Speaker cable - AVS Forum | Home Theater Discussions And Reviews
 85Likes
post #1 of 131 Old 05-23-2019, 08:51 AM - Thread Starter
Quoted: 121 Post(s)
Speaker cable
Does it really matter what speaker cable you use?
LOL
Whats the best bargain type speaker cable?
The economical Best Buy stuff with banana plugs work ok???
redrovermiami is offline
post #2 of 131 Old 05-23-2019, 09:01 AM
Quoted: 2095 Post(s)
Liked: 1720
Best Buy stuff is far from economical.
Head to amazon and buy a 100ft roll of 14 gauge OFC from mediabridge or Monoprice. Best cable you can get for the price.
Leave it at 8 ohms and call it a day :)
Russdawg1 is offline
post #3 of 131 Old 05-23-2019, 09:20 AM
Blacklightning's Avatar
Quoted: 1000 Post(s)
Liked: 857
^correct
and no need for Banana plugs unless you are planing on switching out your equipment all the time.
Soulburner, Philip To and Lp85253 like this.
Blacklightning is offline
post #4 of 131 Old 05-23-2019, 09:55 AM
modenacart's Avatar
Quoted: 282 Post(s)
Liked: 181
Any solid copper stranded wire will be fine as long as you follow the length to gauge recommendation. You can use clad but you will need to increase the wire diameter to account for losses.
-To be an audiophile you must abandon all research and science.
modenacart is offline
post #5 of 131 Old 05-23-2019, 09:58 AM
bobknavs's Avatar
Quoted: 2897 Post(s)
Liked: 2094
I agree that cables tend to be overpriced at Best Buy, even if you avoid Monster Cables. Or the more expensive Audioquest cables they sell in their Magnolia stores.
Buy the bare stuff. Add a good quality wire stripper - maybe $10-15US. Avoid CCA (copper clad aluminum), like some of the Amazon Basics cable. There is nothing basically wrong with it, but it has lower conductivity than copper: a 12 gauge CCA cable is roughly equivalent to 14 gauge copper. (Because of the way gauge is defined, add 2 to CCA to get the equivalent copper.) CCA isn't enough cheaper than copper to make it attractive.
I like banana plugs, as I don't have easy access to the rear of my receiver. I like Sewell Deadbolts or the similar ones from Mediabridge. (Toll-less connection, no setscrews.) For the speaker ends of the cables I like Mediabridge 45° spade plugs; they can't compress (and loosen) like bananas. (Too wide for use at the AVR end, though.)
As for what gauge you need, here's a guide: https://www.audioholics.com/audio-vi...er-cable-gauge
Take any advice (including this) with a grain of sale. Speaker cables are one of the favorite subjects of debate. Remember that some audiophiles claim to be able to hear differences due to cheater cords (the cord that connects the electric power from the wall to the receiver or amplifier). You can spend hundreds, or thousands, of dollars on a single cheater cord.
pjp and scionracing like this.
bobknavs is offline
post #6 of 131 Old 05-23-2019, 10:06 AM
pjp
pjp's Avatar
Quoted: 972 Post(s)
Liked: 534
Agree with the above. Best Buy has very competitive prices on components, but they charge a lot for accessories and cables. Better to buy online from someplace like Amazon. As several have said, just be sure to get wire that is "oxygen free" solid copper wires rather than copper clad.
I had my first experience with copper clad speaker wire and, although it conducts fine when all is well, the build quality is terrible. You can feel the aluminum core when you twist the strands of raw wire after stripping. I guess I had only dealt with OFC before, so now I finally understand the copper clad concerns. Copper clad will still work, but it's better to avoid it.
Lp85253 likes this.
pjp is offline
post #7 of 131 Old 05-23-2019, 10:12 AM
pase22's Avatar
Quoted: 3862 Post(s)
Liked: 3321
LOL
This is basically all you'd need for a standard setup. Banana plugs are not a must have, however they do make installation a lot easier, especially on the receiver end.
https://www.amazon.com/AmazonBasics-...s%2C138&sr=8-6
https://www.amazon.com/AmazonBasics-...s%2C144&sr=8-7
scionracing likes this.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Emotiva A-300, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #8 of 131 Old 05-23-2019, 10:14 AM
Quoted: 2553 Post(s)
Liked: 2374
i agree with all of the above .. get affordable wire from amazon or walmart .. i don't even mind the copper over aluminum .. to me just get whatever works for short runs (under 20 ft.) .. there just isn't enough difference to worry about it...now if it's longer runs or in wall things change.. longer runs need better conductivity and in wall needs better shielding and sometimes solid wire..
