Please help choosing JTR or SVS - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 56Likes
post #91 of 146 Old 07-01-2018, 02:45 PM
madhuski's Avatar
Quoted: 1657 Post(s)
Liked: 1118
Originally Posted by sigpig View Post
High sensitivity, high power handling, nearly indestructible.
So then what are the trade offs to achieve all that?
madhuski is online now
post #92 of 146 Old 07-01-2018, 08:08 PM
nodoubt's Avatar
Quoted: 520 Post(s)
Liked: 322
id say less finesse, less musical, harder to blend seamlessly....
just my guess
nodoubt is offline
post #93 of 146 Old 07-02-2018, 05:09 AM
GIEGAR's Avatar
Quoted: 1030 Post(s)
Liked: 1730
Cost! The high grade Neodymium magnet coaxial compression driver used by JTR in their 3-way models retailed for between $750 - $800 per unit the last time I looked.
just my guess
This is what high-priced consumer audio spivs would like you to believe. But I can't see how the attributes of high sensitivity, high power handling and being "almost indestructible" precludes the first two (loosely defined) attributes. The mid/high coaxial being point source, time aligned, phase coherent and very low distortion at high SPL would strongly indicate the opposite is true.
As for "harder to blend seamlessly...."; the BMC coaxial has a FR down to 300Hz (-10dB?) and loaded onto a 60º x 60º horn, is readily blended with the woofers using a 500Hz crossover on most JTR speaker models. Additionally, the midrange CD covers the majority of the range of human voice.
MKtheater, madhuski and BassMojo like this.
GIEGAR is online now
post #94 of 146 Old 07-02-2018, 06:57 AM
raynist's Avatar
Quoted: 2240 Post(s)
Liked: 2492
just my guess
Not at all.
Trade offs are size, price and they look somewhat industrial.
raynist is offline
post #95 of 146 Old 07-02-2018, 07:09 AM
216dB Shockwave of pain
Adamg (Ret-Navy)'s Avatar
Quoted: 1087 Post(s)
Liked: 2540
Originally Posted by raynist View Post
Not at all.
Looks! Do you buy speakers to look at or listen to ? Some want the former and are never fully satisfied with the latter. Others go for the latter and never give a crap about the former. Chose wisely my friend.....
AdamG, ...out!
The government cannot give to anybody,
anything that the government does not first,
take from somebody else.
Adamg (Ret-Navy) is offline
post #96 of 146 Old 07-02-2018, 07:18 AM
raynist's Avatar
Liked: 2492
All of the speakers in my 4 systems are the PA type, looks come last for me
Adamg (Ret-Navy) likes this.
raynist is offline
post #97 of 146 Old 07-02-2018, 06:20 PM - Thread Starter
Quoted: 75 Post(s)
Liked: 7
Can I ask if there is a comparable (sound, quality, price) alternative to JTR ?
I've emailed, called, and leave messages, but there is no response from them (few emails over 2 weeks, called since last week).
I am a bit concerned of getting help in the future if just getting to their sales is rather difficult.
Is a diy a good idea ? I saw some info on the DIY Sound Group but cant find info on whether a build instruction is included in the packs they sold. (I figure we can use a locally sourced wood. Its something we have plenty of here).
Can anyone please advise how the DIYSG 1899 sounds ? For ht and for music ?
Do you diy the subwoofer also (I imagine this is more difficult ?). If not, then I'd still have to find a sub supply that is hopefully comparable to the cap2400.
Thank you guys.
hughhugh is offline
post #98 of 146 Old 07-02-2018, 06:41 PM
markg35's Avatar
Quoted: 365 Post(s)
Liked: 291
DIY is most definitely an option look at that section.There are threads on the 1899's'one guy built 7!.
The Titans are another option.
The kits don't really come with instruction but there are build threads on most models.Most you can get prebuilt crossovers or there is a speaker designer who can bulid them for you.
Finishing is really the most difficult part.What I mean that by that,is the skys the limit as to how you finish them whether paint,duratex,veneer,ect.
Subwoofers can be built fairly easily as well depending what you want.There are many proven designs in the DIY section,and new ones are popping up daily(it seems)Again the skys the limit.
Check out the DIY section.Many who have, will never go back to commercial speakers and subs(I'm one of them,even though I've only just begun the journey.
markg35 is offline
post #99 of 146 Old 07-02-2018, 06:46 PM
imureh's Avatar
Quoted: 3566 Post(s)
Liked: 4853
Thank you guys.
