Pairing Center with Polk Monitor 60s - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-06-2019, 09:09 AM - Thread Starter
Master Ice's Avatar
I know that Polk Monitor 60s are somewhat dated, but I just put them back into service in our loft after being in storage for a while. Started watching Netflix/Prime Video and really noticed the missing center channel in dialogue. What would you guys recommend for a new center channel speaker in 2019?
Here are a couple that I started considering...
Polk TSi-CS10
https://www.crutchfield.com/S-mQ3TPT...S10-Black.html
Definitive Technology ProCenter 1000
https://www.bestbuy.com/site/definit...lack/7656413.p
Thanks in advance!
Master Ice is offline
post #2 of 4 Old 02-06-2019, 09:31 AM
Quoted: 375 Post(s)
Liked: 313
Not sure your budget but if you can afford a 3 way center like the LSiM 704c it would be great for you setup.
https://www.adorama.com/pkalsim704c....ce=rflaid62905
cocrh is online now
post #3 of 4 Old 02-06-2019, 09:55 AM
yepimonfire's Avatar
Quoted: 77 Post(s)
Liked: 64
The new series ii monitors would be the best choice, the lsim may be nicer, but it won't match in timbre. The cs20 should do nicely.
Sent from my moto e5 play using Tapatalk
yepimonfire is offline
post #4 of 4 Old 02-06-2019, 09:59 AM
m0j0's Avatar
Quoted: 472 Post(s)
Liked: 387
I had the Monitor 60's up until a few months ago and was using a Polk T30 with them. I thought the sound matched very well and you can pick it up for around 100 dollars (about 90 on eBay and maybe a bit more elsewhere).
m0j0 is online now
Reply Speakers
