Bookshelf speakers - AVS Forum | Home Theater Discussions And Reviews
 21Likes
  • 2 Post By Lp85253
  • 2 Post By Russdawg1
  • 1 Post By joewerda
  • 2 Post By gajCA
  • 1 Post By gajCA
  • 2 Post By gajCA
  • 3 Post By joewerda
  • 1 Post By Lp85253
  • 2 Post By pase22
post #1 of 23 Old 05-02-2019, 11:56 AM - Thread Starter
Quoted: 17 Post(s)
Bookshelf speakers
Good afternoon all,
This is my first post and hopefully I can get some info to go into the right direction. I have finally upgraded and purchased my first smart TV. I decided to start upgrading my over decade old audio system.
I purchased a Marantz NR1609 to replace my Onkyo TX-SR304. Now it's time to move to new speakers. I am replacing an Acoustimass 3 system.
I am thinking of going with ELAC Debut 2.0 speakers and a Klipsch Reference Series 10" subwoofer. My living room is not that big and I will be using my 1984 Technics 1200 SL turntable with this system as well.
Your opinions of my choices please.
joewerda is offline
post #2 of 23 Old 05-02-2019, 12:00 PM - Thread Starter
Quoted: 17 Post(s)
I forgot to add that I would like a center speaker but do not have a preference yet.
Marantz NR1609
RSL CG3 x 2
RSL CG23 center channel
RSL Speedwoofer 10S
joewerda is offline
post #3 of 23 Old 05-02-2019, 12:02 PM
Quoted: 1482 Post(s)
Liked: 1068
Budget?
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #4 of 23 Old 05-02-2019, 12:06 PM - Thread Starter
Quoted: 17 Post(s)
Originally Posted by Russdawg1 View Post
Budget?
Under $1k for speakers and subwoofer
Marantz NR1609
RSL CG3 x 2
RSL Speedwoofer 10S
joewerda is offline
post #5 of 23 Old 05-02-2019, 12:12 PM
Quoted: 1940 Post(s)
Liked: 1649
just a thought ... emotiva b1 / c1 combo and whatever $500 sub floats yer boat
cocrh and joewerda like this.
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #6 of 23 Old 05-02-2019, 12:15 PM
Liked: 1068
I’d start with a 12” subwoofer from either Rythmik or HSU.
From there you can determine what your budget is for speakers. I’d guess $400, depending on which sub you get, but you can get a pair of Ascend CBM170SE’s or Emotiva B1’s.
The Elac’s are really only a good choice when on sale for 50% off, if not, there are way better choices in the $300 range.
joewerda and Soulburner like this.
post #7 of 23 Old 05-02-2019, 12:17 PM - Thread Starter
Quoted: 17 Post(s)
Thanks, I am not familiar with this brand but will definitely look them up.
Lp85253 likes this.
joewerda is offline
post #8 of 23 Old 05-02-2019, 12:18 PM
gajCA's Avatar
Quoted: 8593 Post(s)
Liked: 5791
Good afternoon all,
That is a nice but not hugely powerful receiver so you want relatively high efficiency speakers.
This would be a very nice $900 3.1 system.
https://rslspeakers.com/products/cg2...heater-system/
The 5.1 system is a bit over budget so if it is a very tight budget there are options for $100/pair surrounds.
These would work just fine for rear surrounds at $100/pair.
https://www.crutchfield.com/p_107OWM...WM3-Black.html
Lp85253 and joewerda like this.
Geoff A. J., California
gajCA is offline
post #9 of 23 Old 05-02-2019, 12:20 PM - Thread Starter
Quoted: 17 Post(s)
My living room is only approx 14 x 20, would the 12 be too much?
