Setting up home theater need help with speakers - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 57 Old 05-15-2019, 04:07 AM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
Hey crew! So I'm setting up my theater. The room size will be 12x13 with 8 foot ceilings. I don't want to go to large with speakers and also don't want to be too small. My Fl FR and Sr SL speakers all have to be in wall. I was looking at these Polk in wall speakers which come in 5.25" 6.5" 8" and I'm not sure if either of these would be enough. I'm close to buying and this is the list I have. Please please make recommendations
4-Polk Audio RC85i 2-way In-wall Speaker
1-BIC America F12 12-Inch 475-Watt Front Firing
1-Polk Audio Signature Series S35 Center Channel
Denon AVR-X1500H Receiver
Sent from my XT1650 using Tapatalk
ad10sk8er is offline
post #2 of 57 Old 05-15-2019, 09:54 AM
gajCA's Avatar
Quoted: 8429 Post(s)
Liked: 5623
All that looks good other than the subwoofer.
I'd also recommend the RC55i or RC65i for that small a space as their smaller woofers will have better off axis performance which is something you want in an in wall speaker especially.
Are any of these subs within budget?
PORTED SUBWOOFERS $600 AND BELOW, DELIVERED
NOTE:
*THE LARGER PORTED SUBS DELIVER AT LEAST 40% MORE SOUND PRESSURE LEVEL
THAN THE SAME BRAND'S SEALED VERSION WITH SAME SIZE WOOFER AND AMP
*IF LOOKING AT LARGER/MORE EXPENSIVE SUBWOOFERS ADD PSA TO THE LIST OF BRANDS
*IF YOU ARE NOT AN ACTION MOVIE FAN A SUBWOOFER WITH 22-30HZ EXTENSION WOULD BE FINE
*FOR MUSIC A 30HZ SUB IS A FINE CHOICE
*BEFORE BUYING MAKE A CARDBOARD CUTOUT OF THE SIZE OF THE SUB TO MAKE SURE IT IS NOT TOO LARGE FOR YOU
Specs are from the manufacturer unless noted otherwise.
Warranty
for AMP
2 years 350watts =15w16h17d= 40 lbs 10" [30hz] $399 RSL SPEEDWOOFER 10S, (extension from Sound & Vision review)
2 years 250watts =15w19h17d= 42 lbs 10" [25hz] $455 HSU VTF 1 MK3 (extension from Audioholics review)
5 years 300watts =15w19h20d= 46 lbs 10" [18hz] $499 SVS PB1000, (extension from Sound & Vision Review)
5 years 500watts =15w19h20d= 72 lbs 10" [20hz] $500 MONOPRICE MONOLITH THX 10"
3 years 300watts =16w22h21d= 69 lbs* 12" [19hz] $569 RHYTHMIK LV12F
2 years 350watts =15w21h22d= 62 lbs 12" [18hz] $607 HSU VTF2 MK5, (extension from Audioholics review)
* = shipping weight
Geoff A. J., California
gajCA is offline
post #3 of 57 Old 05-15-2019, 10:01 AM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
Hey I reallyappreciate the reply so I found out those speakers wouldn't fit where I need them for FL and FR ak actually ordered the Audio 265-RT 3-Way in-Wall Speakers. I wouldn't want to spend too much on a sub at the moment. I do like action movies,gaming,and music. What is wrong with that particular sub?
post #4 of 57 Old 05-15-2019, 10:10 AM
gajCA's Avatar
Liked: 5623
Those are better in walls for sure.
Compared to the subs I listed it is a bit "one note" but some AVS member like BIC subs.
