Need recommendation for center channel speaker for Klipsch RF-62 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-03-2019, 04:45 PM - Thread Starter
Whitestar19's Avatar
Hello! I've recently snagged an amazing deal on a pair of RF-62's and I need a center channel to match. I don't want it too weak, or over powered. Which one would be a good pairing?
This is what I have - https://www.klipsch.com/products/rf-62
What I'm considering, in order:
RP-440C https://www.klipsch.com/products/ref...?model=rp-440c
RP-404C https://www.klipsch.com/products/rp-...hannel-speaker
R-34C https://www.klipsch.com/products/r-34c-center-speaker
I think the RC-62 would be the perfect match...?, but hard to find since they're almost 10 years old. The RC-62 II is newer, but again, not the easiest to find for sale. https://www.klipsch.com/search/results?q=rc-62
Should I still hunt down the RC-62's, or go with one of the others? Or am I wrong and need something completely different? I was hoping for that price range, or cheaper would be nice. Thanks for your help!
Whitestar19 is offline
post #2 of 7 Old 05-03-2019, 06:36 PM
Kini62's Avatar
Quoted: 2684 Post(s)
Liked: 2472
If budget is a concern and you can't find an RC52 or 62 then this one would work or should work https://www.crutchfield.com/p_714R52...sch-R-52C.html
If you can afford it one of the first gen RP models would be better.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #3 of 7 Old 05-03-2019, 06:49 PM
Quoted: 375 Post(s)
Liked: 313
I'd go with an RP line center channel. Bigger drivers sound better tho like the RP-500C or RP-600C if you can budget that and have space as they are taller
cocrh is offline
post #4 of 7 Old 05-04-2019, 08:39 AM - Thread Starter
I'm comfortable spending up to $400, maaaaybe $450. There's a good deal on the 440C ($350), but would that overpower what I have? I could do the 500C for a little more if it's worth it. The R52C sure has a nice price and if it matches up to what I have now, then great. Thanks for the replies.
post #5 of 7 Old 05-04-2019, 09:05 AM
pase22's Avatar
Quoted: 3094 Post(s)
Liked: 2574
You want the best center you can afford. About 70% of the movie and 99% of dialogue is coming from the center. The lower line model are known for their brightness that can become fatiguing after a while. The RP-line is much smoother and more refined so I'd go with either the RP-440, RP-500/600 models.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #6 of 7 Old 05-04-2019, 09:48 AM
Quoted: 375 Post(s)
Liked: 313
The RP500C is $369 at Crutchfield
https://www.crutchfield.com/p_714RP5...00C-Ebony.html
RP600C is $499 so a bit over your top maybe budget.
https://www.crutchfield.com/p_714RP6...00C-Ebony.html
Open box deal for $449
https://www.audioadvice.com/klipsch-...iABEgKbhvD_BwE
cocrh is offline
post #7 of 7 Old 05-04-2019, 01:22 PM
Kini62's Avatar
Liked: 2472
Try the R52C and if you don't like it, exchange it for the 440C.
Def Tech SC8000
Onkyo RZ820
Kini62 is offline
Reply Speakers
