Speakers wont play below 1000 Hz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-26-2018, 02:37 PM - Thread Starter
soccerTOOLsu's Avatar
I have a pair of FXiA6 Polk Audio. Was running REW and noticed that the pair of speakers won't play below 1000 Hz, the dB is around 80 at 1000 Hz and is down below the soundstage of 60 dB around 900 Hz.
I'm assuming the mid/woofer is done. Don't know the transition from Mid/Woofer to tweeter.
Is this something that is fixable?
I checked in the bipole and dipole configuration. Then I unplugged them and plugged in a set of T15 and it played sound in the 100 Hz to 1000 Hz range. So it is something wrong with the speakers.
Driver Complement
  • (2) 1" (2.54 cm) d (Round) Dynamic Balance silk polymer composite dome - Tweeter
  • (1) 6.5" (16.51 cm) d (Round) Dynamic Balance polymer composite cone and rubber surround - Mid/Woofer
soccerTOOLsu is offline
post #2 of 8 Old 11-26-2018, 02:50 PM
Blacklightning's Avatar
Quoted: 999 Post(s)
Liked: 856
1000hz would be a really low crossover for a 2 way speaker. I have never tested with REW a Dipole/Bipole speaker may be it's just cancellation. Can you post the graph?
Do a slow sweep and feel the woofer, is it still moving below 1000Hz?
Blacklightning is offline
post #3 of 8 Old 11-27-2018, 11:13 AM
gajCA's Avatar
Quoted: 9366 Post(s)
Liked: 6451
Driver Complement
Under warranty if they are less than 5 years old.
Call Polk.
Geoff A. J., California
gajCA is online now
post #4 of 8 Old 11-27-2018, 11:37 AM
LastButNotLeast's Avatar
Quoted: 2656 Post(s)
Liked: 2322
Test each speaker individually.
Michael
LastButNotLeast is offline
post #5 of 8 Old 11-27-2018, 11:54 AM
impreza276's Avatar
Quoted: 511 Post(s)
Liked: 778
In this case 1000Hz is probably well below the crossover point but still audible.
impreza276 is online now
post #6 of 8 Old 11-27-2018, 12:01 PM
Jawaburger's Avatar
Quoted: 214 Post(s)
Liked: 210
Have you tried hooking the speakers up to a source and playing music or something through them? Perhaps you have a setting in REW that is limiting the frequency?
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | Phase Tech PC 9.1 (FL/FR) | Phase Tech PC 3.1 (C/SL/SR) | Dual PSA S1811 Subs
Jawaburger is offline
post #7 of 8 Old 11-27-2018, 01:27 PM - Thread Starter
No, I put a different speaker in and it played full frequency from 100 Hz to 20,000 Hz. So hot swapping speakers allows me to play below 1000 Hz.
Did not change a single setting in REW, Computer, or AVR. For sure issue is limited to Speaker only.
post #8 of 8 Old 11-27-2018, 01:29 PM - Thread Starter
I think the cross over would be in the 1800 Hz to 2300 Hz range. For midwoofer to twitter.
Reply Speakers
