ELAC Announces Debut 2.0 Speakers - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 629Likes
post #91 of 1589 Old 03-07-2018, 01:26 PM
AndrewJ's Avatar
Quoted: 84 Post(s)
Liked: 191
Originally Posted by Scotth3886 View Post
But it is a new and different tweeter is it not?
Yes, the tweeter has been re-engineered with a new magnet structure, coil and soft dome.
Andrew
Aja likes this.
AndrewJ is offline
post #92 of 1589 Old 03-07-2018, 01:42 PM
AndrewJ's Avatar
Quoted: 84 Post(s)
Liked: 191
Originally Posted by RWetmore View Post
My question for Andrew Jones (if he indeed comes and participates in this thread) is -- is there a significant change in the voicing of the tweeter/woofer balance? Frequent complaints of the original debuts were that the highs were a bit too recessed compared to the woofer's output, giving the speakers a distinctly 'dark' sound signature, i.e. proportionally a bit too much bass and not enough highs.
I don't necessarily agree with these complaints, but I'm curious if there has been a significant change in the voicing and/or balance between the woofer and tweeter or if it's about the same as the original debuts. Thanks.
One of my goals with the new versions was to address the issue of tweeter performance, both in terms of sound quality level but also in terms of sound balance w.r.t. the woofer. It can be argued that the tweeter level was a little subdued, particularly off axis due to the rather deep waveguide. Add to this listening with grille on, or if the speakers are not toed in, then it accounts for some listeners comments. So in the new version I have used a new dome/large roll surround diaphragm, enabling the tweeter to go both lower and higher in frequency. This neccessitated a new waveguide, so I took the opportunity to try and widen the directivity a little. I also looked at the balance to the woofer, and raised the HF level a touch. It doesn't make the speaker sound bright as such, but it does open up the sound.
Aja, RWetmore, buzzy_ and 6 others like this.
AndrewJ is offline
post #93 of 1589 Old 03-07-2018, 01:44 PM
l0nestar8's Avatar
Quoted: 559 Post(s)
Liked: 677
@AndrewJ : Despite a physically smaller footprint and cabinet, does the B5.2 have any sonic advantages over the B6.2?
l0nestar8 is offline
post #94 of 1589 Old 03-07-2018, 03:13 PM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
OK, that sounds good. Thanks for answering my question.
RWetmore is offline
post #95 of 1589 Old 03-07-2018, 03:55 PM
Scotth3886's Avatar
Quoted: 3752 Post(s)
Liked: 2302
Andrew
Thanks. I'll already have these before I see you at Axpona in April. This will now be five sets of your speakers! The current living room pair of B6s have been on for 12 hours today so far. Low level of course if I'm working, but this is what I mean by non-fatiguing.
frank xbe likes this.
Scotth3886 is online now
post #96 of 1589 Old 03-07-2018, 06:09 PM
frank xbe's Avatar
Quoted: 94 Post(s)
Liked: 61
My Elac B6 and surrounds are on more than off
Samsung 55KS8000 ,Samsung 55MU6300 . Sony 55X850C ,LG 42LB5400 ,Roku 2
Sony ES 7.1HT AVR modest 5.1 surround with Elac B6 fronts w/other impedance and sensitivity matched surrounds , center and powered sub that work well for what it is.
frank xbe is offline
post #97 of 1589 Old 03-07-2018, 07:16 PM
Quoted: 67 Post(s)
Acknowledging the difference in class, will the 2.0 models roughly approximate the brightness of the U-line speakers? I am preparing to deploy UB-5 in front and B6.2 in the rear with the UC-5 center. It would be ideal if the tweeters approximated each others' capabilities, brightness, and overall tonality. Your participation in the thread is greatly appreciated, as is your ability to make wonderful speakers.
Spock1234 likes this.
spartamets is offline
post #98 of 1589 Old 03-07-2018, 07:39 PM
Spock1234's Avatar
Quoted: 24 Post(s)
Liked: 41
Originally Posted by Walkamo View Post
Hi Spock,
In about a week (Around March 15th) many the new Debut 2.0 speakers will be available at Magnolia Home Theater stores in Best Buy. They should be setup for auditioning and for purchase.
Chris
ELAC
Thanks for the response. I will visit my local Best Buy later this month and check out the v 2's.
