Desperately need help with fronts in new home theater - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #31 of 37 Old 05-17-2018, 04:57 PM
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Originally Posted by Eric 22 View Post
i appreciate the recommendations, and I have looked at the E1, considering i need wall or ceiling mount, but how will those sound at 110 degrees from the listening position since they mount flush to the wall? I figured to position any sats to point at the main listening position. Too bad I cant mount a beefy bookshelf for surrounds.
I just seen the E1 is actually sold out atm. I have bookshelf’s for my sides at 110 degrees and typically run them 1-2dB hotter than the fronts.
Although much more expensive the E2 pair would be ideal.
$469
https://emotiva.com/products/airmotiv-e2
Also if you don’t want to spend so much you could get the Fluance XLBP for $199 in black or walnut also being a bipole design such as the E2’s.
https://www.fluance.com/xlbp-wide-di...pair-black-ash
Or here on Amazon for prime shipping and easy returns
https://www.amazon.com/Fluance-XLBP-.../dp/B00CRMKJTQ
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #32 of 37 Old 05-17-2018, 05:10 PM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2328
I'd run two more JBL in-cielings in the wall for surrounds (mounted to a backer box on wall) to get a match with your Atmos speakers. And they already have a wide dispersion pattern that you want for Atmos speakers. IMO, you don't want bipoles or dipoles for surrounds in an Atmos set--you want direct radiating, wide dispersion monopoles--and you want those speakers to match either the LCR or the overheads, if possible. I personally run Canton 880 in-ceilings in a similar set up for surrounds and overheads and it sounds great.
Here is a useful link if you don't have it already:
https://www.dolby.com/us/en/technolo...guidelines.pdf
jjackkrash is offline
post #33 of 37 Old 05-17-2018, 05:58 PM
littlefoott's Avatar
Quoted: 378 Post(s)
Liked: 223
if you have any concerns about running the 4 ohm speakers , get a cooling fan for your yamaha, there are several options depending on the location (rack mount or stand, console, etc)
Audyssey is a great start, but not always a great finish.
Receiver:Marantz SR-7012, Speakers:Def Tech ST-8060 towers, CS-8040 center, SR-8040 surrounds, Pro Monitor 1000 heights
Subwoofer: SVS PB-2000
TV: 65" LG UG8700 remote: Harmony 1000
littlefoott is offline
post #34 of 37 Old 05-17-2018, 07:31 PM - Thread Starter
Eric 22's Avatar
Quoted: 14 Post(s)
Liked: 4
I have a few ac infinity fan units in my network rack, i will pick up a receiver unit from them as well. They make awesome stuff, and since my cabinet will be closed in front and the only opening will be in the back, im sure it will get extra hot in there.
Eric 22 is offline
post #35 of 37 Old 05-17-2018, 07:38 PM
torii's Avatar
Quoted: 3341 Post(s)
Liked: 1879
you go listen to anything yet or going to buy off internet recs?
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #36 of 37 Old 05-17-2018, 08:03 PM - Thread Starter
Eric 22's Avatar
Quoted: 14 Post(s)
Liked: 4
i put the orders in today for the hsu dual 3.5 and emotiva t2/c2. i really wanted the dual big subs but needed a push, and as far as the speakers, yep, buying blind. what can i say, i like to live life on the edge. Good thing Emotiva has a risk free trial. Its hard for me to demo speakers in stores as most A/V dealers in NYC area really only carry 3-4 lines of speakers that they focus on. I would spend days driving around the tri state area, not to mention spending more on parking lots than a pair of subs would cost. Hopefully I wont regret turning to an awesome bunch of people on this forum for help, though i doubt i will.
jjackkrash and Zorba922 like this.
Eric 22 is offline
post #37 of 37 Old 05-17-2018, 08:09 PM
torii's Avatar
Liked: 1879
well I bet only a dozen or less own or even listened to the new T2's been out maybe a yr??? hope you like em.
torii is offline
Reply Speakers
Kef , Paradigm , speakers , Svs , theater
