Bookshelf speakers as atmos ceiling - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Selden Ball
post #1 of 20 Old 10-24-2018, 03:39 PM - Thread Starter
Quoted: 419 Post(s)
Liked: 46
Looking for a pair under $100 to do a 7.2.2 set up
The 2 bookselves will be the atmos speakers mounted to the ceiling pointing down. REcommendations?
Asgard1an is offline
post #2 of 20 Old 10-24-2018, 04:54 PM
zieglj01's Avatar
Quoted: 3121 Post(s)
Liked: 3043
Look at the Sound Appeal
https://www.amazon.com/Sound-Appeal-...70_&dpSrc=srch
Who AM I
zieglj01 is online now
post #3 of 20 Old 10-25-2018, 03:24 AM
Quoted: 1889 Post(s)
Liked: 1086
Aim them at the listening area not down.
Ellebob is offline
post #4 of 20 Old 10-25-2018, 08:04 AM - Thread Starter
Quoted: 419 Post(s)
Liked: 46
So for the the 7.2.2 basically use this config? Ignore the front Atmos.
post #5 of 20 Old 10-25-2018, 08:44 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2848
A 7.2.4 configuration, as shown in the picture is noticeably better than a 7.2.2 configuration, since it provides for both front-to-back and side-to-side panning of the overhead sounds.
If they're for 7.2.2 with no plans to expand to 7.2.4, then the speakers should be mounted at the Top Middle position: directly above or slightly forward of the main listening position. That'd give the best results for overhead sounds.
Top Front (~45 degrees forward) or Front Height (directly above the front main speakers) would be my next preference. This results in a front-centric soundstage, which some people prefer. I'd rate the rear overhead speaker locations last.
In all cases, the best speaker orientations tend to be with the speakers pointed toward the opposite side of the seating: Top Left pointed toward the right-most seat and Top Right pointed toward the leftmost seat. This is often called the "equal energy" orienation, with being off-axis compensating for being closer to the speaker, for example. Pointing directly down works only when the speakers have been intentionally designed to have a wide dispersion. That's not the case for standard bookshelf speakers.
Victor_S and dfa973 like this.
Selden
Selden Ball is offline
post #6 of 20 Old 10-25-2018, 03:34 PM
Liked: 1086
In the Dolby spec if you take their class like I have it says speaker needs to be aimed towards the audience. I work in this industry and I do acoustic deign as part of my job. I don't know why they show it that way on their consumer site. For in ceiling speakers I would recommend angled models if placing it 45 degrees off axis. But just in case you don't believe me here is literally the guy who wrote the book and what he is doing on his room with bookshelf speakers on the ceiling. I attached a picture of Dobly's HT Atmos demo room at the Audio Engineering Society (AES) convention. i hope this clears up their poor recommendations on their webstite as even they don't follow their webite's guidelines in their own demo room. They could have flush mounted their bookeshelf speakers aiming straight down.
https://www.avsforum.com/forum/89-sp...l#post56635046
His book's latest edition, I have all of them and they are a good read or at least better than most technically natured books
https://www.amazon.com/Sound-Reprodu...d+reproduction
For others looking at in ceiling speakers. This post was for someone wanting to use in ceiling speakers for his front speakers but the angles still apply. Look at post #5 and #7 .
https://www.avsforum.com/forum/89-sp...l#post53625065
Name:	Dolby Atmos AES Demo Room.jpg
Ellebob is offline
post #7 of 20 Old 10-27-2018, 02:46 PM
larrimore's Avatar
Quoted: 109 Post(s)
Liked: 47
Actually, that diagram looks like it is a 9.2.4 system. No receiver supports that as far as I know. 7.2.4 would eliminate the front width channels, I believe. Others can correct if I am wrong.
Sent from my SM-G960U using Tapatalk
Living the HT Dream in 4D.
4K HDR Cinema 106"@9ft w/5.4.2 Object Surround Sound and 6 Aura Bass Shakers
larrimore is offline
post #8 of 20 Old 10-27-2018, 02:47 PM
larrimore's Avatar
Quoted: 109 Post(s)
Liked: 47
Sorry, it actually looks like 9.1.4 since there is only one sub.
post #9 of 20 Old 10-27-2018, 03:58 PM
Liked: 2848
Denon's flagship receiver, the AVR-X8500W, supports having 13 simultaneously active channels (but has only 11 internal amplifiers) configured as either 9.1.4 or 7.1.6. To use all 13 of its processing channels you'd have to add at least 2 channels of external amplification. If you provide 4 channels of external amplification, it can calibrate 15 channels and later you can switch between the two different speaker configurations without changing any speaker connections.
If you're willing to spend a lot more, StormAudio has a 16 channel receiver (model I.ISP 3D.16.12 ELITE, with 12 internal amplifiers) which allows you to configure its amps in any configuration you want. To use all 16 of its processing channels you'd have to add at least 4 channels of external amplification, though.
Emotiva claims that they'll have a receiver similar to the StormAudio early next year.
Selden
post #10 of 20 Old 10-28-2018, 07:02 AM
Quoted: 77 Post(s)
Liked: 26
Not sure if using bookshelf speakers mounted to the ceiling facing down is the best option. Why don’t you install in ceiling speakers. This is the most common option. Or get a good pair of up firing speakers meant for atmos and place them on top of your front left and right.
lightsout190 is offline
post #11 of 20 Old 10-30-2018, 07:05 AM - Thread Starter
Quoted: 419 Post(s)
Liked: 46
I just don;t want to cut into the ceiling and it would be very tough to run wires. So the solution im looking for would be an 'above the drywall' install type.