If not DIY then look at PSA speakers as well. While not the level of JTR they are a lot cheaper and IMO provide a lot of bang for the buck.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #100 of 146 Old 07-02-2018, 06:54 PM
raynist's Avatar
Liked: 2492
Thank you guys.
@Jeff Permanian
Strange, I have always had good luck calling them. He is on central time zone and a one man show.
I would call in the early to mid morning Central Standard Time. I think there is a big time zone difference from what I remember (you are not in the US correct?).
raynist is offline
post #101 of 146 Old 07-02-2018, 08:15 PM
GIEGAR's Avatar
Liked: 1730
JTR's are probably without peer in a high performance passive speaker, but here's a few off the top of my head:
Seaton Sound The Catalysts are DSP controlled tri-amplified active speakers that hook straight up to your pre/pro. (Rack mounted amps are an option.)
Tyler Acoustics Pro Dynamics line using Eminence pro drivers. (Cardas; bi-wiring? A taste of snake oil here.)
Danley Sound Labs Synergy Horns.
Yorkville Sound Unity U215B (passive) or Unity U15PB (powered).
post #102 of 146 Old 07-02-2018, 10:08 PM - Thread Starter
Quoted: 75 Post(s)
Liked: 7
It sounds interesting. Would be great if someone has posted the video on youtube. Although not accurate, I think those videos help.
I thought DIYSG also sells assembled crossovers ? I am not too confident in dealing with electronics. This would be a big factor.
This part would be easy on my side ( for a change ). There are plenty of carpenters here. Although they mostly work without machines (using handsaw and the likes)
DIYSG sub seems to be very limited. I saw a lot of interesting ideas on the DIY section but the thing with too many options is it becomes difficult deciding which one to choose.
Will do.
Thanks @markg35 . I'll keep this option open but will try a few more days on getting in touch with JTR
hughhugh is offline
post #103 of 146 Old 07-02-2018, 10:10 PM - Thread Starter
Quoted: 75 Post(s)
Liked: 7
Ok Thanks @imureh . I'll have a look at them too.
hughhugh is offline
post #104 of 146 Old 07-02-2018, 10:13 PM - Thread Starter
Quoted: 75 Post(s)
Liked: 7
@Jeff Permanian
Thanks Raynist. I googled the area code which comes out as Illinois. So time zone wise should not be an issue. We're 12 hours difference.
Hope he's okay. But probably just too busy. I'll give it a couple more go.
hughhugh is offline
post #105 of 146 Old 07-02-2018, 10:16 PM - Thread Starter
Quoted: 75 Post(s)
Liked: 7
Thanks @GIEGAR . I've heard of Seaton (much more expensive?) and Danley but not the others. I'll have a look at these too.
hughhugh is offline
post #106 of 146 Old 07-02-2018, 11:42 PM
raynist's Avatar
Liked: 2492
Yorkville is a Canadian pro audio company. Interestingly the u215 is a unity horn design from Tom Danley.
Tom Danley, Mark Seatin and Jeff Permanian all used to work together and are good friends.
raynist is offline
post #107 of 146 Old 07-03-2018, 03:50 AM
Quoted: 84 Post(s)
I will take JTR/PSA over SVS anyday if I live in US.
Unfortunately SVS is the only company that sells locally in Canada so I have no choice
KEF R900 (coming), Martin Logan Motion 40, 50XT, 15s, LX16. Dual SVS SB13. Dual PSA 3611s (coming)
Marantz SR5009, Yamaha A-S2100, MX-A5000, OPPO HA-1, Burson HD-160
Headphone : HD800 / Fostex TH900 mk1 / TH610 / Beyerdynamic T5p.2 / HE6 / LCD 2.2 / Denon AH-D7100/AH-D600
canadian411 is offline
post #108 of 146 Old 07-03-2018, 04:45 AM
GIEGAR's Avatar
Liked: 1730
Yes, I believe at Sound Physics Labs/ServoDrive before they struck out on their own.
ServoDrive appears to have wound up years ago: https://web.archive.org/web/20050118...basstech7.html.
What about Yorkville Unitys? Surely if we can get 'em in Australia, you can get 'em in Canada?
post #109 of 146 Old 07-03-2018, 04:59 AM - Thread Starter
Quoted: 75 Post(s)
Liked: 7
Giegar, Raynist, all these brands seem to be much more expensive than the JTR though. I like the idea of the Danley, but they have a lot to choose from and I havent figured out which one is comparable to 212RT. Plus they dont post their price (normally a sign that they'd be way too expensive...)