This would be a better alternative unless it is still too much at $299.
https://www.amazon.com/JBL-High-Perf...93993829&psc=1
gajCA is offline
post #5 of 57 Old 05-15-2019, 10:27 AM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
If I can I keep sub cost around $300 I'd be happy. That's a nice sub I'll definitely consider that. You think the 8" Polk in wall speakers will be good for the surrounds or should I also get the 3 way ones that match front? I will be doing 7.1 for now just to get going eventually well be 9 1 atmis
post #6 of 57 Old 05-15-2019, 10:28 AM
Quoted: 408 Post(s)
Liked: 304
All the subs Geoff recommended would be better options than BIC sub. If budget is a major concern here are a couple of options from Boston Acoustic and Yamaha. In the case of the Yamaha sub, I would get 2 of them.
https://www.accessories4less.com/mak...s-black/1.html
https://www.accessories4less.com/mak...r-black/1.html
Rgarc is offline
post #7 of 57 Old 05-15-2019, 10:29 AM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
I see some reliability issues with that sub
post #8 of 57 Old 05-15-2019, 10:49 AM
gajCA's Avatar
Liked: 5623
Which sub?
I would stay away from 8" in walls in any room but especially a small room.
gajCA is offline
post #9 of 57 Old 05-15-2019, 11:14 AM
pase22's Avatar
Quoted: 2905 Post(s)
Liked: 2405
If you can go to $400 ($399), the RSL Speedwoofer would be much better than the Bic. I own a Bic F-12 and it's boomy and not very accurate. Could do ok for movies in a smaller room, but there are much better subs available.
https://rslspeakers.com/products/rsl-speedwoofer-10s/
BluesDaddy56 likes this.
Kef Q100 FL/FR,SL/SR, Q200C, SVS SB-2000, Denon AVR-X3400H, , Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #10 of 57 Old 05-15-2019, 12:20 PM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
Originally Posted by gajCA View Post
Which sub?
The jbl
post #11 of 57 Old 05-15-2019, 12:21 PM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
Alright so the 6.5" in wall polks should be option than the 8s .... Should I go with the 5.25s?
post #12 of 57 Old 05-15-2019, 12:27 PM
gajCA's Avatar
Liked: 5623
The jbl
The vast majority of those "failed early" reviews are from 2015 and before.
gajCA is offline
post #13 of 57 Old 05-15-2019, 12:31 PM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
Now to decide on the jbl or speedwoofer 10s they both look solid. Ugh what to do
post #14 of 57 Old 05-15-2019, 12:32 PM
gajCA's Avatar
Liked: 5623
Between those two the RSL every day of the week and twice on Sundays!
BluesDaddy56 and RayGuy like this.
gajCA is offline
post #15 of 57 Old 05-15-2019, 12:38 PM
RayGuy's Avatar
Quoted: 2433 Post(s)
Liked: 2204
RSL and don't look back.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #16 of 57 Old 05-15-2019, 01:06 PM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
you guys are killing me hahaha looks like I'm going to go with the rsl. Don't wanna buy something else and be unhappy with it, done that too many times
post #17 of 57 Old 05-15-2019, 01:08 PM
pase22's Avatar
Liked: 2405
RSL Speedwoofer, no contest!
pase22 is offline
post #18 of 57 Old 05-15-2019, 01:14 PM
pase22's Avatar
Liked: 2405
That's exactly why we're trying to steer you away from the Bic.
If you can get the 6.5" speakers, I'd go with those. The 5.25's would be fine for surrounds though.
pase22 is offline
post #19 of 57 Old 05-15-2019, 02:07 PM
Quoted: 22 Post(s)
Liked: 3
Help with speakers system for Home Theatre
My Room for Home Theater is 23 long x 14 wide.
I recently added a soffet the wall with the Insulation is where the screen will be.
What Speakers do you suggest doing, doing In-Wall speakers in columns was looking at
Klipsch-R-5502
or
Polk-Audio-RC85i-2-Way-Speakers
Thoughts?
Thanks for your assistance.
Been reading most of the builds here excited to go on this theater journey......Wife is not LOL
Raider Stagger is offline
post #20 of 57 Old 05-15-2019, 02:10 PM
gajCA's Avatar
Liked: 5623
Good news if YOU think it under delivers, free return shipping.
But I suspect you will be very pleased.
"I can fully endorse David Vaughn’s judgment last year that the Speedwoofer 10S is a cut-rate superstar. RSL’s 10-incher delivered unexpected slam down well below 35 Hz on soundtrack cues such as Apollo 13’s blast-off, which it delivered with impressive scale—especially given that my frame of reference is a hulking SVS PC-12 Ultra.
