AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   Looking for Guidance on Front Speakers (https://www.avsforum.com/forum/89-speakers/3069068-looking-guidance-front-speakers.html)
Yossarian381 05-23-2019 07:34 AM
Hi all. We are moving into a new place in a few weeks and I am trying to figure what speakers to put in the front of our home theater setup. The room is not especially big -- maybe 15x15, and it opens up into our dining area. Like many posters on these fora, I have certain domestic constraints that limit my ability to go all out. As a result, I am focusing on bookshelf speakers, preferably that I can wall mount, or possibly place on top of a TV stand on either side of a center channel. I am not too worried about the rear surrounds. They have to be white, and they can be relatively inexpensive. The TV will be wall mounted, so the TV stand will have an unobstructed top for speaker placement.
My current setup is as follows:
Samsung 65" Q6F
Yamaha RX-A550 or Onkyo TX-NR646 (this is in the exercise area currently)
F/R Cambridge Soundworks Newton MC150s
Center Cambridge Soundworks Newton MC300
Rear Surrounds Cambridge Soundworks Newton S100s
Subwoofer Cambridge Soundworks BassCube 8
All of the speakers date to around 2003. They are fine, but they feel tired and underwhelming. I don't particularly care for the subwoofer.
I think I will go with a Dayton Audio Sub 1200. For the room, and my needs, that feels more than adequate.
The speakers are a different story. I am all over the place. These are the ones I am considering:
-Canton Plus GXL.3
-ELAC Debut 2.0 5.2
-QAcoustics 3020
-Wharfedale Diamond 10.1
-NHT SuperOne 2.1
-Boston Acoustics A26
For the Center speaker, I would use a center speaker that corresponds with the F/R.
All of these speakers are relatively similar price points, plus or minus $50. Do people have any thoughts on these? Are there other speakers you might also recommend? I have scoured Craigslist and Facebook and not seen anything overwhelming. Someone has a pair of used ELAC Debut B6 for $250, but I am thinking the B6 is overkill for my situation, and also not a great price.
I appreciate any guidance you guys may have.
Yossarian381 05-23-2019 08:49 AM
An addendum to my prior post. There is also a set of Emotiva B1s and C1 for $400 that is available near me.
RayGuy 05-23-2019 09:52 AM
Yeah, add Emotiva and Chane to the list ...
You have been living with a very warm set of speakers for a long time, so your ears are going to need some time to adjust to newer, more open, speakers. Have you done any listening? If so, anything appeal, or not?
Yossarian381 05-23-2019 10:08 AM
Emotiva is also on my list. As I mentioned, there is someone selling them near me. I haven't heard most of the speakers I identified. I have heard the Boston Acoustics and some "higher end" Polks and midlevel Klipsch. I had also been using a set of JBL LX500s for several years, which I liked at the time, but they are shot. And those were used more for music than home theater.
gajCA 05-23-2019 10:38 AM
This might be a better sub choice.
https://www.accessories4less.com/mak...s-black/1.html
Yossarian381 05-24-2019 09:24 AM
[quote=gajCA;58089088]This might be a better sub choice.
Thanks. I assume 10" is plenty for a small space?
Any thoughts on ELAC vs Emotiva?
gajCA 05-24-2019 09:35 AM
[quote=Yossarian381;58093378]
Yes, a 10" 100 watt ported sub with 250 watt peak power should be fine in a small space when your budget is under $200.
Many fans of both Elac and Emotiva though the original Debut Elacs received more criticism than the newer Elac 2.0 Debut series.
Quite a few found the original Elac Debuts to be a bit too "warm" and not detailed enough.
Yossarian381 05-24-2019 10:09 AM
[quote=gajCA;58093416]
Thanks. There is a person selling a HSU VTF-2 for $350. I know it is a good deal, but in a 15 x 15 room, will it be overkill, particularly with ELACs, Emotivas or similar speakers?
gajCA 05-24-2019 10:19 AM
[quote=Yossarian381;58093560]
How old is the VTF2?
If under 5 years old that seems like a great deal and it will be fine in a room your size unless the cabinet is too darned big. =15w21h22d=
It has various EQ settings to "tune" the sub to your room which is great.
Here's the size of the Boston Acoustics sub: (H x W x D) 14-1/16 x 14-11/16 x 16-3/8”
Yossarian381 05-24-2019 10:41 AM
[quote=gajCA;58093612]
At least 5 years old, but "hardly used."
pase22 05-24-2019 10:42 AM
Not overkill. You can control how much output you want. The various tuning options make it ideal for both music and movies. Just make sure it's in good condition and nothing rattles at higher volume. If everything checks out and the sub is only a few years old, It's a reasonable asking price, though you can always offer him less to see if he bites.
gajCA 05-24-2019 10:52 AM
[quote=Yossarian381;58093696]
I've never had a sub amp fail within 9 years but you might want to start a thread in the AVS Subwoofer section titled "how long has your HSU VTF2 amp lasted" or something like that.
I'd also call HSU so you are aware how much an amp repair or replacement would cost.
Good luck.
BTW, my sister in law has the first version of the HSU VTF1 and it might be 10 years old, if not older, and it's still going strong.
wrat 05-24-2019 11:59 AM
The VTF is a monster in a good way
Yossarian381 05-24-2019 01:49 PM
I was able to get new, open box Elac Debut 2.0 B6.2 for $185 all in.
Now to negotiate for the subwoofer.
Question on the center channel. Is that much more compelling to go with the Debut 2.0 C6.2 as opposed to the Debut 2.0 C5.2?
pase22 05-24-2019 02:28 PM
If you have space for the 6.2 go with the 6.2. The center is the workhorse of an HT setup carrying most of the dialogue.
gajCA 05-24-2019 02:30 PM
Assuming you have the space to fit the larger center by all means go for it.
Yossarian381 05-25-2019 07:29 AM
I have the space if I get a wide enough TV stand. The Head of Domestic Relations has decreed that any front speakers shall be required to sit on the top of the TV stand. It's not ideal, but I can do that and still have some spacing between the speakers as I only have 80 inches to work with total, and can get a 70-74 inch width TV stand.
Also, the guy selling the HSU will take $300 for it. Assuming it still sounds as it should, that is a solid price, even if it is 5-10 years old?
gajCA 05-25-2019 07:37 AM
Ask in the sub section how long their VTF2s have lasted with the original amp and how much it cost to repair if it failed and then decide.
$300 sounds like a lot when $400 buys you a brand new RSL subwoofer that likely will sound just as good to most people.
Yes, a new VTF2 is worth the extra $200 vs the RSL for those wanting more bass or have larger rooms but a used sub that is over 5 years old should be less than half the cost of a new one IMHO.
Soulburner 05-25-2019 10:36 PM
Nothing worse than having an underwhelming sub.
Get the HSU and forget about the lesser subs. You will be really glad you did.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
