Did I damage my new speakers? - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 1 Post By sannin
  • 4 Post By RayGuy
  • 1 Post By pase22
  • 1 Post By audioguy
  • 1 Post By sannin
  • 1 Post By gajCA
post #1 of 15 Old 04-15-2019, 01:55 PM - Thread Starter
Liked: 2
Hey guys,
I am new to the speakers world - I have just bought my first decent speakers (Dali Zensor 1). But I need to know if I have ****ed up during the connection to the amplifier (Topping MX3). I forgot I left this amp/dac combo plugged into the electric socket (just wanted to check if it works at all, and then forgot to unplug it), and connected the cables. At one point there was a loud bang from one of the speakers, kind of a "pop" sound. But loud as hell. At that moment I noticed that I messed up, so I connected a source and tried to feed it some music to see what happens. Both speakers seem to sound okay from what I can say, but could it leave some permanent damage?
Yeah I know, I am dumb, lesson learned.
Thank you!
sannin is offline
post #2 of 15 Old 04-15-2019, 02:00 PM
Quoted: 1883 Post(s)
Liked: 1612
most likely a "bullet dodged".. a good wake up call... .. turn it up a bit and see how it sounds , if it sounds clean at your highest preferred volume for an extended listen , all should work out well...
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #3 of 15 Old 04-15-2019, 02:10 PM - Thread Starter
Liked: 2
Will do, just can't right now during the night. That would be a not so nice response from the neighbors
Lp85253 likes this.
sannin is offline
post #4 of 15 Old 04-15-2019, 02:21 PM
RayGuy's Avatar
Quoted: 2515 Post(s)
Liked: 2260
Originally Posted by sannin View Post
Hey guys,
Thank you!
18Hurts, Lp85253, shivaji and 1 others like this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #5 of 15 Old 04-15-2019, 02:57 PM
pase22's Avatar
Quoted: 2985 Post(s)
Liked: 2480
Hey guys,
Thank you!
If there are any drivers blown, it'll be apparent even at moderate volume. If it's not distorting and woofer isn't flapping, you're likely ok.
Lp85253 likes this.
Kef Q100 FL/FR,SL/SR, Q200C, SVS SB-2000, Denon AVR-X3400H, , Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #6 of 15 Old 04-16-2019, 02:03 AM
audioguy's Avatar
Quoted: 4421 Post(s)
Liked: 3200
When things like that happen, tweeters usually go first. If he puts his ear up to the tweeter (with something playing), and he either hears nothing or distortion, he really did mess up. If it is OK, he did, indeed, dodge a bullet.
Lp85253 likes this.
audioguy is online now
post #7 of 15 Old 04-16-2019, 07:49 AM - Thread Starter
Liked: 2
The woofer is not flapping, seems like there is no distortion, only a constant low noise/murmur/rustle/DontKnowHowtoTranslateTheVerb (a bit louder than I would care for) when I turn on the amplifier.
I am thinking about taking them to a local audio shop to have them hooked up and looked at. They sound fine to me, but what do I know. I have exclusively used Senn HD 650 up until now.
sannin is offline
post #8 of 15 Old 04-16-2019, 10:57 AM
Liked: 1612
that's just "floor noise" you are hearing i think.. it's amp related ... definition of floor noise in layman's terms.. low barely audible "white noise " sound at low volume ...
Lp85253 is offline
post #9 of 15 Old 04-16-2019, 12:01 PM
gajCA's Avatar
Quoted: 8450 Post(s)
Liked: 5633
Hey guys,
Thank you!
Try these test tones one speaker at a time to see if anything sounds "off" with one of them.
Usually damage immediately reveals itself so you are probably OK, but the test tones and sweeps should help put your mind at ease.
Put the volume low at first and then run them at a loud but not too loud level.
https://www.audiocheck.net/testtones_index.php
Geoff A. J., California
gajCA is online now
post #10 of 15 Old 04-16-2019, 12:10 PM
pase22's Avatar
Liked: 2480
If it's a humming sound, it could be a ground loop issue. If that's the case, the issue can be resolved for less than $5 with a cheater plug.
https://www.amazon.com/CyberPower-MP...s%2C135&sr=8-4
post #11 of 15 Old 04-16-2019, 02:39 PM - Thread Starter
Liked: 2
Thank you guys, I will look at those links and products once I have time.
Lp85253 likes this.
sannin is offline
post #12 of 15 Old 04-23-2019, 05:01 AM - Thread Starter
Liked: 2
Sorry for the late reply, I was afk on an Easter Holiday. Both speakers seem to sound the same, no anomalies (none that I can distinguish at least), there is only a "pop" noise when the sound files start/end to play. There is no such pop while listening to Spotify/Youtube.
sannin is offline
post #13 of 15 Old 04-23-2019, 05:33 AM
markmon1's Avatar
Quoted: 4395 Post(s)
Liked: 2759
Wait you guys seriously don't unplug your amp every time you hook up speakers, right?
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #14 of 15 Old 04-23-2019, 07:38 AM - Thread Starter
Liked: 2
I can't tell if you're being sarcastic or not
sannin is offline
post #15 of 15 Old 04-23-2019, 09:01 AM
gajCA's Avatar
Liked: 5633
I do it with it off, not unplugged.
Lp85253 likes this.
gajCA is online now
Reply Speakers
