AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   LCR speaker under $1300 (https://www.avsforum.com/forum/89-speakers/3038584-lcr-speaker-under-1300-a.html)
sunnybhaku 12-28-2018 05:42 PM
any good recommendation for LCR Speaker under $1300 and most of the time I watch 90% movies (movies and Netflix) and 10% songs. the receiver I' using Denon x3400h for Elac uni fi ub5 and uc5 centre speaker but every time I set volume to watch movies I have to set above 70. I'm planning to return back those speaker and if any one has any recommendation that throws good neutral, clear sound be good and the room dimension is 14*20 with 8 ft ceiling. Gonna add svs sub later in the future.
Russdawg1 12-28-2018 05:49 PM
What’s your problem with setting the volume at 70?
And I’m going to recommend T2 towers with the C2 center from Emotiva. Going to be quite hard to beat at the price.
If not, A5.4 towers with the A2.4 center by Chane would be my next pick.
Lp85253 12-28-2018 05:49 PM
nht c3 x 3 if you have the room for 3 bookshelf speakers in the front...
Lp85253 12-28-2018 05:50 PM
i'm listening to my emo's right now..your right t2 +c2 all the way...
sunnybhaku 12-28-2018 06:04 PM
at 70 eve though doesn't seem like it fills the room
pase22 12-28-2018 06:07 PM
How far back are you sitting that you need to turn it up so much? Also make sure your source volume level is turned all the way up.
sunnybhaku 12-28-2018 06:07 PM
any recommendation wit bookshelves speaker instead tower speaker
thanks
Russdawg1 12-28-2018 06:08 PM
I’m in a situation similar to you. I have an Onkyo rated for 100 watts. I find my self pushing 70, 80’s when I’m having a little fun, but it has crossed my mind that maybe there’s something wrong with the amp. But then I reassure myself that there can’t possibly be something wrong with the amp. However you are in a different situation. If I remember correctly, those Uni-if’s aren’t as inefficient as some. So I think there’s nothing wrong with yours, simply you need a better amp. Changing the speakers will work but if you like the way they sound, getting something with more power like an Emotiva amplifier would be good.
Russdawg1 12-28-2018 06:10 PM
thanks
Chane A2.4’s as LCR or Ascend CMT340’s would work. They are MTM’s so they can be used as centers and L/R. The Ascends are EXTREMELY neutral, I have them myself. They aren’t for everyone. Where did you think your Uni-fi’s fell on the scale. I want to make sure your view of neural is correct.
sunnybhaku 12-28-2018 06:16 PM
its 12 feet and it was on 0db and just changed to 8 I hope it make little difference but won't
sunnybhaku 12-28-2018 06:17 PM
I like the sound but it seems like need little bigger centre speaker to fill the room
Russdawg1 12-28-2018 06:20 PM
Well when you get a subwoofer, it will get louder in general so maybe try one from Best Buy since they have free returns and see if it provides the improvement you seek. But the Uni-Fi’s are quite quality speakers and many of the owners recommend external power amps to make them sound their best and you seem like a prime candidate to get one.
sunnybhaku 12-28-2018 06:21 PM
the only thing I like about these speaker is they sound clear and tweeter are not scratchy. so your ears won't get tired even though after watching for long time.
Russdawg1 12-28-2018 06:22 PM
Completely agree, it’s a great characteristic, all the more reason to keep them.
Lp85253 12-28-2018 06:26 PM
thanks
emotiva b1 or chane a 1.4 or for a larger space chane a2.4...
sunnybhaku 12-28-2018 06:26 PM
how you like your cmt 340 does it good enough to fill medium size room and how the tweeter on it
murphy_5 12-28-2018 06:27 PM
I really like the Infinity Reference line at this pricing! On sale for a few more days. Could build a whole LCR and get two subs for under 1300 right now!
https://www.harmanaudio.com/speakers/#prefn1=brand&prefn2=isRefurbished&prefv3=false&sr ule=popularity&prefv1=Infinity&prefv2=false&prefn3 =isSupport
sunnybhaku 12-28-2018 06:29 PM
https://www.harmanaudio.com/speakers...efn3=isSupport
thanks a lot
murphy_5 12-28-2018 06:29 PM
A review from sound and vision.
https://www.soundandvision.com/content/infinity-reference-r162-speaker-system
pase22 12-28-2018 06:31 PM
It appears you need more efficient and easier to drive speakers. Klipsch RP-160's and matching center would be good candidates for your usage and listening habits. A good sub would certainly make a big difference as it would add more depth and also relieve both your speakers and AVR giving you more head room.
Russdawg1 12-28-2018 06:32 PM
They are really neutral and hold their composure really well when you start nearing Reference volume and even when passing Reference volume they sound fantastic. Extremely dynamic with the dual 6.5” polygel woofers, proprietary to Ascend. The tweeter is extremely detailed but it is VERY revealing. Poorly recorded or overmixed content sounds terrible because they bring light to every tiny detail in the sound but good recordings are where the Ascends shine. Live content or Vinyl make them sound amazing.
sunnybhaku 12-28-2018 06:34 PM
what your opinion with svs ultra centre with prime bookshelves speaker or Ascend CMT340
Russdawg1 12-28-2018 06:39 PM
SVS primes are really bright. You will not like them. Ascend’s will blow them out the water in terms of sound quality too. The Ultra Series is eh. You could do better for the money IMO. I don’t like SVS because I believe they are overpriced. Just my
opinion.
sunnybhaku 12-28-2018 06:40 PM
the only thing I curious that their tweeter won't be too scratchy and that the only reason make me not to buy Klipsch
Russdawg1 12-28-2018 06:43 PM
The Reference series is quite bright. The RP line toned it down quite a bit. Stop by your nearest Best Buy and have a listen. Try out Kef and Martin Logan too while you’re at it. If you like ML, then you’ll love Emotiva.
sunnybhaku 12-28-2018 06:47 PM
opinion.
I read good review about ascend 340se as LCR and personally how you like the sound for action movies
other speaker I like the Chane a2.4 as LCR but don't know How It sounds as it says made in china and don't know their quality and return policy dent sound good
sunnybhaku 12-28-2018 06:49 PM
thanks a lot and now days so many different brands and some time take to much time to decide
Russdawg1 12-28-2018 06:57 PM
The Chanes are supposed to be even better than the Ascends. Surprising, I know. They have production runs seasonally and sell out super quick and for good reason.
I don’t really watch action movies or any movies at all with the Ascends but they tackle any genre of music with ease. I’m sure movies would be no challenge either.
sunnybhaku 12-28-2018 07:02 PM
don't planning to buy sub now but I'll try for trial how it sounds with sub
sunnybhaku 12-28-2018 07:08 PM
personally like ascends and the only reason I feel hesitate is their return policy
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
