I need some sort of speaker stands for Andrew Jones rear surround - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-29-2019, 04:12 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 5
I am going to buy the Pioneer SP-BS22-LR Andrew Jones for rear surround speakers. I need some sort of stands that will work for these. I've seen the Vivo stands that are only 2' high and aren't high enough for me as I need something 3-4' high. I have a the Sanus https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
speaker stands. It doesn't look like the Andrew Jones has holes in the back to mount with bolts onto my Sanus stands.
Are there any other options out there?
djxpress is offline
post #2 of 4 Old 04-29-2019, 08:56 PM
RayGuy's Avatar
Quoted: 2593 Post(s)
Liked: 2342
Video Secu has side clamping adjustable stands ... check Amazon.
Those speakers are nearly 10 lbs, which most of these tall speaker stands cannot accommodate (not to mention a touch unstable. If you went with a lighter speaker, there would be more options. For instance, Accessories4less has the Boston Acoustics A23, a very nice little speaker with a warm sound similar to the Pioneer, at only 4.5 lbs. At that weight, you could get into these nice Atlantic stands:
https://www.amazon.com/dp/B000289DC6..._t2_B002HZHUCW
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #3 of 4 Old 04-29-2019, 09:41 PM
bobknavs's Avatar
Quoted: 2128 Post(s)
Liked: 1506
These are highly regarded (I don't own them): https://www.monoprice.com/product?p_id=24794
The max height version is 32", though, which may not be tall enough for you. (What do you really need? The tweeters are supposed to be at about ear height.) They are not inexpensive. They are also out of stock until at least 5/22/2019.
If you don't care about looks, you could consider these: https://www.amazon.com/ZENY-Monitor-...sr=1-3-catcorr They are fairly light, and they have locking pins to set them at a variety of discrete heights, so you don't have to worry about slipping clamps. (I presume that they are of Chinese manufacture. Identical ones are available under a number of brands. These may be among the cheapest.)
They have no clamping provision, but a little Blue Tac or equivalent will keep the speakers in place against small shocks. I'm using a pair for my rear speakers (7.2.4 Atmos).
Speaking of Chinese speaker stands, you might consider: http://www.vtimanufacturing.com/prod...peaker-stands/ I'm using a pair of VSP 29s for my fronts. (Ok, but overpriced.) Those aren't what you want, but the site lists adjustable height ones, some with side clamps. VTI and others are sold by https://www.standsandmounts.com/fixe...erstands.aspx#
bobknavs is offline
post #4 of 4 Old 04-30-2019, 01:19 AM
Stephen Hopkins's Avatar
Quoted: 402 Post(s)
Liked: 181
There are plenty of 36" speaker stands out there in a wide range of materials, finishes, and price points... just search Amazon for "36 inch speaker stands" and pick the ones you like the look and price of.
BenQ TK800 | Silver Ticket 106" 16:9 1.0 Grey | Marantz SR6011 | B&W P6 | B&W CDMC SE | Sonance .5 THX SUR | MCM In-Ceiling Atmos | Ascendant Avalanche 12" in 6 ft^3 @ 18Hz w/ BASH 500w Plate Amp | Sony X800 | NVidia Shield TV Pro | XBox One 500gb | Nintendo Switch | Harmony Smart Control | SmartThings Hub | Google Home | AT&T Fiber 300 | YouTube TV | Netflix | HBO Now | Spotify
Stephen Hopkins is offline
Reply Speakers
