Splitting Kef Q150 as single rear + center - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Ofir Kris
post #1 of 13 Old 12-04-2018, 07:14 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 9
My current plan for living room is
2X KEF Q150 - Front speaker
1X KEF Q150 - Center
1X KEF Q150 - Single Rear speaker mounted close to ceiling
4X KEF Ci50R - in Ceiling (Drywall)
This is going to be my first setup, trying to stay under budget (all speakers were under ~40% black friday discount) Is this setup Ok?
What would you do differently here? (Should I use a real center speaker, and use 2Xq150's as rear's instead?)
Ofir Kris is offline
post #2 of 13 Old 12-04-2018, 09:42 AM
Zorba922's Avatar
Quoted: 7149 Post(s)
Liked: 5459
Try the single Q150 as center first and see if it's enough for you. If not, move it to surround duty with the other one, and get a proven performer horizontal center in the $250-350 range (unless you want to get raped for a $650 KEF center just for the sake of the "timbre matching" unicorn).
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 13 Old 12-04-2018, 10:42 AM
Quoted: 543 Post(s)
Liked: 302
Try setting it up as a phantom center first, KEF imaging is superb so it may work out great.
Speakers: KEF Q100, Q300, Q750, Q650C / Fluance Signature Series Bookshelf, SX6, XL5F/ Mirage M-190 / DCM TP160S-CH Subwoofers: Outlaw Ultra X12 (x2) / BIC H100-II
Receiver: Denon AVR-X4500H, AVR-X1400H Integrated Amplifier: Yamaha A-S501/ Fosi Audio TPA3116 mini amp Extras: MiniDSP Umik-1 Amplifier: Emotiva BasX-A300
macgallant is offline
post #4 of 13 Old 12-04-2018, 11:15 AM
pase22's Avatar
Quoted: 3339 Post(s)
Liked: 2808
While the Q650c is a little expensive it is a very good speaker, it adds dynamics and gives you a fuller sound. You'll get very clear and detailed sound and dialogue. A single Q150 will work well as a center by providing clear dialogue, but won't have the fullness of sound you'd get with the larger 3 way center. I'm not sure how a single Q150 would work as a surround speaker since it's something I've never considered trying, though I think having L&R surrounds might sound better.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #5 of 13 Old 12-04-2018, 02:51 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 9
@Zorba922 Thanks I'm going to give it a try first,
I can arrange an old 2nd hand Q200c Do you think it should perform better vs the (newer) Q150 as a Center?
Also, I have a very old "Wharfedale Topaz WH-10" Sub that is just sitting in the basement (it has some annoying humming sound), Do you think it will match the other speakers in my setup? or should I modernize to a newer Sub?
post #6 of 13 Old 12-04-2018, 03:13 PM
Zorba922's Avatar
Liked: 5459
No idea, just try both and see which one you prefer.
The Wharfedale sub is better than nothing, but if HT is your main focus not music, then I would plan to upgrade it sooner rather than later.
Zorba922 is offline
post #7 of 13 Old 12-04-2018, 06:52 PM
Quoted: 270 Post(s)
Liked: 265
It might actually be a good thing for you. I received my q150s yesterday and have been running q100s x 5 in my setup for the last year. It is a bit early for me to give any definitive judgement of them, but I can already attest to what others have stated in that the mids are definitely more recessed than the q100s. The older q200 center might actually be a good thing for dialog clarity with the more forward mids......not that the q150s lack clarity, but more as a comparison of the two models. If I keep my q150s I will still be using q100s in the center and surround positions.
D33vious is online now
post #8 of 13 Old 12-05-2018, 06:38 AM
Quoted: 543 Post(s)
Liked: 302
how much for the Q200c, could you demo it with the Q150's first?
post #9 of 13 Old 12-05-2018, 09:39 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 9
2nd hand Q200 - $350
new Q150 pair - $300
I think i'll take the pair, and use one single as rear
sdg4vfx likes this.
post #10 of 13 Old 12-05-2018, 09:55 AM
Quoted: 270 Post(s)
Liked: 265
That's not a bad price for the q200c.
post #11 of 13 Old 12-05-2018, 10:53 AM
Endlesscc's Avatar
Quoted: 371 Post(s)
Liked: 68
A year ago I spent $450cad on the Q650c so no I am sure they are almost the same price or cheaper these day?
KEF Q750, Q650c, Kube 12B, Denon AVR-X3400H, Sony XBR75x900e, PS4 Pro
Endlesscc is offline
post #12 of 13 Old 12-05-2018, 11:43 AM
Quoted: 543 Post(s)
Liked: 302
IMO I don't find the Q650C that overpriced (it's been exaggerated imo).It's literally a Q750 Tower($750 each) with 1 less bass radiator and this is also reflected in the price ->$650.
with that being said i always see the Q650C on sale and I grabbed mine for $600 CDN taxes in ($450 US).
note: the Q650C needs decent power to shine, it's not the easiest speaker to drive. My AVR-X1400H does a very poor job driving the Q650C.
I tested my Q650C with my Yamaha a-s501(setup mono) and it brought out all the dynamics that was missing through the X1400H.
my next step is to get an AVR with pre-outs and few amplifiers.
post #13 of 13 Old 12-06-2018, 01:01 PM
sdg4vfx's Avatar
Quoted: 243 Post(s)
Liked: 201
FWIW ...
I ran a 6.1 setup (5.1 plus a single "back" speaker) using Q100's for several year and liked it very much. Most 7.1+ AVR's handle 6.1 fine but it's worth double checking first.
I used a Q100 as my center and it was great - but I've always favored a more cohesive/unified front stage sound.
My neighbors all listen to great music. Whether they like it or not.
sdg4vfx is offline
Reply Speakers