So far it seems the diy option is the only feasible route.
Canadian411, yes I agree. From previous advises above I have removed svs from the list. I think I'd be happy with the JRT if only there is a way to order it.
Thanks guys
hughhugh is offline
post #110 of 146 Old 07-03-2018, 05:34 AM
imureh's Avatar
Liked: 4853
Thanks guys
Did you look at PSA? raynist can confirm that they are excellent speakers. I have yet to come across anyone that has not been pleased with them.
imureh is offline
post #111 of 146 Old 07-03-2018, 05:37 AM
ack_bk's Avatar
Quoted: 1365 Post(s)
Liked: 1550
There seems to be a common theme with JTR not picking up the phone or answering emails. I see this in a lot of threads these days. Too bad, but this is the downside of some of the small ID companies.
I think DIY makes sense, you should be able to get fully assembled cross overs and you could always hire a carpenter to assemble the cabinets.
What is your budget? Are these speakers going to be out in the open or hidden behind a screen? There are some good options from JBL and QSC as well for home theater, but you probably want to hide them behind a screen.
ack_bk is offline
post #112 of 146 Old 07-03-2018, 05:53 AM - Thread Starter
Quoted: 75 Post(s)
Liked: 7
@ack_bk I saw the jbl ones. They seem to be home theater appropriate but not for music.
I am not familiar with QSC yet.
Budget wise I'd be happy with 3xjrt212rt and 2xcap2400. So about $13,600
@imureh I was just looking at PSA and am thinking that the spec (they seem to have only 1 tower model) is not on par with the jtr212rt. So if I can I'd look for something around the same spec (which hopefully translate to the same performance, although I've never actually heard the 212rt myself. But I know I will always wonder about it if I go with a lower spec).
Thank you
hughhugh is offline
post #113 of 146 Old 07-03-2018, 05:55 AM
imureh's Avatar
Liked: 4853
Thank you
I think @raynist can explain what differences you can expect to hear as he has owned both JTR and PSA. Not sure if it was exactly the 212RT but could help you get a feel.
imureh is offline
post #114 of 146 Old 07-03-2018, 06:19 AM
raynist's Avatar
Liked: 2492
Thank you
You should be hearing from Jeff soon.
raynist is offline
post #115 of 146 Old 07-03-2018, 06:21 AM
raynist's Avatar
Liked: 2492
The 212RT is a full range speaker so this is much different than the PSA 210T speaker which is good down to around 70ish. I actually use the PSA 210T in my bedroom full range by giving it a big boost around 50-60hz. It is good enough for a bedroom
raynist is offline
post #116 of 146 Old 07-03-2018, 08:08 AM
imureh's Avatar
Liked: 4853
But if he is getting some good subs these should work for him right?
imureh is offline
post #117 of 146 Old 07-03-2018, 08:22 AM
raynist's Avatar
Liked: 2492
It could, but I thought part of what he wanted was full range music?
There is a pretty big difference in the sound coming out of the high end CD in the JTR RT/HTR/RM line and the PSA line as there should be - the CD in the JTR costs more than the PSA110 speakers.
I have never had the thought of upgrading my JTR speakers with the 2 way CD
raynist is offline
post #118 of 146 Old 07-03-2018, 08:25 AM - Thread Starter
Quoted: 75 Post(s)
Liked: 7
Imureh, Raynist, yes I sometimes like to do 2.0 music. So a full range speaker is preferable.
hughhugh is offline
post #119 of 146 Old 07-13-2018, 11:41 AM - Thread Starter
Quoted: 75 Post(s)
Liked: 7
Since I did not receive a single response from JTR despite emailing and leaving voice messages on their answering machine over the course of more than a month, I am no longer pursuing this brand.
However, I'd like to Thank You to all the above that has helped in your replies. I believe I learned a lot from your feedback. The support that I see from this group was a big part of my interest in jtr.
For now, I am moving to the DIY section.
Thank you guys
Red Five likes this.
hughhugh is offline
post #120 of 146 Old 07-13-2018, 12:21 PM
imureh's Avatar
Liked: 4853
Thank you guys
Good luck. Lot of value in DIY if you are the handy type for sure. You will save a lot of money as an upside for sure. As busy as Jeff is, I think it’s probably worthwhile for him to consider some help at least responding to potential customers.
imureh is offline
Reply Speakers
