Setting up home theater need help with speakers - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #31 of 58 Old 05-16-2019, 02:35 PM
Quoted: 26 Post(s)
Liked: 4
[quote=gajCA;58056390]
Originally Posted by Raider Stagger View Post
$312 on Amazon today which is lower than Crutchfield but not $140.
https://www.amazon.com/Polk-Audio-26.../dp/B004L9GWSK
We must not be looking at same speaker?
Raider Stagger is offline
post #32 of 58 Old 05-16-2019, 02:47 PM
Quoted: 26 Post(s)
Liked: 4
Originally Posted by gajCA View Post
Which sub?
I would stay away from 8" in walls in any room but especially a small room.
why stay away from the 8" in walls
even if my room is 23 x 14 room dedicated theater room?
post #33 of 58 Old 05-16-2019, 03:10 PM
gajCA's Avatar
Quoted: 8593 Post(s)
Liked: 5791
[quote=Raider Stagger;58057894]
That's a great price for what seems like a great speaker.
Crutchfield reviews are far more reliable than Amazon's and the lowest rating was 4 stars.
An in wall speaker you want as much dispersion as possible because you cannot swivel the woofers which handle every frequency below about 2700hz.
An 8" woofer offers less dispersion than a 6.5" woofer using the same size tweeter.
Geoff A. J., California
gajCA is offline
post #34 of 58 Old 05-16-2019, 06:18 PM
Quoted: 26 Post(s)
Liked: 4
[quote=gajCA;58058026]
Ok thank you I didn't understand why a 8" is bad in walls but a 6.5 is good in walls lol makes sense now so basically it has one point of sound , straight ahead and doesn't disperse to other parts of room.
so if money was somewhat of a issue but not that much what set up would you go with for 2 fronts, 2 sides and 2 rears and 2 ceiling speakers.
or is this overkill for a 23 x 14 x 8 room?
Also any particular speaker wire or just any in Wall Audio Speaker Cable Wire CL2 14/2 AWG Gauge 2 Conductor
post #35 of 58 Old 05-16-2019, 06:20 PM
Quoted: 26 Post(s)
Liked: 4
are you saying it is two different quality of speakers but same speaker , if the speakers are the same why would I not buy them from Amazon if they are way less.
post #36 of 58 Old 05-16-2019, 06:36 PM
Quoted: 26 Post(s)
Liked: 4
[quote=Raider Stagger;58058682]
https://www.amazon.com/Micca-M-8C-Ce...NN84F16QQN4ZYG
Is this a better option cause of the pivoting woofer.
post #37 of 58 Old 05-16-2019, 07:45 PM - Thread Starter
ad10sk8er's Avatar
Quoted: 34 Post(s)
Liked: 7
love the analogy looks like it's going to be the speedwoofer 10 just can't swing it this week. Need to buy a lawn mower
Sent from my XT1650 using Tapatalk
ad10sk8er is offline
post #38 of 58 Old 05-17-2019, 08:22 AM
gajCA's Avatar
Liked: 5791
[quote=Raider Stagger;58058748]
That's a pivoting tweeter like the Polk in walls which you should get from Amazon.
If you can afford to get enough of them they can be used for all positions other than in ceiling.
The Micas would probably be just fine for in ceiling Atmos effects.
Buy your speaker wire from Monoprice.
14 gauge pure copper should be just fine.
gajCA is offline
post #39 of 58 Old 05-17-2019, 11:41 AM
Quoted: 26 Post(s)
Liked: 4
[quote=gajCA;58060488]
Awesome Thanks, I appreciate the help Kinda new to this and not 100% sure on what to do?
Build a stage for subs to be under , put sub in back lol which speakers, which reciever so many options and such little time to plan lol
post #40 of 58 Old 05-17-2019, 11:55 AM
gajCA's Avatar
Liked: 5791
[quote=Raider Stagger;58061432]
Are you trying to accomplish 5.2.2 or 5.2.4?
