DefTech BP7000sc knocking sound from sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-12-2019, 03:25 PM - Thread Starter
mike iuro's Avatar
Quoted: 16 Post(s)
Hey guys,
bad news for me, my DT started a knocking sound on heavy bass parts....At first I thought it was an imperfection in the source material. I was watching a movie on cable. I soon realized it was my sub.
It was making a knocking sound and then it would cut out.....with no source material I could tap the back of the speaker and tell the power was trying to cut in/out, but the knock noise was the giveaway to something being amiss.
Never had any trouble with these speakers at all. Doing a little research on knocking noises from subs I've read something about "spider webbing" coming loose behind the sub as a possible culprit.
I did pull the cover off and didn't note any visual damage to the outside of the sub speaker.
I have no idea how to pop this thing open for further exam and am a noob at technical diagnostics.
Any advice or ideas?
What should I do?
Thanks guys
mike iuro is offline
post #2 of 4 Old 03-12-2019, 03:34 PM
keeper's Avatar
Quoted: 626 Post(s)
Liked: 258
Hello, I have these too and have taken them apart a few times. What I would do is unscrew the amp and take it out as much as you can. Then play the speaker and see if you can locate the part that is making that noise. Be careful.
Also, could it be port noise from having the amp up high?
keeper is offline
post #3 of 4 Old 03-13-2019, 08:19 AM - Thread Starter
mike iuro's Avatar
Quoted: 16 Post(s)
No, the amp wasn't up too high.
Is there anyplace in chicagoland that services these amps?
post #4 of 4 Old 03-13-2019, 08:52 AM - Thread Starter
mike iuro's Avatar
Quoted: 16 Post(s)
Oops, I mean speakers.
Reply Speakers
