Room Advice, wide room, open floor plan - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-29-2019, 10:50 AM - Thread Starter
drewcwsj's Avatar
Question Room Advice, wide room, open floor plan
Would love some advice on speaker placement.
Equipment:
Marantz SR5009 with Audyssey mic
ERA D4 L/R and Center
Era Sub 8
Era D3 for surrounds (may change based on suggestions)
Source:
HTPC for internet video and gaming
Sony bluray
I am struggling with the surround placement. Currently using the D3 on stands about 5 feet left and right of the sofa. This leads to extreme sweet spot in center of sofa but unbalanced for left or right seat. Could go in-wall or in-ceiling, dipole or biole.
drewcwsj is offline
post #2 of 4 Old 04-29-2019, 01:15 PM
gajCA's Avatar
Quoted: 8823 Post(s)
Liked: 6002
Equipment:
Era Sub 8
Source:
Sony bluray
My sofa is up against the wall so my rear surrounds are mounted on the wall on flat shelves at about ear height when standing above the end tables of the couch.
The shelf itself is a ceramic floor tile from Home Depot with some brackets I bought there also.
The speakers are pointed at the center of the room and tilted down a little with the use of a wine cork under the rear of the speaker and it works very well.
Geoff A. J., California
gajCA is offline
post #3 of 4 Old 04-29-2019, 09:18 PM
RayGuy's Avatar
Quoted: 2729 Post(s)
Liked: 2500
Try raising the speakers up to about a foot above your seated ear. See if that evens out the sound. the speakers should be slightly behind the seated ear, almost facing each other, pointed towards the center seat. If you are still having issues, try bringing them in closer to the seating, as that will increase the angle of the speaker to the closest listener, thus reducing the apparent output of the closest speaker.
You will need to experiment a little. Let your ears decide what position and orientation sounds best at all your seating positions.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #4 of 4 Old 04-30-2019, 07:39 AM - Thread Starter
drewcwsj's Avatar
I went ahead and bought some cheap fluance bipolars to do some experiments. Planning on putting them a few feet left and right of the couch, wall mounted near the ceiling.
drewcwsj is offline
Reply Speakers