How about the idea of using the on-walls in a 5.1 set-up? And, the performance of the B6 vs the on-walls as fronts?
Spock1234 is offline
post #99 of 1589 Old 03-08-2018, 05:52 AM
0100010's Avatar
Quoted: 54 Post(s)
Liked: 50
Question
Is there a new 12" debut 2.0 sub coming as well? Referring to the sub on the bottom right in this pic:
As compared to the current S12EQ:
Insert signature here.
LR : E65-C3 | HW-MS750 | SWA-W700
HT : ES 120" | JVC RS-520 | Oppo-203 | Denon X3400H 5.1.2 | ELAC A4.2 B6.2 C6.2 F6.2 & VTF-15MK2
0100010 is offline
post #100 of 1589 Old 03-08-2018, 08:01 AM
buzzy_'s Avatar
Quoted: 134 Post(s)
Liked: 164
The response accounting for wall loading is 4dB down at 70Hz. I designed it to be used as an onwall matched to a subwoofer. It's main purpose is as a surround speaker for home theater
Andrew
Thanks. That seems unusual for a speaker that size, even with wall loading, and speakers this size or even larger don't seem to measure that way.
The SP-BS22-LR (about twice the size of the new on-wall) measured as shown in the attached in Stereophile's 2013 review. The red line is the port, the blue line the 4" woofer.
BTW this discussion illustrates why I find the comments about placing smaller speakers against walls here so puzzling. For most of the HT applications being discussed, the bass reinforcement for a small speaker is not a problem, and is of less concern than other issues.
buzzy_ is offline
post #101 of 1589 Old 03-08-2018, 08:08 AM
buzzy_'s Avatar
Quoted: 134 Post(s)
Liked: 164
Originally Posted by l0nestar8 View Post
The sub-$300 budget category might be the most competitive segment in the market. Incidentally, it's also my favorite segment because of the engineering challenges and the fact that there has been steady (if slow) progress over the decades. I'm happy with my >$1000 speakers, but I enjoy testing out the cheaper ones more. As an engineer myself, I can appreciate a good design, riddled with compromises.
I'm also kinda insane when it comes to finding the "perfect" budget models to recommend to friends and family (and those in this forum) who have no desire to drop 4 figures on good sound reproduction.
I also find this segment very interesting, because (1) it can get very good sound out to a lot of people and (2) it's roughly the point where you can demonstrate to most people the better sound quality. Or in other words, the point up to which where there's still a return for more investment for the broader market of people, those less focused on the fine points of audio quality and more interested in enjoying music and HT. So it's great to see speakers like these ELAC designs.
Though I'm thinking up to $300 a speaker as the point where return on additional investment gets low for most people, not $300 a pair, not sure about you. $300 a pair is an interesting category too, and can reach a lot of people if they know about how much they can get for that money.
tucker3434 and spartamets like this.
buzzy_ is offline
post #102 of 1589 Old 03-08-2018, 08:22 AM
genesplitter's Avatar
Quoted: 117 Post(s)
Liked: 68
... so I took the opportunity to try and widen the directivity a little...
The original Debut speaker, with narrower directivity, may be a better fit as back-surround speakers in my somewhat unusual case. I have a long and narrow living room and was thinking that the narrow directivity (think a narrow flashligh beam) would cover the seating area nicely but not waste "superior sound" on the furniture and junk I'm storing in the rear half of the living room. If the original Debut go on closeout I'll have no choice but to buy a pair
U-Turn Orbit Plus turntable, Marantz SR-7009 AVR, iNuke 6000DSP, DIY LinkwitzLab speakers, MartyCube + JohnnySub, BenQ W1070, Roku stick, Plex
genesplitter is offline
post #103 of 1589 Old 03-08-2018, 02:12 PM
RayGuy's Avatar
Quoted: 2594 Post(s)
Liked: 2348
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #104 of 1589 Old 03-08-2018, 03:38 PM
Walkamo's Avatar
Quoted: 237 Post(s)
Liked: 153
Hi,
Spoke with Andrew regarding using 5 of the on-wall speakers with a sub and he says it should work quite well.
We are going to give it a try tomorrow.
Chris Walker
ELAC
Walkamo is offline
post #105 of 1589 Old 03-08-2018, 03:42 PM
Walkamo's Avatar
Quoted: 237 Post(s)
Liked: 153
Yep. There will be.. Just a little behind...