YAMAHA TSR 5790.. front l/r Dennis Murphy modded emotiva b1's ..BIC v1220.....Emotiva basx10.... infinity alpha 20 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. ascend cbm 170 se... kef q100 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #9 of 131 Old 05-23-2019, 10:46 AM - Thread Starter
Quoted: 121 Post(s)
I have some 14g wire that Ive been using but Im getting new speakers figured Id do it right...I bought the plugs though
Thanks for the tip!!!
If I need more wiring Ill def get the one you recommended!
post #10 of 131 Old 05-23-2019, 12:32 PM
nonstopdoc1's Avatar
Quoted: 923 Post(s)
Liked: 394
I almost always go to Monoprice for all my cable needs. If they don't have something I am looking for or I need something in a hurry than Amazon Prime is my backup.
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | JBL SDP-55 | Nord NC500 | ATI AT528NC | Procella P8/P5V | Revel C763L | Monolith 12" x4
Living Room - LG OLED 65" | Denon X4400H | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia 20 CC | Polk Surrounds | Rythmik FV15HP x2
nonstopdoc1 is online now
post #11 of 131 Old 05-23-2019, 01:23 PM
Quoted: 356 Post(s)
Liked: 106
Canare makes quite good cables. Another good alternative is your local electric appliance shop - bad cables for house wiring are threat to safety and it is more or less regulated, so you know what you are buying.
But I would take canare over them, for bith signal and speaker cables.
Rex Anderson and gbus like this.
aats is online now
post #12 of 131 Old 05-23-2019, 02:10 PM
Quoted: 1441 Post(s)
Liked: 1666
I worked as a professional recording and live sound engineer for 34 years. I use Canare or Belden speaker cable and get it made in custom lengths by Blue Jeans Cable. I like the sonic weld termination they use.
https://www.bluejeanscable.com/store/speaker/index.htm
KenM10759 and gbus like this.
Rex Anderson is online now
post #13 of 131 Old 05-23-2019, 07:29 PM
brian6751's Avatar
Quoted: 1759 Post(s)
Liked: 1789
I prefer these banana plugs to any others
https://rover.ebay.com/rover/0/0/0?m...2F162096760910
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is online now
post #14 of 131 Old 05-24-2019, 07:34 AM - Thread Starter
Quoted: 121 Post(s)
I dont know what cable I have...I think I got it at Best Buy about 5 years ago. Its 14g wiring. I got the banana plugs from Amazon that was suggested earlier in this thread.
One guy I spoke to said that he custom solders the plugs on. Said you have to be careful when you use the plugs etc you can short out stuff.
modenacart likes this.
post #15 of 131 Old 05-24-2019, 07:40 AM
modenacart's Avatar
Quoted: 282 Post(s)
Liked: 181
That is why I like bare wire but there is a risk of strands shorting across terminals too and causing the receiver to go into protect mode.
post #16 of 131 Old 05-24-2019, 07:50 AM
pjp
pjp's Avatar
Quoted: 972 Post(s)
Liked: 534
That shorting possibility is why I only use "paired" banana plugs. It is very easy to bend single banana plugs at the pin if you move the speaker or amp without realizing the speaker cable is taut because there is a lot of leverage from where the wire attaches to the plug and the (necessarily) hollow pins take very little force to bend. I seem to be the only person on AVS concerned about that (last time I mentioned this I heard crickets).
I agree with comments that connecting speaker wire directly to the posts is at least as good as, and often better than, using banana plugs ("less is more" when it comes to connections).
