Eosone RSF1000 sub replacement suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-16-2019, 11:44 AM - Thread Starter
Liked: 0
I have Eosone RSF1000 Towers in the 10-inch Subs are wearing out. The foam surround is getting bad and quite honestly they never had good authority. I would like to replace the subs and the amplifiers if possible. Any suggestions would be fantastic.
Sent from my SM-G920P using Tapatalk
knever3 is offline
post #2 of 9 Old 01-16-2019, 11:49 AM
sivadselim's Avatar
Quoted: 430 Post(s)
Liked: 381
No suggestions but great speakers in their day.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #3 of 9 Old 01-16-2019, 11:50 AM
Quoted: 1419 Post(s)
Liked: 990
I’d check out parts Express.
They have plenty of plate amplifiers and they have lots of 10” woofers. If you would like to go cheap, GRS 10” subwoofers are $20 a piece. They are quite good for the money. On the other side, you could go a little more expensive and get Dayton Audio’s Reference 10” which are closer to $100. They have woofers for basically anything you need. If you can take the current woofers out and measure the impedance that would be great so we can find the correct match for you. Also what is the F3 of the Towers? (-3 dB point)
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #4 of 9 Old 01-16-2019, 12:01 PM
sivadselim's Avatar
Quoted: 430 Post(s)
Liked: 381
As for the sub sections never having "good authority", perhaps there is something else wrong with them or they are not connected/configured correctly. I don't know how low they might have gone but my recollection of them is that they were quite capable over the range of frequencies that they DID cover.
post #5 of 9 Old 01-16-2019, 01:09 PM - Thread Starter
Liked: 0
I have no idea what the f3 is and wouldn't know how to test that. They look like 4 ohm impedance, I measured three of them and all three came out at 3.2 or 3.3 ohms.
knever3 is offline
post #6 of 9 Old 05-07-2019, 07:32 AM
Quoted: 79 Post(s)
Liked: 85
My experience with them has been that they are best used with the high-level inputs to give the towers a fuller range, as opposed to using them as a separate subwoofer channel. They sound good, but not what you would think 4 10's would sound like.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is offline
post #7 of 9 Old 05-07-2019, 07:39 AM
Quoted: 79 Post(s)
Liked: 85
@knever3 did you ever get anywhere with this project?
DIY 110" AT Screen
post #8 of 9 Old 05-07-2019, 07:43 AM
Quoted: 79 Post(s)
Liked: 85
@Russdawg1 is it possible to measure F3 with a working cabinet? I'm happy to take any measurements. I have UMIK-1 and REW but I'm a novice at these things.
DIY 110" AT Screen
post #9 of 9 Old 05-08-2019, 04:43 PM
Liked: 0
@Russdawg1 , reg. f228be, being a newbie, cannot pm you. can you email me - userkv(at)gmail(dot)com
userkv is offline
Reply Speakers
