banana plugs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-04-2019, 07:48 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 4
banana plugs
so i just got some monster banana plugs not the deadlock ones the normal.
and it have 1 screw that is for the cable but you can also undscrew the base of the plug? what is that good for?
am i just suposed to put the screw in to connect the speaker wire or what function does it have to be able to unscrew the base of it?
https://www.ebay.com/itm/24PCS-Gold-...zZA9:rk:7:pf:0
vampyiere6 is offline
post #2 of 5 Old 01-04-2019, 07:59 AM
Bill-99's Avatar
Quoted: 853 Post(s)
Liked: 530
It's hard to tell for sure from the pic, but it looks like this to me:
1) Unscrew the base of the plug. Slide that part onto the cable wire with the screw toward the exposed wires.
2) Loosen the screw in the gold plated connector. Slide your cable into that, and then tighten the screw to hold the wire in place.
3) Slide the base of the plug up to the gold plated connector and screw it on.
Looks like that should be all you need to do, but again, it's hard to tell from the pics.
Just one more upgrade and things will be perfect.
Bill-99 is online now
post #3 of 5 Old 01-04-2019, 08:52 AM
Blacklightning's Avatar
Quoted: 998 Post(s)
Liked: 855
Does not show in the video but my guess is that it helps to clamp down on the cable sleeve for thick cables.
Blacklightning is offline
post #4 of 5 Old 01-04-2019, 10:35 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 4
https://youtu.be/HphbTOHtH8o?t=218
Yea i did watch the video and most others i found but noone shows this kind of plugs as i cant see any use for it but could be for thick cables maybe thats the only thing i could think of too
post #5 of 5 Old 01-05-2019, 07:54 AM
Jonas2's Avatar
Quoted: 2835 Post(s)
Liked: 1805
Yep, that's what it's for, and if it can grip the insulation effectively, it'll help to prevent any unneeded twisting of the conductors that might otherwise occur during manipulation. Or so is my theory....
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
Reply Speakers
