Wire type through attic - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Subvivalist
  • 1 Post By darthray
  • 1 Post By buzzy_
  • 2 Post By mikeTRON250LM
post #1 of 13 Old 04-29-2018, 06:11 PM - Thread Starter
zero_zep's Avatar
Quoted: 35 Post(s)
Hello, just looking for some recommendations on what time of speaker wore to get if I’m running through the attic for my surrounds. I’m guessing it’s prob about 50-60 feetish. Thank you.
zero_zep is offline
post #2 of 13 Old 04-29-2018, 07:16 PM
Liked: 3
12 or 14 Gauge. Make sure its rated for inwall.
darthray likes this.
Subvivalist is offline
post #3 of 13 Old 04-29-2018, 07:17 PM
Liked: 3
Well, I guess it doesn't have to. But the extra shielding might deter a squirrel from chewing it up...maybe?
post #4 of 13 Old 04-29-2018, 07:19 PM
MackGuyver's Avatar
Quoted: 265 Post(s)
Liked: 230
I'd also avoid using peanut butter to lubricate the wire when you pull it through the ceiling
Preamp/Amps: Anthem AVM60, Emotiva XPA-2, XPA-5, A-300
Speakers: (7.1.2): Klipsch Reference Premiere / Power Sound Audio S3000i sub
Video: LG OLED65B7A, Oppo UDP-203, Roku Premiere+, Nvidia Shield TV
Room: GIK Acoustics treatments
MackGuyver is offline
post #5 of 13 Old 04-29-2018, 07:55 PM
darthray's Avatar
Quoted: 2304 Post(s)
Liked: 3378
Big +1
zero_zep
Myself, I would get 12AWG, but 14AWG might suffice.
Like the quote above, I also strongly suggest that you get wires that are in wall rated, they should say CL2 or CL3 on them.
The main reason, is for your home insurance, now a day insurance companies like to be able to deny a claim for any excuse.
When buying in bulk on line, the difference of price is around $10, for a 100ft reel, same as the difference of pricing between 12 or 14AWG, so for $10-20, it is a cheap price for a piece of mind.
Ray
Spectah likes this.
darthray is offline
post #6 of 13 Old 04-29-2018, 08:21 PM
buzzy_'s Avatar
Quoted: 134 Post(s)
Liked: 164
The wire gauge considerations are about the resistance. The famous site, see the table:
http://www.roger-russell.com/wire/wire.htm
The wire ratings are for fire protection. You (and your local building code) don't want burning, toxic insulation during a fire. So a CL2 or CL3 riser rating.
http://www.bluejeanscable.com/articles/inwallrating.htm
If they are running in a plenum (HVAC duct) the standard is higher.
Also:
https://www.crutchfield.com/S-pCCslw...kers_wire.html
nissand likes this.
buzzy_ is offline
post #7 of 13 Old 04-30-2018, 12:07 AM - Thread Starter
zero_zep's Avatar
Quoted: 35 Post(s)
Awesome, thank you guys for the quick responses, I’ve never even bought speaker wire before, just used the junk the speaker came with. Can someone please kindly point me to a place where I can buy the 12 gauge in wall certified? Thank you.
zero_zep is offline
post #8 of 13 Old 04-30-2018, 08:07 AM
mikeTRON250LM's Avatar
Quoted: 419 Post(s)
Liked: 345
Access Series 12AWG CL2 Rated 2-Conductor Speaker Wire, 100ft from Monoprice.
https://www.monoprice.com/product?p_id=2817
Monoprice does not have free shipping but amazon is still more expensive (especially if you have to pay tax), but Amazon gets you the product quicker.
https://www.amazon.com/Monoprice-100.../dp/B003L1AFL4
buzzy_ and darthray like this.
mikeTRON250LM is offline
post #9 of 13 Old 04-30-2018, 07:36 PM
darthray's Avatar
Liked: 3378
Good wires, I had some and very well constructed
The only reason I did not use that wire, was because I was making my own fancy speakers wires with a sleeve on them.
And the twisted look did not look right.
But as wire, absolutely nothing wrong with this one.
Good quality, cheap and in-wall/ceiling rated
Ray
darthray is offline
post #10 of 13 Old 04-30-2018, 07:49 PM
farsider3000's Avatar
Quoted: 1621 Post(s)
Liked: 1008
This is good stuff. Very flexible. I have used some black cased wire from mono price in the past that was too stiff.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5/P5 in-wall
Subs: JTR Captivator subs: One S2, Two RS2, One S1
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #11 of 13 Old 04-30-2018, 08:32 PM
Snowmanick's Avatar
Quoted: 467 Post(s)
Liked: 640
I’m running this for all my inwalls and in-ceiling speakers. Does the job.
Snowmanick is offline
post #12 of 13 Old 05-01-2018, 12:43 PM
GoZags13's Avatar
Quoted: 183 Post(s)
Liked: 92
Do yourself a favor and buy a 500' roll instead of the 250'...if you're doing 4 speakers at 50-60' each, that's uncomfortably close to 250. Plus the cost of ordering another small roll is more than if you'd gone big in the first place.
Denon X4300H; Sony XBR75 900E; Definitive Technology RLS-II/DI 5.5LCR/DI 5.5R; NHT SW12
GoZags13 is offline
post #13 of 13 Old 05-02-2018, 10:14 PM - Thread Starter
zero_zep's Avatar
Quoted: 35 Post(s)
Awesome, thank you guys for all of the help, I’m gonna go for the 500, these forums are always so helpful, again thank you.
What types of hangers do I need for these tiny speakers?
ID:	2398380   Click image for larger version
zero_zep is offline
Reply Speakers