Which speakers would be good for the upfiring?
post #12 of 20 Old 10-30-2018, 07:44 AM
Quoted: 77 Post(s)
Liked: 26
OK I hear you about cutting a hole in the ceiling and running wires through. In that case I would then suggest the upfiring Atmos speakers mounted on top of your left and right speakers. Here are three examples of different brands.
http://ca.kef.com/q50a
https://www.elac.com/product/debut-a4/
http://www.pioneerelectronics.ca/POC...ers/SP-T22A-LR
Now keep in mind all three of these will cost allot more than the $100 budget you have, with the KEF probably being the most expensive. But I have to be honest with you and tell you that for under $100 your are not going to get a very good bookshelf speaker either. And cheap bookshelf speakers will not be able to be used as an Atoms speaker by hanging them upside down. So your basically going to waste your money if your buying them for that purpose. Not to mention that aesthetically this is going to look awful. If I were you I would drop the second sub as it is not really necessary and for the money you save on that invest in a good pair of of Atoms speakers like the ones I provided in the link above. I am sure there are many more like this out there as well.
post #13 of 20 Old 10-30-2018, 07:59 AM
dfa973's Avatar
Quoted: 767 Post(s)
Liked: 714
I use Wharfedale Crystal 4.1 small bookshelves as on-ceiling speakers, but pointed towards the MLP, not down.
Name:	Wharfedale Crystal 4.1 black-ring.jpg
dfa973 is offline
post #14 of 20 Old 10-14-2019, 01:39 PM
Brian81's Avatar
Quoted: 16 Post(s)
Hi, I've been planning to mount bookshelf speakers for Atmos ceiling speakers. Would using center channel speakers (MTM), drivers oriented right to left parallel with seating, be a superior option?
Please excuse my attempt to portray this the following way in text
...MTM...................MTM...
......[-----SEATING-----]......
VERSUS
...MT..........................TM...
OR
...TM..........................MT...
Also, ceiling speakers best to be on the outside of seating or directly above? If using MTM center channel speakers, 'above seating' could provide more sound coverage along length of seats?
Brian81 is offline
post #15 of 20 Old 10-14-2019, 03:15 PM
WOKNROX's Avatar
Quoted: 401 Post(s)
Liked: 333
I've used the Definitive technology studiomonitor 450's and they work really good.
I recently was able to score 4 of the Sony Core 5's when they were on sale..$75 a pair... I'm running them now as Atmos speakers and really like them. The 3 way design with the super tweeter really shines over the hard dome tweeter in the Def-Tec's.
The Core 5's go on sale frequently so keep an eye out for them.
Orotund Desert Theater:14'x20'x10',100amp service, JVC RS620, 120" AT screen, Carada Masquerade Masking, OPPO-203 & Panny ub820, Anthem AVM60, Simaudio Moon Titan 7&5 channel amplifiers, ACInfinity Fans, L&R Polk SDA SRStl Fully built, CC 2 Polk RTA15tl in Custom Cabinets Fully build, SS-BS Triad Gold, 4 Atmos 3 way Core5's, Subs-1 Rythmik FV25HP & 4 HSU VTF-MK5-HP, 2 Rows of 3 Seatcraft Excalibur Lx Seats and more.
WOKNROX is offline
post #16 of 20 Old 10-14-2019, 04:40 PM
Brian81's Avatar
Quoted: 16 Post(s)
My last posting example does not appear correctly
Code:
VERSUS
OR
Perhaps this will work?
Brian81 is offline
post #17 of 20 Old 10-14-2019, 05:14 PM
WOKNROX's Avatar
Quoted: 401 Post(s)
Liked: 333
VERSUS
OR
I used to use Definitive technology clr 2500...four of them...for my Atmos speakers and man did they kick A$$!!
They are a bit heavy so you need to make good mounts.
I never would've moved away from them but you need to be able to apply double bass to make good use of their powered bass/subs. When I switched to the Anthem avm60 I lost this feature and could no longer use them.
I still have them around here somewhere....
WOKNROX is offline
post #18 of 20 Old 10-14-2019, 06:23 PM
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 156 Post(s)
Liked: 79
VERSUS
OR
MTM is a flawed design and only intended for when you need to place a speaker under a TV.
Unless you already have MTM speakers I would just use normal bookshelfs.
I ran my surrounds upside down once and couldn't tell any difference so I would try them both ways to see which sounds best if you go with bookshelfs.
niterida is offline
post #19 of 20 Old 10-14-2019, 07:08 PM
WOKNROX's Avatar
Quoted: 401 Post(s)
Liked: 333
I would agree to just use mono-poles if buying but, judging from his diagram it looks like he's going to stand them up.
If so I don't see anything wrong with that... If he's wanting to keep the arm-chair jockeys here on the forums happy...lol
To be honest I really couldn't really tell the difference between standing up an on the sides with the clr2500's.
Your pointing them @ the MLP anyways.
WOKNROX is offline
post #20 of 20 Old 10-15-2019, 02:05 PM
BlueGhost's Avatar
Quoted: 33 Post(s)
These little cube speakers from BA look like they would work for Atmos.
BlueGhost is offline
Reply Speakers
