Ceiling speakers to go w/ M&K S150's ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-01-2019, 10:19 AM - Thread Starter
Aslan's Avatar
Location: White Bear Lake, MN ----- CUSL2C, P3/1.0, 256Mb, HiPix, A2496, D50Q, Stewert 1.3g, Denon 3801,
Quoted: 42 Post(s)
I have a system of original M&K S150's that includes S150 LCR's, four SS150 tripoles and S10 powered sub. I've been extremely happy with this. It is in a small dedicated theatre (no parallel surfaces, double green glue sheetrock on isochannel, insulated walls & ceiling, etc.)
We are building a new house and will not have a dedicated theatre but rather a larger room that can seat more people and have a bar. I'm planning to re-use the S150 system but would like to add height speakers. Amp will likely be an Anthem MRX 1120.
My initial thought is four M&K IC95 or four M&K IW95 or M&K IW950 or similar. This is pricey but I assume would be better timbre matched than other options. Not sure if it's worth it though. I'm leaning IC95 for cost.
The ceiling speakers throughout the rest of our house will likely all be Paradigm. Either P656-R or E65-R. I'm wondering if something like the E80-R would be a better option than the M&K's. I'd also appreciate any thoughts on the P65 vs E65 as well as the possibility of mixing them with the E's in more critical locations.
Aslan is offline
post #2 of 3 Old 05-01-2019, 10:28 AM - Thread Starter
Aslan's Avatar
Quoted: 42 Post(s)
Here's the room that these will be going in. It's approx 20'x27'
Aslan is offline
post #3 of 3 Old 05-01-2019, 06:56 PM
RayGuy's Avatar
Quoted: 2586 Post(s)
Liked: 2330
Look at the Boston Acoustics options, which should have a similar sound signature to your M&K. If you have trouble finding them, take a look at the RSL C34 in-ceiling speaker. Silk dome tweeter but very neutral in character, so should blend with anything. Plus, it has a built-in 15 degree angle to make placement and area coverage easier.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
Reply Speakers
ceiling speakers , m&k , Paradigm