As to sub placement, here's SVS's take.
https://www.svsound.com/blogs/svs/75...ofer-placement
https://www.svsound.com/blogs/svs/75040195-why-go-dual
gajCA is offline
post #41 of 58 Old 05-17-2019, 08:35 PM
Quoted: 26 Post(s)
Liked: 4
[quote=gajCA;58061486]
5.1.2 well at least I thought not really sure I built columns on each side to house speakers but now I think it would be better to have the columns up front and then 2 speakers on each side and a 2 in back or ceiling I want a good system but not go deaf or have overkill.
post #42 of 58 Old 05-18-2019, 07:51 AM
gajCA's Avatar
Liked: 5791
[quote=Raider Stagger;58063410]
Denon 1500 is at a nice price.
https://www.crutchfield.com/p_033AVX...VR-X1500H.html
gajCA is offline
post #43 of 58 Old 05-18-2019, 11:21 AM
Quoted: 26 Post(s)
Liked: 4
[quote=gajCA;58064628]
I absolutely Love Denon I have a Denon receiver at this moment
I think you should just pick out my system......
Can you do that for me pick out my speakers, sub and I will just buy it and be happy with it!
It is way better to have an experienced individual tell you what you should go with then to attempt to guess what you think would sound good. Then buy the wrong stuff and send it back 30 times. I just want a Good Quality Decent sound theater room for movies, gaming, and Football.
I would like 2 speakers in front 4 on sides and 2 in ceiling probably just 1 sub woofer or 2 sub woofers.
I have Cerwin Vega huge box speakers at the moment the R series Awesome speakers but take up way too much room.
ID:	2568304   Click image for larger version
ID:	2568306   Click image for larger version
post #44 of 58 Old 05-18-2019, 11:42 AM
gajCA's Avatar
Liked: 5791
[quote=Raider Stagger;58065542]
Ha ha ha.
So, no center speaker?
Budget?
Why not re use your current Denon or is it just 5.1?
You may have answered this already but where are you located?
gajCA is offline
post #45 of 58 Old 05-18-2019, 12:07 PM
Quoted: 26 Post(s)
Liked: 4
[quote=gajCA;58065624]
Ha ha ha.
Budget?
yes center speaker as well,
4,000 well so we took a loan for home improvement, a patio for 6800 -15,000 leaves = 8,200
drywall and finish $4000 leaves 4,200 ( this is for entire basement)
electrical we are doing so 1300 for fixtures, leaves $2,900
plus 8,000 we had saved up so I would say 3,000 to 4,000 for theater sounds
but not really decided yet potentially 6,000 still have pool table , seating,
The Denon I have now is 5.1 dolby digital about 6 years old
The below diagram is what I was thinking. Let me know what your thoughts are.
Name:	speaker diagram.jpg
post #46 of 58 Old 05-18-2019, 12:09 PM
Quoted: 26 Post(s)
Liked: 4
[quote=Raider Stagger;58065738]
maybe for budget a 7.2 would be best ?
post #47 of 58 Old 05-18-2019, 12:24 PM
gajCA's Avatar
Liked: 5791
[quote=Raider Stagger;58065754]
Let's see what 5.1.4 comes to.
Denon 4400 from Amazon is $899
HSU VTF2 sub is $607
Four Polk Polk Audio RC60i from Crutchfield are $260
Five Chane A2.4s are $1245 + $125 shipping when they come back in stock "soon."
So that's $3136 for 5.1.4.
Add a second HSU if you think you need it and your total is $3743 for 5.2.4 with dynamic speakers, excellent subs and great EQ in the receiver that dials in dual subs.
If you want to step up to the RSL in ceilings your total moves up to $3983.
gajCA is offline
post #48 of 58 Old 05-18-2019, 12:42 PM
Quoted: 26 Post(s)
Liked: 4
[quote=gajCA;58065822]
Perfect now what are rsl lol
post #49 of 58 Old 05-18-2019, 12:47 PM
gajCA's Avatar
Liked: 5791
[quote=Raider Stagger;58065890]
Sorry, these:
https://rslspeakers.com/c34e-ceiling-speaker/
https://hometheaterreview.com/rsl-c3...aker-reviewed/
I must tell you I am recommending speakers I've never heard but they are one of the most "I bought these and I love them" speakers on AVS in their price range.
