Need help with speaker placement - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 2 Post By pase22
  • 2 Post By DaBateman
  • 1 Post By sdurani
  • 1 Post By elick504
post #1 of 7 Old 05-05-2018, 12:50 PM - Thread Starter
Liked: 1
Hello! I currently have a 7.1 surround system in my home theater. I am using Klipsch KG4.5s for the front 2 channels and just bought 2 more 4.5s. Right now, I have all small speakers as surrounds. Should I place the second pair of Klipsches as the side surrounds or the rear surrounds in my 7.1 setup? Not sure what will give a more convincing surround effect -- having the moire powerful surrounds on the sides or in the back. Any recommendations will be greatly appreciated. Thanks!!
elick504 is offline
post #2 of 7 Old 05-05-2018, 01:14 PM
pase22's Avatar
Quoted: 3862 Post(s)
Liked: 3328
Most soundtracks are mixed in 5.1. I would use the better speakers as side surrounds and the other 2 as either front height or on ceiling atmos channels if your AVR supports it.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Emotiva A-300, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #3 of 7 Old 05-05-2018, 01:33 PM - Thread Starter
Liked: 1
Thanks for the quick reply. I would still like to keep the 7.1 setup and not change to 5.1. What would be the best option when in 7.1? Larger side or rear speakers?
elick504 is offline
post #4 of 7 Old 05-05-2018, 03:18 PM
pase22's Avatar
Liked: 3328
Ideally you'd want all the surrounds the same. Short of that, I'd put the larger/better speakers as side surrounds.
sigpig and elick504 like this.
pase22 is offline
post #5 of 7 Old 05-05-2018, 07:40 PM
DaBateman's Avatar
Quoted: 723 Post(s)
Liked: 521
I agree w/ @pase22 I’d put the new larger bookshelf’s in the side position. Rears aren’t nearly as important
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #6 of 7 Old 05-06-2018, 01:14 PM
sdurani's Avatar
Quoted: 7885 Post(s)
Liked: 7079
When sounds move from the fronts to the surrounds they shouldn't change. So better to use the second pair of 4.5s at your sides, since they are adjacent to the fronts. Use the dissimilar speakers behind you, where our human hearing is not as good and a little less apt to notice differences. IF you can eventually replace them with a third pair of 4.5s, that would be optimal.
elick504 likes this.
Sanjay
sdurani is offline
post #7 of 7 Old 05-08-2018, 01:47 PM - Thread Starter
Liked: 1
Thanks for the responses! I'll switch out the 4.5s to the side surrounds.
sdurani likes this.
elick504 is offline
Reply Speakers
7.1 , Home Theater , speakers , surround