Emotiva mentioned for a second time. Definitely going to look them up! Thanks.
joewerda is offline
post #10 of 23 Old 05-02-2019, 12:21 PM
Liked: 1068
I’d be scared of it being too little
Soulburner and joewerda like this.
post #11 of 23 Old 05-02-2019, 12:23 PM - Thread Starter
Quoted: 17 Post(s)
Thanks for the info! That first link looks very interesting.
joewerda is offline
post #12 of 23 Old 05-02-2019, 12:28 PM
Liked: 1649
that RSL combo unit would be very nice for home theater (good dynamics) .. as far as music , i don't know, but i wouldn't rule them out until i heard from others...
post #13 of 23 Old 05-02-2019, 12:29 PM
gajCA's Avatar
Liked: 5791
https://www.soundandvision.com/conte...-system-review
I just noticed that the new CG3 5.1 system is only $79 over budget.
https://rslspeakers.com/products/cg3...heater-system/
And the new special edition is bang on your budget but you need to be able to place one of the new CG3s vertically as a center and it's 9.5" tall.
https://rslspeakers.com/products/cg3...ecial-edition/
joewerda likes this.
gajCA is offline
post #14 of 23 Old 05-02-2019, 12:33 PM - Thread Starter
Quoted: 17 Post(s)
Forgive my ignorance but this if from the first link under Minus: Sats can be a bit power-hungry in larger rooms
What is a Sats?
joewerda is offline
post #15 of 23 Old 05-02-2019, 12:40 PM
gajCA's Avatar
Liked: 5791
What is a Sats?
Sats = small satellite speakers; in this review it refers to the CG3s.
So you may be better of with the less power hungry CG23 3.1 system and the Polks I linked as satellite surrounds.
RSL has free returns if you are worried but unless you have a very large room and like to listen at very loud levels the CG23 3.1 system + Polk surrounds should work very well.
It will certainly be head and shoulders above what you had before.
joewerda and Lp85253 like this.
gajCA is offline
post #16 of 23 Old 05-06-2019, 10:25 AM - Thread Starter
Quoted: 17 Post(s)
Alright everyone, I finally ordered my speakers. Here is what I went with:
2 RSL CG3 front speakers
1 RSL CG23 center channel
1 RSL 10" Speedwoofer 10S
Total cost $849. I should receive them on Friday. Thanks for all of your help!!
Lp85253, gajCA and cocrh like this.
joewerda is offline
post #17 of 23 Old 05-06-2019, 10:28 AM
Liked: 1649
1 CG23 center channel
1 10" Speedwoofer 10S
well done .. you played it just right.. 3.1 with a nice sub is a great start up system.. you can add rears and / or another sub as you see the need
post #18 of 23 Old 05-06-2019, 10:35 AM
pase22's Avatar
Quoted: 3094 Post(s)
Liked: 2574
You got yourself a very nice setup at a good price. Come back and let us know your impressions once you're setup and running.
Sit back and enjoy!
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #19 of 23 Old 05-06-2019, 03:50 PM
Liked: 9
Have a look at Ascend Acoustics speakers. They will outperform the Elac's for around the same price.
mdinno is offline
post #20 of 23 Old 05-15-2019, 09:12 AM - Thread Starter
Quoted: 17 Post(s)
Sit back and enjoy!
Well everyone, I got them all hooked up and man.....I am blown away!! The sound is amazing to say the least. I have owned nothing but Bose since the early 90's and cannot believe what I have been missing. I spent the last 4 days binge watching movies because I never heard such great sound. That subwoofer....I've had to straighten pictures already! My wife keeps thinking she is hearing thunder LOL
Also, RSL just started offering the speakers I bought as a package now but for $20 more. Glad I ordered when I did!
https://rslspeakers.com/products/new...heater-system/
joewerda is offline
post #21 of 23 Old 05-15-2019, 09:49 AM
Liked: 1649
a nice sub makes a BIG difference.... enjoy...
post #22 of 23 Old 05-15-2019, 10:05 AM
pase22's Avatar
Liked: 2574
For $850 you easily blow away a Bose setup costing 3 to 4 times the price. I think that's one of the main reasons Bose isn't very well liked in the forum. They're way overpriced for what they offer.
Glad you're enjoying the new setup! Now get a 2nd Speedwoofer and you're all set.
post #23 of 23 Old 05-15-2019, 10:06 AM
gajCA's Avatar
Liked: 5791
Congratulations!
gajCA is offline
Reply Speakers
