Sound bar above projector screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-17-2018, 09:59 PM - Thread Starter
MartyNg's Avatar
Question Sound bar above projector screen?
I am looking to donate my 50" TV and use a pull down screen + projector instead to free up some floor space. I would like to make this a very inexpensive project. If I end up using it a lot, I may upgrade down the road.
For now, I have a 100" pull-down screen (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) , which is good enough quality for me. I have 2 large open doorways into my living room, so one of them would be covered temporarily when using a projector. See the attached picture where I've drawn in the screen and a sound bar above. I have a SONY HT-CT150 subwoofer + sound bar currently hooked up to my TV. I would like to use this decent sound system with the projector, but the only place for the sound bar would be above the screen. The ceiling is 9 feet tall. The soundbar would sit about a foot below the ceiling. Is this a reasonable setup if I angle the sound bar down slightly?
Name:	Sound bar and screen.png
MartyNg is offline
post #2 of 3 Old 08-17-2018, 10:10 PM
popalock's Avatar
Quoted: 1495 Post(s)
Liked: 2097
Yes. I love it. Do it. Take pics. Post them here.
popalock is offline
post #3 of 3 Old 08-18-2018, 10:22 AM
RayGuy's Avatar
Quoted: 2852 Post(s)
Liked: 2620
Cool, the way the screen just floats there!
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
Reply Speakers
position , projector , screen , sound bar
