Def tech cs 9040/9060 vs klipsch RP440c - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eja35oz
post #1 of 10 Old 12-06-2018, 04:41 PM - Thread Starter
Liked: 3
Need some help on which is the better speaker. Beginning to upgrade my current 5.1 def tech pro 800 setup and I'm starting with the center. I purchased the Yamaha rx v683 for my receiver and svs prime elevation for my atmos front heights. Should I stick with def tech for my upgrade or try klipsch reference premier line? Set up is for 90% movie watching 10% music. I get a different answer from all the "experts" in the magnolia section at best buy. I've only been able to hear def tech. Klipsch demo was not available. So I'm curious what you guys think who have heard both? Thanks
eja35oz is offline
post #2 of 10 Old 12-06-2018, 05:26 PM
Kini62's Avatar
Quoted: 2681 Post(s)
Liked: 2470
Either would work. Are you limited to best buy? The emotiva C1 gets rave reviews and is quite a bit less expensive and is available from Amazon for $349.
If you're limited to BB get one DefTech and the 440 and return the one you like least.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is online now
post #3 of 10 Old 12-06-2018, 06:35 PM
Zorba922's Avatar
Quoted: 6919 Post(s)
Liked: 5209
You mean $249 if US Amazon.
Amazon.ca has it for $335CAD.
@eja35oz - there's a whole world out there beyond Best Buy, I suggest exploring.
$369 gets you the C2, but not off Amazon:
https://emotiva.com/collections/loud...ts/airmotiv-c2
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 10 Old 12-06-2018, 06:53 PM - Thread Starter
Liked: 3
@Kini62 no not limited at all. Was actually going to order from Amazon anyways. Just like that I can demo them there. Best buy would price match Amazon though if I did go that route
eja35oz is offline
post #5 of 10 Old 12-06-2018, 07:17 PM - Thread Starter
Liked: 3
@Kini62 also the emotiva is too tall. I need something less than 7 inches in height.
eja35oz is offline
post #6 of 10 Old 12-06-2018, 07:46 PM
golden78's Avatar
Quoted: 403 Post(s)
Liked: 131
I hd the deftech center and i liked it. But If limited by height but not width also look at the GoldenEar supercenter xl only problem is unless find used one have get it from a local dealer they don't ship.
golden78 is offline
post #7 of 10 Old 12-07-2018, 09:37 AM
gajCA's Avatar
Quoted: 8580 Post(s)
Liked: 5781
The general consensus is the for Atmos you really want front firing speakers and going the DefTec 9000 series route, which has many fans on AVS, not only deviates from the Atmos "standard" but forces you into powered towers if you want towers or very expensive bookshelves if you choose to go with passive bookshelves.
Amps fail before passive speakers do which is why many shy away from powered towers.
I guess that's a long winded way of saying try the Klipsch first.
Geoff A. J., California
gajCA is offline
post #8 of 10 Old 12-07-2018, 05:04 PM - Thread Starter
Liked: 3
@gajCA ya I decided on klipsch. But I'm going with SVS prime elevation for my height atmos speakers
gajCA likes this.
eja35oz is offline
post #9 of 10 Old 12-08-2018, 02:54 AM
Justin Andrew Parks's Avatar
Quoted: 60 Post(s)
Liked: 38
Good choice with the Klipsch.
Receiver: Marantz 5012 Power: Emotiva XPA-5 Gen 1
Towers: Klipsch RF83 Center: Klipsch RP450C
Surrounds: Klipsch RS42II
Subs: Dual Rythmik FV15HP
Justin Andrew Parks is offline
post #10 of 10 Old 12-08-2018, 10:20 AM
gajCA's Avatar
Liked: 5781
Looking forward to your impressions.
You could also use some RP400ms with wall mounts but they don't come in White which I'm guessing is the color you'll get the Elevations in.
gajCA is offline
Reply Speakers
