Energy CB-20 vs Sony Cores SSCS5 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
  • 3 Post By Driv3l
  • 2 Post By zieglj01
  • 1 Post By Doe Doe
  • 2 Post By Driv3l
  • 1 Post By Rgarc
  • 1 Post By Rgarc
  • 1 Post By zieglj01
  • 3 Post By MIX_MASTER_ICE
  • 1 Post By Doe Doe
  • 1 Post By ematcion
post #1 of 28 Old 10-24-2018, 02:59 PM - Thread Starter
Liked: 5
I currently have a set of Energy Take Classics as my fronts and surrounds (with a Dayton sub-1200 12" sub and a mediocre center i.e. JBL Loft-20). One of my surrounds went bad (random distortion noises when playing audio).
I decided to move one of my classics from the front to replace the bad surround and replace the fronts with something new.
First got a pair of Energy CB-20's which were on discount. I figured these would be a good match for the take surrounds since they are from the same company.
The CB-20's are decent.... didn't wow me. Ran them pretty consistently for ~3 days to break them in and hoping they will get better. They did not. Sounded a little boxy and didn't quite have the punch I was expecting.
I just received a pair of Sony Core's (SSCS5) to compare.... and wow, are those speakers awesome! The room sounds like it's filled with sound now. I did not expect them to be as good as they are. They have a good bass punch too, especially compared to the CB-20s, which have bigger woofers.
I am very impressed with the Sonys!
Currently have a set of Infinity Reference 253's (floor standing) to compare to the Sonys. Will see how the Sony's hold up against those.
Driv3l is offline
post #2 of 28 Old 10-24-2018, 03:12 PM
Quoted: 1884 Post(s)
Liked: 1613
i have heard them in my set up as well .. i agree that they are better than most anything near the price point..($150).. enjoy , imo, you chose wisely..
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #3 of 28 Old 10-24-2018, 04:56 PM
zieglj01's Avatar
Quoted: 2935 Post(s)
Liked: 2837
The Sony is for real
Lp85253 and NuSoardGraphite like this.
Who AM I
zieglj01 is offline
post #4 of 28 Old 10-24-2018, 05:42 PM
Quoted: 2573 Post(s)
Liked: 1196
I find the Cores surprisingly decent considering their price. And even more-so when they go for <$100. They are a notch below Kef Q100s to my ears, but it's not like there is a humongous difference in quality between them.
If they had an andrew jones signature on the back, I expect they would be more popular than they are. I still find it weird how some review sites claimed (or maybe still claim) the BS22s are the best budget speaker and overlook the Cores entirely.
Doe Doe is offline
post #5 of 28 Old 10-24-2018, 05:45 PM
Liked: 1613
at moderate volume , i like the sony's better than the kef's...and if i had to do it over..well.. the kef's wouldn't be here and the cores would..
Lp85253 is offline
post #6 of 28 Old 10-24-2018, 06:15 PM
Liked: 1196
For music listening only, I might agree. Not sure, as I primarily use them for HT. There I find the Kefs have a bit more 'sparkle' which works well w/ movies.
I'm not sure if I'd like that 'sparkle' so much if I was listening to music for hours on end though.
Lp85253 likes this.
Doe Doe is offline
post #7 of 28 Old 10-24-2018, 06:17 PM
Liked: 1613
bingo,,, the sony's sound like a poor man's b1 to me.. so knowing my posts you can do the math..
Lp85253 is offline
post #8 of 28 Old 10-24-2018, 06:45 PM - Thread Starter
Liked: 5
I tried the BS22's briefly when Frys had them on special. I didn't see what all the fuss was about. They didn't sound that much better than my Take Classics (at least not to me)... plus, I really hated the way they looked, so I ended up returning them.
Driv3l is offline
post #9 of 28 Old 10-24-2018, 10:04 PM
Zorba922's Avatar
Quoted: 6862 Post(s)
Liked: 5134
Most noticeable difference will be that the Refs should be able to play a lot louder without distortion. The Cores are awesome at moderate volumes and crossed over to a sub, but when pushed near reference levels their limitations quickly become obvious, esp. if running full range. The Core towers and centers though are reportedly not anywhere as good as the bookshelves.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #10 of 28 Old 10-25-2018, 03:37 PM
Quoted: 411 Post(s)
Liked: 304
another vote for the cores. The only reason I didn't go with them is that I'm holding out for something that is a bigger step up from my current system since I don't like to upgrade often.
Rgarc is offline
post #11 of 28 Old 10-25-2018, 03:41 PM
Liked: 1613
emotiva b1's are darn similar..a little smoother with the amt tweeter... and better treble extension..
Lp85253 is offline
post #12 of 28 Old 10-25-2018, 03:56 PM
Quoted: 411 Post(s)
Liked: 304
The B1's are on my short list but I want to see what the RSL CG5's have to offer and i'm in a position where I can wait and see.
Lp85253 likes this.
Rgarc is offline
post #13 of 28 Old 10-25-2018, 04:01 PM
Liked: 1613
the phiharmonic aa+ might work for you as well .. a good source says they are the same "kind" of presentation as the cores and b1's ...
Lp85253 is offline
post #14 of 28 Old 10-25-2018, 04:12 PM
Quoted: 411 Post(s)
Liked: 304
I'm currently looking at those for my office where I'm currently using yamaha powered monitors. I'll probably try the AA's first while I wait for the CG5's to get released. The HT has to wait because I trying to decide where to remodel or move.
Lp85253 likes this.
