Speaker selection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-05-2019, 11:48 AM - Thread Starter
Liked: 0
Question Speaker selection
I'm looking for suggestions on a good set of wall mountable front speakers that I can mount above french doors that are in way. I would rather have floor standing speakers, but french doors would hit one of them when opened unless it 7" or less. I plan to use an Onkyo TX-NR676 receiver. I will also be needing the surround, rear and, a sub woofer so I'll take any suggestions I can get with those as well, but my immediate issue is the front speakers.
Thanks in advance for any help.
Andy Mayfield is offline
post #2 of 13 Old 01-05-2019, 12:09 PM
Quoted: 1738 Post(s)
Liked: 1338
Can we get a picture? And what is your budget? Most speakers can be easily wall mounted but HTD L3’s come to mind when you want a solid wall mounted speaker. They are front ported so they can be put directly against the wall.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #3 of 13 Old 01-05-2019, 12:14 PM
Quoted: 464 Post(s)
Liked: 408
I don't suppose 7.5" would work? These Canton's are pretty thin
https://www.accessories4less.com/mak...specifications
If wall mounts needed, HTD has some good ones and can get different cloth sock colors to match decor..
https://www.htd.com/Products/Speaker...binet-Speakers
cocrh is online now
post #4 of 13 Old 01-05-2019, 12:30 PM
Quoted: 464 Post(s)
Liked: 408
How about center channel? Would you need a wall mount there too or would a standard center channel speaker work?
cocrh is online now
post #5 of 13 Old 01-05-2019, 02:27 PM
head_unit's Avatar
Quoted: 574 Post(s)
Liked: 306
7" wide?
Yeah, what @Russdawg said! And of the rest of the room, to see where surrounds could be fitted.
Would you be open to kit/DIY? Because a tower with a pair of 6.5" could certainly be built carefully to 7" wide. Or certainly 2x5". On the premade front, you can sure find 7" wide towers. These
https://www.monitoraudio.com/en/prod...er/silver-200/
should sound as excellent at $1500 as their 300 big brothers I spent several hours listening to at Upscale Audio, albeit with somewhat less bass. Or these https://www.elac.com/product/uni-fi-fs-u5-slim/?r=us
These Polks cost considerably less but are 7.5" hence pictures and very careful measurements are indicated.
https://www.crutchfield.com/p_107SIG...ck-Walnut.html
I aesthetically prefer towers to bookshelf speakers on stands because very very very few stands are attractive at all. I'm also skeptical about wall-mount, unless maybe you can work in some small shelves that actually match your decor. Otherwise you just have ugly boxes stuck on your wall, which may be OK in your local darkened multiplex, but is bleh in your living room.
Towers also have an advantage in that you can start your system without a subwoofer. Speakers last a VERY long time, and you do get better speakers as you spend more money, so it is best to get go bit-by-bit getting the best you can at each stage.
head_unit is offline
post #6 of 13 Old 01-05-2019, 02:31 PM
Liked: 1338
Originally Posted by head_unit View Post
7" wide?
Wrong Russdawg, but thanks for agreeing with me
post #7 of 13 Old 01-05-2019, 03:32 PM
Quoted: 555 Post(s)
Liked: 291
deftech mythos 9 or 10 or maybe a Goldenear supersat. Ascend acoustics Sierra Luna or RSL CG23
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #8 of 13 Old 01-12-2019, 04:53 PM - Thread Starter
Liked: 0
7" wide?
7" deep. If they stand off the wall more than that, a french door would be hitting the right speaker all the time. I will try to get some pictures and post them. I will have to figure out how to do that since I've never posted a picture here.
post #9 of 13 Old 01-12-2019, 05:01 PM - Thread Starter
Liked: 0
I'm going to have to install the center channel on the ceiling. The TV takes all the wall space between the top of the mantle and the ceiling.
post #10 of 13 Old 01-12-2019, 05:10 PM
head_unit's Avatar
Quoted: 574 Post(s)
Liked: 306
Oh! I thought they had to be skinny so the door wouldn't hit them. If 7" DEEP, then how wide can they be? That's a LOT tougher-designers usually want speakers to look skinny, so to get more cabinet volume they tend to be deeper than their width. True for bookshelves also. That makes me think you may need DIY...well, or those real skinny speakers, though generally they are just not going to have the same kind of performance. In-wall?
Hey, this is kind of funny, there is an ad for RSL Speakers on this page, showing their "center channel" (which is perfectly suitable for L/R). Small woofers (albeit two), would need a sub, but they have been well reviewed.
https://rslspeakers.com/cg3-overview/
post #11 of 13 Old 01-13-2019, 05:47 AM
Dawn Gordon's Avatar
Quoted: 422 Post(s)
Liked: 254
I'm going to suggest the Triad InCeiling Bronze/8 LCR for all three of your front speakers. Thanks to their 45 degree angle design, Triad's InCeiling LCRs will project the sound down to the listener, and the sound will seem like it's coming directly from the TV.
https://www.triadspeakers.com/produc...c-bronze8-lcr/
They also have a Bronze on-wall model that's about 4" deep: https://www.triadspeakers.com/produc...ow-bronze-lcr/
We use Triad speakers almost exclusively. Triad is a Portland-based company that hand builds speakers in just about every configuration you can imagine. They will even color match the speakers and grills to match the paint on your walls. The company has speakers in many different price ranges, starting at $300 per speaker - all the way up to $15k per speaker.
While not a household name, Triad is a favorite of custom installers and has won numerous industry awards.
________________________________________
[email protected]
Dawn Gordon is offline
post #12 of 13 Old 01-13-2019, 09:45 AM - Thread Starter
Liked: 0
I'm sorry, you were right. I don't know what I was thinking. It would be the width and not the depth.
post #13 of 13 Old 01-13-2019, 04:45 PM - Thread Starter
Liked: 0
7" wide?
Hopefully this works.... I haven't posted pictures here before. The arrows I put on the pictures are where the prewire is located. I like those Triads you mentioned, but I've been scared of ceiling mounted speakers.
Name:	Front Speaker Locations.jpg
ID:	2510382   Click image for larger version
Name:	Left Right Speakers.jpg
ID:	2510384   Click image for larger version
Name:	Rear Speaker Locations.jpg
Reply Speakers
