Daily TV/Music Bookshelf/Amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-31-2019, 07:13 AM - Thread Starter
sub23's Avatar
I'm looking to change my sound system in my living room that I use for every day TV/Music. I currently have Logitech Z623 that does not work anymore. They did the job for everyday use but i'm looking for better quality. I currently have a Polk PSW125 subwoofer that takes dust. Do you have any recommendation for an amp / bookshelf speaker combo or powered Bookshelf . 200$ CAD Budget. (maybe a used setup ?) I already have a 5.1 HT in my basement for movies.
Room is 12'x30' (Open area with kitchen). Listening position at 10'
sub23 is offline
post #2 of 3 Old 03-31-2019, 10:09 AM
gajCA's Avatar
Quoted: 8597 Post(s)
Liked: 5795
This lacks a subwoofer out but you can just send a second speaker wire from the left speaker outputs to your subwoofer using the speaker wire inputs on the sub and see if that works well enough for you.
Canadian made but not sure of the CAD price but nothing else, new, that you will find in Canada is as inexpensive.
https://www.fluance.com/powered-2-0-...peakers-bamboo
Geoff A. J., California
gajCA is offline
post #3 of 3 Old 03-31-2019, 10:10 AM
callas01's Avatar
Quoted: 1361 Post(s)
Liked: 905
Maybe see what you can find from Paradigm or PSB.
callas01 is offline
Reply Speakers
