Does The Sleeve Of A Banana Plug Conduct Electricity? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bobknavs
post #1 of 5 Old 05-15-2019, 09:03 PM - Thread Starter
Quoted: 56 Post(s)
Liked: 5
I have some 90 degree angle Nakamichi banana plugs connected to my speakers that are on speaker stands. Unfortunately, the clearance in back is very minimal, which is why I needed the 90 degree plugs. They work, but the outer sleeve of each plug is touching the metal speaker pole.
I'm wondering if the outer sleeve of the banana plug conducts a signal? Will this setup cause a short?
ID:	2567380   Click image for larger version
djxpress is online now
post #2 of 5 Old 05-15-2019, 09:10 PM
bobknavs's Avatar
Quoted: 2042 Post(s)
Liked: 1432
Dunno.
Maybe it'd be worth a $10 investment in a cheap DVM (digital volt meter), which could be used to check it.
My guess? The metal shell of the banana plug is connected to the plug. The paint on the pole may save you, but you may not wish to rely on that. Black electrical tape, maybe?
BuddTX likes this.
bobknavs is online now
post #3 of 5 Old 05-15-2019, 09:26 PM - Thread Starter
Quoted: 56 Post(s)
Liked: 5
I literally didn't even think of that. 5 minutes later and a quick fix. Thanks!
post #4 of 5 Old 05-16-2019, 08:26 AM
function12's Avatar
Quoted: 40 Post(s)
Liked: 35
Yes, if wired correctly most of them should be negative voltage or ground for one leg and positive for the other. It would not be a good idea for them to be touching other metal parts. Painted parts don't always conduct electricity but over time vibrations can wear away the paint. An easy fix would be a few wraps of electrical tape.
function12 is offline
post #5 of 5 Old 05-16-2019, 02:49 PM
bobknavs's Avatar
Liked: 1432
Originally Posted by function12 View Post
Yes, if wired correctly most of them should be negative voltage or ground.
Really?
My speaker wires are unshielded.
Reply Speakers