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
(The color coding is nice also -- red is used for the right speaker, black for the left)
Lp85253 likes this.
pjp is offline
post #17 of 131 Old 05-24-2019, 08:37 AM
machavez00's Avatar
Quoted: 58 Post(s)
Liked: 112
According to the Audioholics chart I need to get some 16 or 14 gauge for my 6 ohm rear speakers. They’re about ten feet from my AVR.
Amazon shows 16 footers on the page, the max length is 9.8 feet in the drop down menu. The gauge is not shown, but they look like 14 or 12 gauge.
https://www.amazon.com/KK-ZB-ZB-Spea...YBR6SB2ZNSE243
I was thinking about getting these for my fronts.
https://www.amazon.com/dp/B01M641W3W...ing=UTF8&psc=1
machavez00 is offline
post #18 of 131 Old 05-24-2019, 08:39 AM - Thread Starter
Quoted: 121 Post(s)
My rears would be about needing 30 feet of cable each
post #19 of 131 Old 05-24-2019, 08:42 AM
Liked: 2374
12 or 14 gauge should be ok
post #20 of 131 Old 05-24-2019, 08:58 AM
pjp
pjp's Avatar
Quoted: 972 Post(s)
Liked: 534
It's very weird that they don't list the gauge, but it looks pretty thick (hard to tell how much is insulator and how much is wire). These look like a nice practical set of speaker wires. Pay attention to the connectors, the first pair looks like they slip into the binding post hole (rather than a banana plug) and the second set has bananas on one side and pins on the other.
pjp is offline
post #21 of 131 Old 05-24-2019, 10:56 AM
Quoted: 168 Post(s)
Liked: 42
Does it need to be 14AWG? 16AWG won't work?
Sent from my CLT-L04 using Tapatalk
boldventure is offline
post #22 of 131 Old 05-24-2019, 11:13 AM
machavez00's Avatar
Quoted: 58 Post(s)
Liked: 112
I ordered the banana to pin 3M pair. My AVR has banana plug for the fronts, and spring connections for the surround and center. My 301’s have spring connections, thus the banana to pin. When I replace the surround and center I will buy speakers that have banana terminals so I can use the 16 foot banana to pin. The center can use pin to pin.
post #23 of 131 Old 05-24-2019, 11:13 AM
pase22's Avatar
Liked: 3321
You can use 16awg, but you should follow the recommended gauge on the chart below if you have longer runs.
pase22 is offline
post #24 of 131 Old 05-24-2019, 11:18 AM
modenacart's Avatar
Quoted: 282 Post(s)
Liked: 181
If you use a higher gauge than recommend you risk distortion. It is your system so you can choose the higher gauge wire.
post #25 of 131 Old 05-24-2019, 11:18 AM
Quoted: 168 Post(s)
Liked: 42
My surround wire, the longest maybe 20ft
post #26 of 131 Old 05-24-2019, 11:21 AM
machavez00's Avatar
Quoted: 58 Post(s)
Liked: 112
Based on the Audioholics chart, 14 gauge for 6 ohm.
post #27 of 131 Old 05-24-2019, 11:41 AM
pase22's Avatar
Liked: 3321
I just used Amazon Basics 14awg for my entire setup. A 100ft roll ($35 CDN-$25 USD) was more than enough. My system suffers no loss in sound quality compared to the more expensive wire I had from Best buy years ago. If you have 16awg wire on hand use it. If buying new, the price difference between 16awg and 14awg is negligible so may as well get 14awg.
https://www.amazon.com/AmazonBasics-...gateway&sr=8-5
pase22 is offline
post #28 of 131 Old 05-24-2019, 02:35 PM
Kini62's Avatar
Quoted: 2948 Post(s)
Liked: 2827
LOL
Nope. Any wire that can pass the current needed over the required distance will result in the exact same speaker performance. There is no magic wire.
Lp85253 and pase22 like this.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #29 of 131 Old 05-24-2019, 10:41 PM
rbfastback's Avatar
Quoted: 77 Post(s)
Liked: 43
thanks for the good advice, i was just wondering the same thing
rbfastback is offline
post #30 of 131 Old 05-25-2019, 01:39 AM
Quoted: 356 Post(s)
Liked: 106
It's too vague description and is not true.
aats is online now
Reply Speakers
