Good outdoor speakers ideas ? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Striper Mark
  • 1 Post By yanks1
  • 1 Post By nlpunited
post #1 of 28 Old 04-17-2019, 04:39 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
Im looking into options for my outdoor summer fun times.
Either looking at a single big boom box style speaker (active with bluetooth and such)
OR
Passive speakers (probably 2 ) that i would mount on my toolshed with a little amp or old avr inside toolshed.
Again, this has to be available in Canada. So either amazon or one of the trusted websites. (I like electronicsforless.ca for example)
So far my research:
ACTIVE:
A Benhringer PA speaker:
https://www.amazon.ca/dp/B00DMRV9H6/...v_ov_lig_dp_it
Easy option all-in-one deal. Also nice that i can bring it to friends houses when needed.
PASSIVE:
https://www.electronicsforless.ca/kl...pair-2448.html
Klipsch speakers. They usually are loud, wich would be good for outside listening. I would pair them with an AVR (buy a used one) with a bluetooth built in.
https://www.electronicsforless.ca/jb...lack-4974.html
JBL outdoors.
https://www.amazon.ca/Polk-Audio-Atr...tronics&sr=1-2
Polk Atriums. Saw a couple of good reviews on those.
https://www.amazon.ca/Polk-Audio-Atr...r=1-2-fkmrnull
Atrium 8, pricier. Same price has the Klipsch
https://www.amazon.ca/Definitive-Tec...1-1-fkmr0&th=1
Def tech. They are also well reviewed
So far im thinking either the klipsch or the def tech.
Any help is welcome. Happy Spring to you !
nlpunited is offline
post #2 of 28 Old 04-17-2019, 05:29 AM
Striper Mark's Avatar
Quoted: 132 Post(s)
Liked: 60
OR
So far my research:
ACTIVE:
PASSIVE:
JBL outdoors.
I absolutely love the RSL Outdoor speakers.
Rgarc likes this.
Living Room: Samsung 65" KS8000; Oppo 203; NAD 758V3; Elac Unifi C5 Center; Elac Unifi F5 Front Left/Right; Elac B5's Rear Left/Right; SVS PB2000
Basement : Sony HW45ES; Denon x4300; SVS Ultra L/C/R; Prime Surrounds; Prime Elevation; Infinity in-Ceiling (7.1.4) Dual PSA V1500
Striper Mark is offline
post #3 of 28 Old 04-17-2019, 07:48 AM
noway1's Avatar
Quoted: 54 Post(s)
Liked: 26
In Ottawa, under the bridge near Parliament Hill, they have Bose outdoor speakers blasting away 24/7 I think to discourage the homeless people from sleeping under there. So you might consider these:
https://www.ebay.ca/itm/New-in-Box-B...k/254154970361
(I know that's not much of an endorsement, lol)
noway1 is online now
post #4 of 28 Old 04-17-2019, 08:26 AM
pjp
pjp's Avatar
Quoted: 365 Post(s)
Liked: 257
I am building a deck system now and am using the Polk Atrium 6 as mains with this passive 8" in-ground subwoofer (https://www.amazon.com/TIC-Outdoor-W...gateway&sr=8-3) to fill out the bass. I couldn't find an outdoor 2.1 amp to drive the passive sub that had sub controls, so I am using this little board amp (https://www.parts-express.com/tps311...RoC6dsQAvD_BwE) and will build an enclosure for the amp unit.
The board amp has built-in Bluetooth also (I am using a version of that board without bluetooth, so I can't comment on Bluetooth performance). I am only bench testing this system now -- it's not installed outside yet -- but this combination rocks. The Polks are super clear and the TIC sub puts out powerful bass.
When paired with a $10 24-volt 4-amp power supply from eBay, that little amp sounds amazing. The amp has controls for sub crossover, sub level, amp level to the mains, a treble control (sub level is effectively the "bass" control), and a master volume. While that may seem like a very strange mix of controls, it's actually perfect because it allows you to finely tune the main/sub mix very effectively.
The TIC sub also has a built-in fixed crossover, so you could just hook up a 2-channel amp to the left/right of the passive sub inputs, and connect the sub speaker outputs to left/right mains. Using it this way is a lot simpler, but you don't have any control over the sub/main balance where with the board amp you have total control over it.
pjp is offline
post #5 of 28 Old 04-17-2019, 08:57 AM
Quoted: 1005 Post(s)
Liked: 776
I have pair of Polk Atriums & love them; also would 2nd RSL as very good value speakers with solid build quality.. good luck
pjp likes this.