And on material even lower, such as a hi-res file of a Buxtehude pipe-organ chorale setting with a low G pedal tone at about 26 Hz, musically productive fundamental tone was perfectly audible.
One of my favorite subwoofer tests is Lou Reed’s classic “Walk on the Wild Side” played at reference-level-plus—with the front speakers disconnected. A prominently mixed string bass (the lower of the track’s two basses) slides obligingly back and forth between D and G (roughly 75 and 50 Hz), a range that will encompass the maximum output of nearly any subwoofer. Thus, port chuffing, peak/dipping, slapping, or cone breakup will be comparatively easy to hear. The Speedwoofer 10S displayed modest port noise—but only at levels beginning approximately 5 dB above THX reference, a result that earns very high marks in my book and makes the noise entirely inaudible in a fullsystem setting.
I had to work hard to stress it."
Read more at https://www.soundandvision.com/conte...GSAo0ydlYYz.99
gajCA is offline
post #21 of 57 Old 05-15-2019, 02:21 PM
Quoted: 22 Post(s)
Liked: 3
My electrical I'm doing, Drywall and mud and tape is around $4,000 but this is for entire basement, and bathroom with wall I am removing to get a pool table downstairs in bar room.
post #22 of 57 Old 05-15-2019, 02:29 PM
gajCA's Avatar
Liked: 5623
Klipsch-R-5502
or
Thoughts?
I would most definitely not buy any Klipsch R series as they are more hated than loved on AVS for being quite shrill so if you think you might buy them you need to listen to some R series cabinet speakers before pulling the trigger.
The Polks are not in that camp and are a good option but not when you can get Revel for a similar price with a better choice of a 6.5" woofer.
https://www.crutchfield.com/p_265W26...63.html?tp=192
These would also be a better choice albeit at a slightly higher price point.
https://www.crutchfield.com/p_107265...RT.html?tp=192
gajCA is offline
post #23 of 57 Old 05-15-2019, 02:32 PM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
Klipsch-R-5502
or
Thoughts?
Looks like what I'm doing just bigger
post #24 of 57 Old 05-15-2019, 02:37 PM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
Ordered 6.5" in wall speakers fir surrounds and the taller 3 ways for front and pilk signature s35 center channel. Haven't ordered sub yet
gajCA likes this.
post #25 of 57 Old 05-15-2019, 02:51 PM
Quoted: 22 Post(s)
Liked: 3
[QUOTE=gajCA;58053080]I would most definitely not buy any Klipsch R series as they are more hated than loved on AVS for being quite shrill so if you think you might buy them you need to listen to some R series cabinet speakers before pulling the trigger.
Polk-Audio-265- ARE $140 on Amazon lol
post #26 of 57 Old 05-15-2019, 03:08 PM
Quoted: 22 Post(s)
Liked: 3
I have Cerwin Vega R series and wow does it rock but they are huge and bulky and weigh a ton
post #27 of 57 Old 05-16-2019, 04:09 AM - Thread Starter
ad10sk8er's Avatar
Quoted: 22 Post(s)
Liked: 3
Anyone have why experience or info on MartinLogan Dynamo 500 subwoofer? Pretty set on the rsl speedwoofer but if I b save a few bucks that be awesome
post #28 of 57 Old 05-16-2019, 09:46 AM
gajCA's Avatar
Liked: 5623
Martin Logan makes good subs that are usually overpriced at full msrp but worth considering when discounted.
It has about 1/3 the power of the RSL though so would "run out of steam" earlier but good choice for smaller rooms with modest volume levels required.
3 years 120watts =13w15h16d= 29 lbs 10" [29hz] $250 MARTIN LOGAN DYNAMO 500, limited time offer
gajCA is offline
post #29 of 57 Old 05-16-2019, 09:50 AM
gajCA's Avatar
Liked: 5623
[quote=Raider Stagger;58053206]
$312 on Amazon today which is lower than Crutchfield but not $140.
gajCA is offline
post #30 of 57 Old 05-16-2019, 11:11 AM
RayGuy's Avatar
Liked: 2204
RSL Speedwoofer 10s ...................... Martin Logan Dynamo 500
Reply Speakers
