Cheaper version of SVS elevation speakers? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By gajCA
  • 1 Post By bobknavs
  • 1 Post By gajCA
  • 1 Post By m0j0
post #1 of 13 Old 04-06-2019, 01:35 PM - Thread Starter
whiteboy714's Avatar
Quoted: 619 Post(s)
Liked: 162
Trying to get the wife to agree to some height speakers. They need to be like the SVS elevation speakers. They will be up above the tv, so need to be angled down. I can't do overhead in my room.
But for the setup I have $500 for some atmos speakers is way high. Looking around for the same form factor but maybe half the price? I see a lot of upfiring and ceiling speakers when searching for atmos related.
whiteboy714 is online now
post #2 of 13 Old 04-06-2019, 01:52 PM
Quoted: 16 Post(s)
Liked: 5
You have probably seen the Klipsh RP-140sa and since they are made to upfire and have the recessed tweeter to kind of shoot up they may work because they will be further away above the tv instead of the optimal spot past the front 3. High up upside down bouncing might even work better or at least worth testing depending on the main listening distance.
Stephen Dohring is offline
post #3 of 13 Old 04-06-2019, 02:17 PM
gajCA's Avatar
Quoted: 8401 Post(s)
Liked: 5605
In truth any bookshelf speaker on a wall mount that can be angled down would work just fine.
Two of these for $160/pair for example; they even have a bigger woofer than the SVS Elevations.
https://www.accessories4less.com/mak...te-each/1.html
sdg4vfx likes this.
Geoff A. J., California
gajCA is online now
post #4 of 13 Old 04-06-2019, 03:02 PM - Thread Starter
Quoted: 619 Post(s)
Liked: 162
Oh I thought those were only upfiring but I see they can also go on the wall thanks.
Yeah I guess I just need to look at a wider range of speakers. If that is the case I need to figure out how to get a couple bookshelves I have up on a pole or something to test out if its even worth the hassle.
post #5 of 13 Old 04-06-2019, 07:45 PM
bobknavs's Avatar
Quoted: 2042 Post(s)
Liked: 1431
How many speakers do you want for that $500 budget? (2 or 4?)
NHT Superone 2.1 speakers can be had for $100 each at Amazon. Superzero 2.1, about $63. I haven't heard them, but they seem to be well-regarded. You'll need to budget for mounts, though. Maybe OmniMount 10.0 or the VideoSecu equivalent.
Lp85253 likes this.
bobknavs is online now
post #6 of 13 Old 04-06-2019, 08:52 PM
fr8flyr's Avatar
Quoted: 31 Post(s)
Liked: 50
Get some small bookshelf speakers a mount them on adjustable brackets, so they can be aimed at the MLP. The little Polk T15 speakers would do a good job fairly inexpensively. I was going to do this setup until I decided to go ahead and use in-ceiling speakers in my room.
Earl
fr8flyr is offline
post #7 of 13 Old 04-07-2019, 09:13 AM
gajCA's Avatar
Liked: 5605
Most folks say 5.1.4 is well worth the hassle but 5.1.2 less so.
Maybe tall ladders?
sdg4vfx likes this.
gajCA is online now
post #8 of 13 Old 04-07-2019, 09:23 AM
m0j0's Avatar
Quoted: 420 Post(s)
Liked: 321
You can get Focal Sibs for about 100 each sometimes. Very versatile from a mounting perspective.
sdg4vfx likes this.
m0j0 is online now
post #9 of 13 Old 04-07-2019, 02:13 PM
bobknavs's Avatar
Liked: 1431
I considered these before, but I have the impression that their built-in base does not offer a continuous range in tilt, but just a couple of discrete positions. Is that correct?
post #10 of 13 Old 04-07-2019, 02:22 PM - Thread Starter
Quoted: 619 Post(s)
Liked: 162
Maybe tall ladders?
Yeah thats what I am thinking, would hate to mount and then not really appreciate the added sound. I don't really have anything around the house tall enough.
post #11 of 13 Old 04-07-2019, 02:23 PM
gajCA's Avatar
Liked: 5605
@doedoe uses them for surrounds I think and he may be able to answer and I know a couple of AVS members used them for Atmos on wall.
If you look at the photo here a couple of them are tilted quite far back.
https://www.crutchfield.com/S-lXrNVV...ack-Black.html
Here's one mounted on the wall "backwards.'
Can't link the photo so go the link and go to the fourth photo.
http://audioconcept.com.ar/productos...-sib-cub3-5-1/
gajCA is online now
post #12 of 13 Old 04-07-2019, 02:28 PM
gajCA's Avatar
Liked: 5605
Drive around the neighborhood and find 4 tall 14 year olds playing basketball and offer them $20 each to be temporary stands for 20 minutes.
But call their parents first to avoid being arrested!
Or buy 4 8 foot ladders at Home Depot and then return them.
gajCA is online now
post #13 of 13 Old 04-07-2019, 07:17 PM
bobknavs's Avatar
Liked: 1431
(snip)
Maybe it's because they're in the Southern hemisphere. (Argentina.)
Reply Speakers