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parasound P5 & ATI 500NC 2 channel amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #6 of 28 Old 04-17-2019, 09:05 AM
pjp
pjp's Avatar
Quoted: 365 Post(s)
Liked: 257
One thing I liked about the Polk Atriums is that they claim to exceed mil specs for environmental endurance. I don't know how significant that rating is, but since mine will be out in the elements without cover, that was part of the deciding factor for me. The 6's are larger than I'd like (the 8's are larger still), but sound-wise I am very impressed with them. Durability I haven't tested at all yet, but am optimistic based upon their (claimed) mil spec rating.
pjp is offline
post #7 of 28 Old 04-17-2019, 12:29 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
Thats hilarious in a way. Sad in some other way.
post #8 of 28 Old 04-17-2019, 12:30 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
Yeah the Polks look like a good bet too..Hard to pick.
I know Klipsch are usually loud as hell wich makes sense for outside listening
Muphasta likes this.
post #9 of 28 Old 04-17-2019, 12:30 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
Dont think RSL is available in CAN
Those look real good there. Nice setup.
yanks1 likes this.
post #10 of 28 Old 04-17-2019, 12:31 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
They dont seem to be available in CAN sadly.
post #11 of 28 Old 04-17-2019, 12:46 PM
Muphasta's Avatar
Quoted: 231 Post(s)
Liked: 189
I have the Klipsch AW-650s and they are fantastic in our back yard. They are large outdoor speakers, so check the specs if WAF is an issue.
Vinyl, tape, digital... I don't care as long as I can listen to my music...
Muphasta is offline
post #12 of 28 Old 04-17-2019, 12:49 PM
pjp
pjp's Avatar
Quoted: 365 Post(s)
Liked: 257
The Polks have better treble and are clearer sounding, the Klipch's are not as open sounding but are more efficient. How do I know? Check out this tool -> https://www.crutchfield.com/S-1yoNUR...ch-AW-650.html. This comparison is the $299 Atrium 6 against the $549 Klipsch AW-650.
This is the first time I've used the tool above, but it seems pretty awesome. I'm using my studio monitors to evaluate -- it asks what headphones to use, pick your headphones if you are using them, or AKG if not.
pjp is offline
post #13 of 28 Old 04-17-2019, 01:15 PM
pjp
pjp's Avatar
Quoted: 365 Post(s)
Liked: 257
If you get this passive sub (https://www.amazon.com/TIC-Outdoor-W.../dp/B00009UI6L) or something similar, I suspect you can go even smaller than the Atrium 6 and not sacrifice sound quality unless you really plan to crank it hard or have a very large area to cover. Given that I have the sub, if I could do it over again, I would have chosen smaller mains (Atrium 5 or maybe even 4's) both for WAF and MOAF (my own acceptance factor).
pjp is offline
post #14 of 28 Old 04-17-2019, 06:24 PM
pjp
pjp's Avatar
Quoted: 365 Post(s)
Liked: 257
I don't know it was clear in my prior post with the link above, but once you get to that page you have to hit the "Listen Now" button at the top left of the page under the "Speaker Compare". That should pop up the window below that allows you to switch back and forth between the Polk and Klipsch recorded audio at volume matched levels. The difference between speakers seems most pronounced on the "Alternative Rock" track. This is a pretty awesome comparison tool. If you click the "same power" option instead of "same volume" at the bottom, you can hear how much more efficient the Klipsch are.
Name:	Screen Shot 2019-04-17 at 9.15.06 PM.png
pjp is offline
post #15 of 28 Old 04-17-2019, 06:57 PM
grasshoppers's Avatar
Quoted: 949 Post(s)
Liked: 697
If you are in Canada you should check out the outdoor speakers by
2 very good Canadian companies...PSB & Paradigm.
I own the largest Paradigm Stylus 470's for about 7 years now.
The 2 models from PSB were jaw dropping good too.
(Main)-Marantz 6012*Outlaw Audio M2200*Rythmik F12 subs*Paradigm Signature S6,C1,S1
******Harman Kardon DMC1000 (music)-Assassin HTPC (movies).
(Bedroom)-Marantz SR5003*Paradigm Studio 40,SE Center,SE One*SVS SB-2000 subs*Sony S6200
(Music room)-Outlaw Audio RR2150*Sierra Two ribbon speakers*Rythmik L12 sub*Yamaha CDR-HD1500
grasshoppers is offline
post #16 of 28 Old 04-17-2019, 07:21 PM
Yellbean's Avatar
Quoted: 48 Post(s)
Liked: 100
I have the Def Tech 6500 on my deck and would happily recommend them. They replaced some Yamaha 350s and it was a night and day difference.
