Polk Audio Signature Series S35 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By Doe Doe
  • 1 Post By MIX_MASTER_ICE
  • 1 Post By cocrh
  • 1 Post By Ryan Statz
post #1 of 19 Old 07-24-2018, 05:58 PM - Thread Starter
erwildcat's Avatar
Liked: 0
My new Denon AVRX2400H sounds amazing except for the center channel speaker (Sony SS-CN5000P) which still sounds as bad (hollow and boxy) as on my old Sony receiver. I have tried turning the center channel off completely but do not like how that sounds either. I know the boxy sound of a center speaker is a common complaint but I was wondering if throwing more money at the problem like, say a Polk S35 would help any. My front speakers are in the "Big Advent" walnut enclosures from the mid 1970's but the woofers and tweeters were replaced about twenty years ago with parts from another manufacturer unknown to me (They still sound great!). Any advice would be appreciated.
erwildcat is offline
post #2 of 19 Old 07-24-2018, 06:36 PM
Quoted: 2671 Post(s)
Liked: 1262
The S35 may sound a bit thin too, as it's a thin speaker.
If you can fit in a larger center, I see no logical reason to choose the S35. If you want to go with the Polk signatures, choose the S30 instead.
If your budget is in the $250+ range, other options too, like the Emotiva which is frequently recommended here.
Lp85253 likes this.
Doe Doe is online now
post #3 of 19 Old 07-25-2018, 11:33 AM
gajCA's Avatar
Quoted: 9253 Post(s)
Liked: 6359
Easy enough to try, and return, the S35 at Best Buy if not happy.
Sound and Vision was surprised that they liked it.
Geoff A. J., California
gajCA is offline
post #4 of 19 Old 07-25-2018, 12:40 PM
Quoted: 167 Post(s)
Liked: 144
I have the S35 and really like it. Seems to work really good in my room with my setup.
LG OLED65B7, LG UP970, Yamaha RXA770, Polk S55's, Polk S35, Polk S15's, KEF Ci160ER's, Dual SVS PB-1000's
Sask HT is online now
post #5 of 19 Old 07-25-2018, 12:48 PM
Liked: 1262
OP may be fine with the S35, but outside of those with space issues, why would he purposely choose that one? Again, if he can only fit that size center, sure, I see no reason not to give it a try.
But otherwise, I can't think of any reason to go that way. It's not like he wants it to match his fronts... and even if he does want to go with Polks, the S30 makes more sense. The S35 is usually the center of last resort for TV over fireplace or other size constraint people.
post #6 of 19 Old 07-25-2018, 04:50 PM
Quoted: 167 Post(s)
Liked: 144
That's a matter of opinion . I personally think the S35 sounds better than the S30.
post #7 of 19 Old 07-25-2018, 05:04 PM
Liked: 1262
True, it's all subjective. Just that most comments here seem to lean towards the S30 over the S35. And freq. charts give the advantage to the S30. I am guessing you find it better with clarity/highs over the S30, at the expense of a little mid-bass?
If near a BB, OP could try both, return the loser. Although since the OP can get any center he wants and isn't trying for a match, there may be better options for him than the Polks anyway. It just seems odd to go with the S35 if the OP's main complaint with his current center is it's too hollow. It's like if someone complained their center was too warm/muffled and then recommending a Pioneer C22 to him.
post #8 of 19 Old 07-26-2018, 12:35 AM
dowop's Avatar
Quoted: 122 Post(s)
Liked: 43
I have the S35 & S30. I like the sound of the S30 better. That being said I went back to the csia4 & csi a6. I have two systems using Polk speakers.
dowop is offline
post #9 of 19 Old 02-09-2019, 08:18 AM
Quoted: 35 Post(s)
Liked: 2
Back when I knew even less then now I bought a HT in a box since I was a bit tight I got a Paradigm Cinema 110 but I swapped the subwoofer for a better one and added a couple of their ADP v.3 dipoles to give me 4. I decided to upgrade and replaced the 4 satellites with Polk S10's (wanted S15's but they were too big for one of the wall mounted location). For the fronts I'm on the fence, I'm aware that the S30 is probably better than the S35 but there are issues. First of all I currently have my L/C/R speakers wall mounted and would rather stay with that or I'll have to do some spackling and painting where the center was mounted and I'd have to put the S30 on top of my BDI entertainment center and I'd rather not. Also I may be wrong but isn't it preferable to have the front 3 match? My current fronts have a frequency response of 120Hz to 20kHz in spite of 4.5" drivers so I figure it'll be an upgrade either way. Any advice?
cldlhd is offline
post #10 of 19 Old 02-09-2019, 02:16 PM
MIX_MASTER_ICE's Avatar
Quoted: 2674 Post(s)
Liked: 2480
The S30 is the only true center channel in the Signature line. The S35 is a LCR speaker that is designed for those who have minimal space.
