Need help putting together a wonderful system - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #61 of 68 Old 04-15-2019, 10:22 AM
BluesDaddy56's Avatar
Quoted: 536 Post(s)
Liked: 722
Originally Posted by Ironshiekh123 View Post
So I did some research on Monoprice to find “equivalent” items. Please take a look at these along with the details, length and quantity for my 5 speakers, 2 subwoofers and the receiver. The setup will consist of integration with the OLED77C8P. I’m going to return all Amazon items except the media bridge one (the equivalent cable type is showing as OOS but I’ll include the link so you can double check). I’m going to be doing this for the first time so I’d rather be safe than sorry 🙂 Regards
Quantity 1 for the following, length 3 ft
https://www.monoprice.com/product?c_...seq=1&format=2
Quantity 2 for the following, length 6 ft. Each
OOS ETA 4/26 for 14 AWG at 100 foot.
https://www.monoprice.com/product?p_id=2747
All your choices are fine except for the HDMI cable. I know it says "4K" but to ensure 4K with HDR gets passed through you need "certified premium" - https://www.monoprice.com/product?p_id=15427 - for every HDMI to HDMI connection in the your path (source -> AVR -> display).
Display: Vizio P55-E1l Pre-pro: Marantz 7703; Amps: Emotiva XPA-2 Gen 2, Emotiva XPA-3 Gen 1, H/K AVR 520 (direct in to amps); Sources: Sony UBP-X700; X-box 1 S; Technics 1200 Mk II; Win10 PC for digital; Phono Preamp: Emotiva XPS-1; Speakers - LR: Philharmonic BMR LR, Center: Emotiva Airmotiv C2; Surrounds: Wharfedale Reva-2; Rear Surrounds: Wharfedale Diamond 220; Atmos: TF - Monoprice Alpha 8; TR - BIC VI-38; Subwoofers: dual Rythmik L22s
BluesDaddy56 is offline
post #62 of 68 Old 04-16-2019, 11:59 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 1
I can still return the AQ stuff. I don’t like overkill and spending extra money on wasteful stuff. I was told by multiple sources (BestBuy Magnolia, Crutchfield and TheMasterSwitch) that AQ stuff is high quality. I got a used AQ subwoofer cable for $75 (new is 100), used AQ HDMI cable for $59 (new is 80), new Monoprice banana clips for $10 and new AQ speaker cable for $60. In comparison, I can still order the following (or I’m open to other suggestions as well, please advise):
Mediabridge ULTRA Series Digital Audio Coaxial Cable (4 Feet) - Dual Shielded with RCA to RCA Gold-Plated Connectors - Black - (Part# CJ04-6BR-G2) https://www.amazon.com/dp/B00FMZX5RI..._sFvRCb0JJX3HP
AmazonBasics High-Speed HDMI Cable, 3 Feet, 1-Pack https://www.amazon.com/dp/B014I8SIJY..._MFvRCb2YY1Z14
Monoprice Gold Plated Speaker Banana Plugs – 5 Pairs – Closed Screw Type, for Speaker Wire, Home Theater, Wall Plates and More https://www.amazon.com/dp/B0097JLQVC..._KGvRCbEZFB6VE
Mediabridge 14AWG 2-Conductor Speaker Wire (100 Feet, Clear)- Spooled Design with Sequential Foot Markings (Part# SW-14X2-100-CL ) https://www.amazon.com/dp/B00I8V8XC0..._3GvRCbVGDBPPC
I’ll look into the home insurance stuff. Is there a rider you’d suggest if it’s already not covered by my insurance? Thanks
HUGE margin for stores on cables. They will ALWAYS tell you that and always try to sell it to you. Check out Monoprice.com for your cable needs, though I've purchased some Mediabridge stuff as well. Longer speaker cable runs typically require smaller # gauge wire (equals bigger wire). While Monoprice sells on Amazon, if you're buying enough direct from them, even with shipping vs. free Prime on Amazon, it will wind up cheaper.
Also, be prepared for how big the Emotiva Airmotiv C2 is. :-)
Bump 🙂
Ironshiekh123 is offline
post #63 of 68 Old 04-16-2019, 02:44 PM
Quoted: 536 Post(s)
Liked: 722
Bump 🙂
Did you see my original response to this?
post #64 of 68 Old 04-16-2019, 11:37 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 1
Bump 🙂
just saw it now. I didn’t see it before. So I need just 1 of those certified cables that you suggested, correct?
post #65 of 68 Old 04-17-2019, 04:09 PM
Quoted: 536 Post(s)
Liked: 722
If you're only going from AVR to display/tv, yes. If you have a 4k Blu Ray player, you need another to go from it to the AVR. I'd order two (their cheap) - and make sure you order ones long enough.
post #66 of 68 Old 04-17-2019, 05:52 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 1
Just have a TV 🙂 I ordered a 3 foot cable, as I had selected previously. Going to be using the following resource for setting up my place: https://www.dolby.com/us/en/guide/su...5-1-setup.html
I came to Atlanta yesterday and leaving today 🙂 Beautiful weather. Best wishes
post #67 of 68 Old 04-22-2019, 12:02 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 1
bump
post #68 of 68 Old 04-22-2019, 11:38 AM
gajCA's Avatar
Quoted: 8467 Post(s)
Liked: 5652
bump
That is a good guide to follow though some other guides suggest rear speakers at 2 foot or so higher than ear height when seated.
That is what I have and it works quite well as it minimizes localization when the rears are closer to the couch than in that diagram.
Geoff A. J., California
gajCA is offline
Reply Speakers