Should be available in the next couple of months...
Chris
ELAC
Walkamo is offline
post #106 of 1589 Old 03-08-2018, 03:44 PM
Walkamo's Avatar
Quoted: 237 Post(s)
Liked: 153
Originally Posted by TuteTibiImperes View Post
Is Magnolia going to carry the Adantes? I've been wanting to check those out.
Not at the moment. Just the Debut 2.0 models.
Chris
ELAC
Walkamo is offline
post #107 of 1589 Old 03-08-2018, 06:48 PM
0100010's Avatar
Quoted: 54 Post(s)
Liked: 50
Chris
ELAC
Damn. Can't wait that long, already held off ordering Debut 1.0s for the 2.0s; no way can I stand 2 month delay on a sub (or two).
0100010 is offline
post #108 of 1589 Old 03-09-2018, 07:08 AM
Scotth3886's Avatar
Liked: 2302
post #109 of 1589 Old 03-09-2018, 07:19 AM
Scotth3886's Avatar
Liked: 2302
post #110 of 1589 Old 03-09-2018, 09:21 AM
Blacklightning's Avatar
Quoted: 998 Post(s)
Liked: 853
I think that it's great that Andrew and Chris are answering some questions. It really shows that they care about there customers and that they stand behind their products.
I think the best part is that Andrew made the best speaker that he could (with the budget) and for Version 2 it seems like he is just changing things based on customer feedback. This is a great way to do things at this price point.
RWetmore and genesplitter like this.
Blacklightning is offline
post #111 of 1589 Old 03-09-2018, 10:06 AM
Pop Zeus's Avatar
Quoted: 32 Post(s)
Welp, looks like I'm gonna have to sell my barely used speakers and amp (which, I'm not gonna lie, are disappointing) to get something that I hopefully will want to listen to as much as my headphones.
_____
Living Room: Oppo 203 / Chromecast Ultra / Audio-gd R2R-1 / Denon 3400H / Elac F6.2 / Rythmik L12 / Panasonic P50ST60
Pop Zeus is offline
post #112 of 1589 Old 03-09-2018, 11:20 AM
Spock1234's Avatar
Quoted: 24 Post(s)
Liked: 41
Hi,
Chris Walker
ELAC
Thanks. I look forward to the results of your listening test.
post #113 of 1589 Old 03-09-2018, 12:40 PM
Slickman's Avatar
Quoted: 484 Post(s)
Liked: 424
Here's the B6.2 review from CNET!
https://www.cnet.com/products/elac-d...0-b6-2/review/
frank xbe and yanks1 like this.
Slickman is offline
post #114 of 1589 Old 03-09-2018, 02:23 PM
frank xbe's Avatar
Quoted: 94 Post(s)
Liked: 61
Originally Posted by Slickman View Post
Saw that .I have the B6 originals I am satisfied with.
post #115 of 1589 Old 03-09-2018, 02:27 PM
frank xbe's Avatar
Quoted: 94 Post(s)
Liked: 61
post #116 of 1589 Old 03-09-2018, 02:30 PM
cesar123's Avatar
Quoted: 390 Post(s)
Liked: 579
Already out of stock on Amazon lol
Yippee-ki-yay...
cesar123 is offline
post #117 of 1589 Old 03-09-2018, 02:32 PM
Slickman's Avatar
Quoted: 484 Post(s)
Liked: 424
I wish they would make bipole speakers, I like my surrounds to be bipoles.
Slickman is offline
post #118 of 1589 Old 03-09-2018, 03:08 PM
Scotth3886's Avatar
Liked: 2302
That's what it also says when they aren't in yet.
post #119 of 1589 Old 03-09-2018, 03:13 PM
Scotth3886's Avatar
Liked: 2302
The old ones so excel at something like this, on at very low levels, maybe 50-55 db. Hope they don't screw this up by too bright.
https://tidal.com/album/77622786
post #120 of 1589 Old 03-09-2018, 03:31 PM
Slickman's Avatar
Quoted: 484 Post(s)
Liked: 424
I can glue 2 atmos speakers together and put them on the wall sideways to make a bipole and split the wire so it goes to both.
Slickman is offline
Reply Speakers
debut 2.0 , elac , speakers
