NHT superzero and superone setup - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #31 of 40 Old 09-11-2019, 12:03 PM
pase22's Avatar
Quoted: 3296 Post(s)
Liked: 2739
Originally Posted by ace54 View Post
how do I set speaker crossover points to the sub?
Set crossover knob on the sub all the way up or bypass. Set volume knob to about 12 o'clock. Run YPAO. After YPAO is done set all speakers to small and set a 90hz crossover (in the AVR menu) to start, then adjust to preference.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #32 of 40 Old 09-11-2019, 12:33 PM
gajCA's Avatar
Quoted: 8984 Post(s)
Liked: 6148
I'm not sure he can set a separate crossover for the center but it actually looks like a 120hz crossover is needed for the SuperZeros.
EDIT: he has to use a global crossover as per page 82 of the manual.
https://pdf.crutchfieldonline.com/Im.../022RXS600.PDF
"The SuperZero 2.0’s –3-dB point is at 110 Hz, and the –6-dB point is at 97 Hz. Impedance reaches a minimum of 6.23 ohms at 230 Hz"
Read more at https://www.soundandvision.com/conte...rbEO3UdCqyS.99
Geoff A. J., California
gajCA is offline
post #33 of 40 Old 09-11-2019, 12:38 PM - Thread Starter
ace54's Avatar
Quoted: 89 Post(s)
I will keep the energy take classic sub the Yamaha subwoofer would be a downgrade
Classic energy take specs
Bass Reflex with Front Firing Port
200 Watts
8” (20cm) MPP Cone with patented Ribbed Elliptical Surround™
33Hz – 150Hz +/- 3dB
0°, 180°
40Hz – 150Hz @ 18dB/octave
Line In/Sub IN (RCA) and Speaker Level In (Spring Clips)
On/Auto/Off
Yamaha specs
Driver: 20.3 cm (8 in.) cone
Dynamic power: 100 W (5 ohms)
Output power: 50 W (100 Hz, 5 ohms, 10% THD)
Frequency: 28-200 Hz
Advanced YST: yes
Twisted flare port: yes
ace54 is offline
post #34 of 40 Old 09-11-2019, 12:43 PM
gajCA's Avatar
Liked: 6148
200 Watts
0°, 180°
On/Auto/Off
Yamaha specs
Advanced YST: yes
I didn't realize you already had a sub.
But if you didn't know how to set the crossovers you will need to set the receiver so that it knows you have the sub in play, set the other speakers to "small," and use a 110hz or higher crossover.
I linked the manual for your reference above.
gajCA is offline
post #35 of 40 Old 09-11-2019, 12:45 PM
pase22's Avatar
Liked: 2739
Yeah.... Had him mixed up with another OP that has the S15's.
pase22 is offline
post #36 of 40 Old 09-11-2019, 12:46 PM - Thread Starter
ace54's Avatar
Quoted: 89 Post(s)
I changed my speakers since starting this thread I now have C1s for L/R TWOC for center and Absolute Zeros for surround all at 80hz crossover
I know how to set crossovers very well done it many times I thought you were talking about something else earlier my mistake
ace54 is offline
post #37 of 40 Old 09-11-2019, 12:55 PM - Thread Starter
ace54's Avatar
Quoted: 89 Post(s)
Yeah I have the energy take classic sub I don't think I can upgrade for $150/$200.00 budget so I will keep what I have for now
ace54 is offline
post #38 of 40 Old 09-11-2019, 01:23 PM
gajCA's Avatar
Liked: 6148
My mistake on your having the Superzeros up front.
80hz and "small" should be fine as should the sub until you have the $700 it takes to upgrade in Canada!
gajCA is offline
post #39 of 40 Old 09-11-2019, 03:32 PM
Quoted: 2067 Post(s)
Liked: 1721
See page 81 and 82 of your manual.
When you get the sub tell the receiver "use" for the sub and then set all speakers to "small" with an 100hz crossover.
Place the sub near the front three.
this ..100 hz is about perfect , i think...
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #40 of 40 Old 09-11-2019, 07:23 PM
Zorba922's Avatar
Quoted: 7099 Post(s)
Liked: 5403
I did run ypao the level was set to -1.5 I set it to -3.0 and it does sound better now
I would check to see how -4.5 sounds, if worse then -3.0 it is.
Typically the L/R are going to be an extra foot or two farther away from the main listening position than the center to begin with, so if the center happens to be both high sensitivity and tonally more on the "bright" side then a greater level adjustment would be just the ticket.
ace54 and Lp85253 like this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
Reply Speakers