I have heard the smaller HSU VTF1 sub and it was very well made and sounded very very good and the VTF2 is better still and is another AVS "I bought this and I love it" product in your price range.
Denon with Audyssey XT32 is a no brainer and one member did 5.1.4 Atmos with Polk level in ceilings and then switched to the RSLs but wondered if any "improvement" in the Atmos sound was his imagination as the cheaper speakers worked very well for the minimal demands of Atmos effects, (in his opinion).
gajCA is offline
post #50 of 58 Old 05-18-2019, 04:59 PM
Quoted: 26 Post(s)
Liked: 4
[quote=gajCA;58065910]
Sorry, these:
this is my sub I am using right now
https://www.amazon.com/gp/slredirect...getName=sp_atf
not bad
post #51 of 58 Old 05-18-2019, 05:10 PM
Quoted: 26 Post(s)
Liked: 4
Sorry, these:
here is the receiver I guess it is a 7.1
Denon AVR790 7.1-Channel Multi-Zone Home Theater Receiver with 1080p HDMI Connectivity
I t worked so far but this is not the same setup I used before this is a dedicated theater room
Oh by the way I'm in Iowa.
https://www.amazon.com/Denon-AVR790-...r=8-3-fkmrnull
post #52 of 58 Old 05-18-2019, 06:29 PM
Quoted: 26 Post(s)
Liked: 4
Sorry, these:
Here is the Crappy little projector I was using for watching movies and games.
LOL so bad got 1 star on Amazon
https://www.amazon.com/Acer-MR-JL811.../dp/B015JVG59E
post #53 of 58 Old 05-18-2019, 07:03 PM
Quoted: 26 Post(s)
Liked: 4
Dude Is this website Legit?
www.accessories4less.com
A 110watt x 7.2 Marantz receiver 799.99?
post #54 of 58 Old 05-18-2019, 08:21 PM
Liked: 25
I’ve personally bought from ACC4LESS a half dozen times or more and have zero complaints and completely happy with the products I’ve purchased from them.
gbus is offline
post #55 of 58 Old 05-19-2019, 09:48 AM
gajCA's Avatar
Liked: 5791
[quote=Raider Stagger;58066766]
not bad
That's a decent little music sub.
Sadly there are no local makers of high value speakers or subs near Iowa.
gajCA is offline
post #56 of 58 Old 05-19-2019, 09:53 AM
gajCA's Avatar
Liked: 5791
Most of their receivers are factory refurbished which can mean anything from a unit checked and reboxed or repaired and reboxed and many AVS members have bought receivers from them with no complaints.
I bought a factory refurb sub from them when I wanted a second identical one in my secondary room and while the box was a bit beat up the sub looks and works every bit as well as the identical new one I have.
The only thing to caution about them is their very restrictive return policies where you pay full boat on shipping both ways plus a restocking fee so when it comes to speakers I'd only buy a speaker from them I had heard and liked as returns can cost as much as a pair of inexpensive speakers.
gajCA is offline
post #57 of 58 Old 05-19-2019, 10:01 AM
gajCA's Avatar
Liked: 5791
[quote=Raider Stagger;58067022]
Another LCR speaker to consider is this well priced RBH speaker.
https://rbhsound.com/r515.php
https://www.audioholics.com/bookshel...eviews/rbh-r-5
Another setup worth considering are Ascend 170s in the corners with a 340 center.
http://www.ascendacoustics.com/pages.../spkrlist.html
gajCA is offline
post #58 of 58 Old 05-29-2019, 09:57 PM
Quoted: 26 Post(s)
Liked: 4
[quote=gajCA;58069096]
What is everyones thoughts on MICA's or INWALLTECH? or the Polk Audio
https://www.amazon.com/Polk-Audio-Va...ronics&sr=1-17
Reply Speakers