Rgarc is offline
post #15 of 28 Old 10-25-2018, 04:26 PM
MIX_MASTER_ICE's Avatar
Quoted: 2546 Post(s)
Liked: 2392
I have both the Energy CB-20's and Sony CS5's. Both are good speakers for their price points. The CB-20's do require a lengthy break-in period, but once they are settled in they have a really nice, balanced sound. For 6.5" woofers the cabinet size is relatively small, coming in around the size of most speakers with 5.25" woofers. I'm using the Energy CB-20's with the CC-10 center in my very small theater room set up and I've been very pleased with them. Aesthetically speaking, the Energy speakers look a bit more stylish. Both speakers benefit greatly from a sub to anchor the low end, but the CS5's are a bit thin in bass on their own, more so than the CB-20's. IMO, both are edged out by the Polk Signature speakers, which generally cost a bit more.
Subs>RBH I-12e/I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 530/520c, 270/235c/230/225c, Arena 130/125c. Jamo S807/S803. Pioneer FS52/BS22A/C22. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith AM Cinema 5 bs. Polk RTiA1/CsiA4. Infinity R152. Other Audio>Sony MDR-Z7m2, WH-XB700, XB32, XB31.RBH EP1. Logitech GPro HS. Plantronics RIG 500 Pro HS. LG FH6,RK8,PK5,PH4. UE Boom3.
MIX_MASTER_ICE is online now
post #16 of 28 Old 10-25-2018, 06:03 PM
Youcan1's Avatar
Quoted: 113 Post(s)
Liked: 91
I used to have the Energy CB-10 and they didn't really wow me either. Kind of muddy sounding and the top and bottom end didn't really impress me at all. I think I liked the Energy RC-Micro set more (even though they had no bass at all due to their size). I also have the Cores and the Infinity Reference R162/R152 bookshelf speakers and the Infinity are a step up in every category to me. Cleaner sounding with better bass and treble. The Cores are still pretty good though for their cost.
Youcan1 is offline
post #17 of 28 Old 10-25-2018, 07:10 PM
zieglj01's Avatar
Liked: 2837
Stereophile did not like them and their measurements were poor
https://www.stereophile.com/content/...r-measurements
Lp85253 likes this.
Who AM I
zieglj01 is offline
post #18 of 28 Old 10-26-2018, 12:39 PM - Thread Starter
Liked: 5
Yeah.. I figured the CB-20's would start sounding better as I got closer to the 100 hour break-in (which is insanely long), but I couldn't wait that long. Out the box, the Sony's just sounded better, and I expect they will get sound even nicer once I hit the break in period (whatever that is).
I was surprised that the Sony's bass sounded better than the CB-20's even though they have smaller woofers. That's probably due to the break-in as well.
Driv3l is offline
post #19 of 28 Old 10-26-2018, 01:12 PM
Zorba922's Avatar
Liked: 5134
The Sonys don't put out much bass, but what they do have is nice and tight. Try positioning them closer to the wall to get a little more output.
Zorba922 is offline
post #20 of 28 Old 10-26-2018, 01:15 PM - Thread Starter
Liked: 5
Thanks for the tip... I'll give that a try!
Driv3l is offline
post #21 of 28 Old 10-26-2018, 10:38 PM
djp2k7's Avatar
Quoted: 310 Post(s)
Liked: 223
I love this thread. Years ago I was searching for some bookshelves and I had the CB-20's on my list. I got RC-10's, B&W 685's, Paradigm Mini Monitor 6's, and PSB Image B6's instead. I just noticed the CB20's are only $150 now on Amazon and thought about picking up a pair but think I'll hold off now based on your experience. Might as well grab some Sony Cores lol. The vintage Mirage 360's I have are really something special though. In hindsight, I probably should have just kept the B6's or Mini Monitors and saved a lot of money!
Marantz SR5012 / Yamaha CD-S300 / XBOX One X / Sony UBX700
Dali Zensor 1 / Martin Logan Dynamo 300 / HiFiMan HE400i Headphones
djp2k7 is offline
post #22 of 28 Old 10-27-2018, 03:31 PM
Liked: 2392
If you aren't in a hurry to get speakers, I would wait about a month. I believe the past two years the Sony Core speakers have all been about half price around the end of November. Seems like I paid like $76 a pair for the CS5's near the end of last year.
Zorba922, Lp85253 and Doe Doe like this.
post #23 of 28 Old 10-27-2018, 04:36 PM
Liked: 1613
i would second that vote.. you may find other great options as well....
Lp85253 is offline
post #24 of 28 Old 10-27-2018, 05:13 PM
Liked: 1196
And a third.
I'd also recommend keeping at eye out on Polk S15/20s... I expect bargains to be found as the newer revision is coming out soon. I've already seen the S15 direct from polk at $150 and it may go lower.
Lp85253 likes this.
Doe Doe is offline
post #25 of 28 Old 10-27-2018, 07:00 PM
Liked: 1613
And a third.
x2 on the polks as well.. the elac b6.2 will be on sale as well..
Lp85253 is offline
post #26 of 28 Old 10-29-2018, 12:19 PM
ematcion's Avatar
Quoted: 171 Post(s)
Liked: 259
NHT SuperOnes less than $180.00/pair currently on Amazon
Lp85253 likes this.
Avatar - My guard dog, Bogi - RIP
Part of my ever-growing SACD collection
ematcion is offline
post #27 of 28 Old 10-29-2018, 01:04 PM
zieglj01's Avatar
Liked: 2837
Bingo!
Lp85253 likes this.
Who AM I
zieglj01 is offline
post #28 of 28 Old 10-29-2018, 03:50 PM
Liked: 1613
that's the ticket...
Lp85253 is offline
Reply Speakers