Living room: Sony 75x940D, Yamaha RX-A1080 receiver, Monitor Audio 5.1 RS6 / RS Center / RS 1 rears, Outlaw EX LFM 1-Plus, XBOX One S, PS 3, Amazon Fire TV
Cave: Panasonic 65ZT60, Denon x1300w receiver, Monitor Audio RS 1 2.0, PS4, PS2, PS1, Nintendo / N64
Yellbean is offline
post #17 of 28 Old 04-18-2019, 04:18 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
Looking that paradigm's website.
Whats the difference between 470 and 470 sm ??
SM is made to be used on its own i think ?
post #18 of 28 Old 04-18-2019, 04:32 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
Actually just found out psb's CS500 series are on sale for 250$ pair... Seems really good.
Would you pick those VS the Definitive Technology AW 6500 (350$/pair)
PSB's are usually 500$/pair.
post #19 of 28 Old 04-18-2019, 05:57 AM
pjp
pjp's Avatar
Quoted: 365 Post(s)
Liked: 257
Here is a sound clip comparison of the PSB, Klipsch, and Polk (the Def Tech is in the comparison for stats, but Crutchfield don't have a sound clip for the Def Tech yet) -- all 3 sound quite different, the alternative rock track seems to reveal the most differences:
https://www.crutchfield.com/Product/...=01|735AW6500B
pjp is offline
post #20 of 28 Old 04-18-2019, 06:18 AM
pjp
pjp's Avatar
Quoted: 365 Post(s)
Liked: 257
Listening to more Crutchfield sound clips, I think the PSB's sound the most natural. The Polks have the most sparkle, which seems like overboosted highs and less midrange. If you like bright speakers, the Polks are great, if you don't like bright, Polks may be the worst choice. Revel and Klipsch sound flat in comparison to the others -- maybe they are more accurate, but not as compelling to listen to.
The Polks are so bright that going from Polks to anything else make the next speaker sound dead. It's better to listen to the Polks last (particularly after the PSB's), because then you get the sense that the Polks might well be overboosted in the highs.
Unfortunately, Crutchfield doesn't carry Paradigm and they don't have sound clips for Def Techs or Martin Logan yet.
pjp is offline
post #21 of 28 Old 04-18-2019, 06:54 AM
Quoted: 949 Post(s)
Liked: 697
The SM model has 2 tweeters and is meant to be used as a single speaker
Being fed a 2-channel signal. (Left/right into one speaker)
I'm running a pair of the regular 470's.
post #22 of 28 Old 04-18-2019, 07:00 AM
Quoted: 949 Post(s)
Liked: 697
I haven't heard the Det Tech speakers. If you can get the PSB's for $250, I'd
Jump on it. If my Paradigms ever go out, I decided after hearing the PSBs
That they would be my next outdoor speakers.
That's a really good deal on those speakers
post #23 of 28 Old 04-18-2019, 07:47 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
Yeah decided to give it a try at that price seems lilke a no brainer
All i need is to find a nice amp for it.
Maybe the paradigm PW amp on sale at 250$ would make sense
pjp likes this.
post #24 of 28 Old 04-18-2019, 09:22 AM
jedi1982's Avatar
Quoted: 241 Post(s)
Liked: 514
We have the JBL's for our covered deck and love listening while we chill & grill
jedi1982 is offline
post #25 of 28 Old 04-24-2019, 01:48 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
Talking
I currently got the PSB CS 500 mounted in my garage (my shed is not builded yet) and i love to listen while i cook on the BBQ (curently have to cook in driveway because my yard is a mud fest)
I think i will order some Def Tech and compare both models and send the others back...Or keep them for the garage. Lol
post #26 of 28 Old 04-24-2019, 01:49 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 29
They are currently pluged in the garage.
They sound really good but i figured i would also order def tech and compare.
post #27 of 28 Old 04-24-2019, 06:06 AM
jedi1982's Avatar
Quoted: 241 Post(s)
Liked: 514
hah! more is always better right???
jedi1982 is offline
post #28 of 28 Old 04-24-2019, 08:52 AM
rocky1's Avatar
Quoted: 428 Post(s)
Liked: 117
I think the def techs are great. I have a pr of aw5500 in the patio area under roof/eaves. Have a pr of aw6500 coming in which I will put out by the side of the pool under the eaves.
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is offline
Reply Speakers