Ryan Statz likes this.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB32,XB31. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. SIVGA SV004. SA HDTwo. HyperX CloudPS4. TB Elite AtlasAero. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
post #11 of 19 Old 02-09-2019, 02:24 PM
Quoted: 494 Post(s)
Liked: 438
If you want to go Polk and 250 is your budget this is the one to get. 3 way design.
https://www.adorama.com/pkalsim704c....ce=rflaid62905
Emotiva C1 or C2 also awesome. C2 is huge so check size at Emotiva. Both 3 way designs too
https://emotiva.com/collections/loud...ts/airmotiv-c1
https://emotiva.com/collections/loud...ts/airmotiv-c2
cocrh is offline
post #12 of 19 Old 02-09-2019, 04:02 PM
Quoted: 35 Post(s)
Liked: 2
I could put an S30 on top of my entertainment center , it's not a space problem but more of an aesthetic one plus I'd have to patch the 3 holes from where the current center speaker is mounted. If I went with an S30 what to use for the left and rights as they are also currently wall mounted as well?
cldlhd is offline
post #13 of 19 Old 02-09-2019, 05:47 PM
Liked: 1262
What is the max size speaker you can mount? What are your current fronts?
If you have the space (and money), I'd probably say consider the Polk lsims over the signatures. They aren't small speakers though.
post #14 of 19 Old 02-09-2019, 06:01 PM
Quoted: 35 Post(s)
Liked: 2
How well would they match with S10's or S15's for surrounds?
cldlhd is offline
post #15 of 19 Old 02-09-2019, 06:56 PM
Liked: 1262
No idea, but matching isn't like it's written in stone.
Would you rather have better fronts that don't match 100% with the surrounds, or inferior fronts that match?
I'm not saying the signatures are bad, just that the lsims should be better. Matching the fronts is ideal (although even then, sometimes not matching is the better option). Matching the surrounds I guess is nice, but I wouldn't worry about it if it's not an exact match.
An exception being is if you like to play a lot of multi-channel music. Then matching and ideally exact models all-around would be warranted.
post #16 of 19 Old 10-09-2019, 05:35 AM
displaylou's Avatar
Quoted: 45 Post(s)
Got the chance to compare the S30 and S35 in the authorize retailer audio store of polk products here in my country. In my mind I choose S30 already based on the online review. At first we tested the S30, then the S35 in same sequence of the movie. In my humble opinion, S30 have a lean back soundstage, whereas the S35 has an aggressive front soundstage maybe because of the six drivers that S35 have. No contest at all, I choose the S35 and brought it home for breaking-in.
Here is the unboxing and partial sound test on my 5.1.2 system....
ID:	2625676   Click image for larger version
ID:	2625678   Click image for larger version
displaylou is offline
post #17 of 19 Old 10-09-2019, 09:17 AM
Ryan Statz's Avatar
Quoted: 549 Post(s)
Liked: 319
If you were going to go for the Polk Signature series, the S30 would probably be the better choice. If you wanted to stick with Polk altogether, I am happy with the CSi A6 I have (even the A4 is nice - I had it, too, but swapped it out for the A6 when I came across an idiotic deal for one), or the LSiM 704/706 could be viable options.
dowop likes this.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is offline
post #18 of 19 Old 10-09-2019, 11:35 AM
jmbgator's Avatar
Quoted: 46 Post(s)
Liked: 33
I own a S-35 and it sounds great. No major complaints. I went with the S-35 as I needed a center with a thin profile to fit under my TV. It has alot of good reviews on Amazon. I may eventually raise my TV and upgrade to a traditional sized center channel but for what its worth, the S-35 puts out great output for its size
TV: 65'' Samsung KS8000; AVR: Denon AVR X-4500H; Center Channel: Polk Signature S-35; L/R Channels: Polk Signature S-20; LFE: SVS-SB3000; UHD Blu-Ray Player: Sony UBP-X800; Gaming: PS4 Pro; Streaming Device: Apple TV 4K
IEMs: Shure 535, Shure 846; DAC/Amp: Dragonfly Cobalt
jmbgator is offline
post #19 of 19 Old 10-23-2019, 07:18 AM
Slaine's Avatar
Quoted: 65 Post(s)
Another vote for the S35. We bought it mainly for its slim profile, but have been consistently impressed with the output from the speaker. Dialog in particular is handled very well.
Slaine is offline
Reply Speakers
