HT System advice for $1500 budget with questions - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 74Likes
post #181 of 194 Old 06-16-2019, 04:53 PM
motrek's Avatar
Quoted: 372 Post(s)
Liked: 134
Originally Posted by d-rail34 View Post
I stand corrected, as I did use the wrong term to point out in regards to the mains what will happen by using those settings, so thanks for correcting. But it's still a bad idea, and NOT recommended for HT applications by pretty much everyone but YOU. The fact that you aren't able to see this is baffling.
Wait, what's a bad idea? Using LFE+Main? You think people should just use LFE? In other words, you think the only thing that should come out of a subwoofer is the LFE channel, i.e., some explosions when you're watching movies? You should never use a subwoofer for e.g. listening to music? That's insane. Nobody recommends that.
As for when he wants to listen to music, he can set it to "Stereo", which will output to LR/Sub, or "Pure Direct", which will output to just the LR at full range. This is all being done with the speakers set to small with a 80Hz x-over, and sub set to LFE. But I'm sure you will argue that too, so you have fun with that.
Nobody should have to set anything to anything special to listen to music. I'm not sure what you're suggesting or implying here.
motrek is online now
post #182 of 194 Old 06-16-2019, 05:40 PM
d-rail34's Avatar
Quoted: 375 Post(s)
Liked: 705
Again, to the OP...good luck. I hope you're able to get to where you want to be with your setup.
Darrell
You really should actually read the posts before you speak. It's really making you look even more ignorant than you really are when it comes to these applications.
Again...READ! It's not that hard to figure out.
There are these cool things on today's AVR's called "FEATURES" that you can use to do all kinds of crazy things. Like playing movies/music using different sound modes. Gee! What an awesome 21st century concept! Can't wait to here your BS take on that. Although, I'm sure it'll be the same old rhetoric that you used to argue using the AVR's HDMI ports to hook up all of your equipment to, because for whatever reason you say that's stupid (paraphrasing), and insisted on recommending to hook the components to the TV instead (Don't play dumb, because you know exactly what I'm talking about.). Why?? What the hell is wrong with streamlining things? You know, kinda like using the "Channel Level Settings" to tweak sub trim with the remote...??? AGAIN...WHAT AN AWESOME CONCEPT!!!
It's really unfortunate that common sense cannot be taught. I'm done here.
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon: AVR-X2400H/Hsu Research: HB-1 Bookshelfs (4)/Hsu Research: HC-1 Center (1)/SVS: PB12 Plus (1)/Samsung: UN65H7150/Sony: UBP-X800/PC: Built by D-Rail
Bedroom - Blose: Cinemate II GS 2.1/Sony: XBR49X800E/XBox: One S
d-rail34 is online now
post #183 of 194 Old 06-16-2019, 06:45 PM - Thread Starter
rbfastback's Avatar
Quoted: 55 Post(s)
Liked: 26
you definitely DO NOT want to set your sub to LFE+MAIN...unless you're running your speakers full range (Large), which is NOT RECOMMENDED whenever you're using a seperate sub to handle the low end. LFE+MAIN will will force your mains to output all of the lower frequencies while at the same time your sub is playing the exact same thing, and you have no control over your speakrs crossover settings. This will generally result in a muddy, audible mess. Hence the reason it's recommended to set your speakers to small, crossovers for your LCR to 80Hz, sub to LFE (120Hz default). If your surround's crossovers are set below 80Hz by Audyssey, then you can set those to 80Hz as well. Otherwise, if they're set by Audyssey to say 100-120Hz, just leave them be, as it is not recommended to lower the crossover frequencies. Only raise them from where Audyssey sets them.
i’m still learning and i see a lot of AVR’s can be different when it comes to the technical settings cuz i do know that for my denon that would not work the way your saying to do it.
your end goal is exactly right tho but for my avr the biggest difference is the speakers being set to small or large.
right now it’s setup LFE+MAIN with the towers set to SMALL with an 80Hz crossover (and yes a 120Hz default on the LFE+main setting)
i think in the past or other brand avr’s do this differently from what i’m reading.
for my model denon the sub WILL NOT work on just LFE alone.
this is so all the LFE plus the bass signals that are sent to the MAIN TOWERS will go to the sub that are under 80hz. freeing the towers to play with more power above the 80hz range.
if i were to change it to LARGE then the sub would still play all the LFE+MAIN stuff just like in the other scenario except he speakers would not have the crossover anymore and they would also play the same low frequency bass and like u say it would sound bad and muddy.
obviously i’ve learned it’s not a hard cut off with the 80Hz crossover but more of a gradual signal weakening or whatever u call it.
lastly i actually upped what audyssey set my crossover and setting since it was still muddy and too low of a cross to me.
it came back like 40hz for the center and mains were set to LARGE, so i had no cross for the towers.
basically the opposite of what i want and what u are saying is bad (for obvious reasons)
And one other piece of advice...it's always pretty handy to investigate the people that are giving you your information.
I say this to you only so that you can feel comfortable knowing that you got the best possible information to get the most enjoyment out of your gear.
So yeah, if you want to take his advice, by all means, go for it. I don't recommend that you do. But hey, what do I know? I'm not an Electrical Engineer after all.
i absolutely agree with most of this, i ALWAYS research what anyone tells me no matter how popular they are on the forum and i hope ppl do that for me on he forum i’m more knowledgeable.
anyone can be wrong just like u inadvertently were about deferent avr settings even tho the end result is exactly the same what should be done.
i always appreciate anyone’s post, wrong or right they took the time to give it to a random person like me.
it’s my job to pick through it and decided what parts i want to take out of it as good advice.
(most of the time ppl are arguing they are actually talking about the same thing and not understanding each other since they read so fast or skip over info)
most ppl admit they were wrong, or they just keep arguing...
motrek has been very helpful along the way and yes a few ppl including him and you have misspoken about a few small things here or there but who hasn’t in one post or another.
i will say out of all my hobbies this one leaves the most room to make mistakes or have a wrong setting easily, there is a lot about audio/visual to learn and no end to how much
rbfastback is online now
post #184 of 194 Old 06-16-2019, 06:50 PM - Thread Starter
rbfastback's Avatar
Quoted: 55 Post(s)
Liked: 26
Darrell
i’ve tried only LFE before and it turns iff the sub making it a 2.0/5.0
ppl are saying for my avr lfe only will not work if u want the sub
i called customer support too an looked up videos on the subject.
if u know another setting that will work if appreciate it and i’ll go try it right now.
edit for bad spelling
post #185 of 194 Old 06-16-2019, 07:34 PM
d-rail34's Avatar
Quoted: 375 Post(s)
Liked: 705
Not sure why you're not getting anything through your sub with setting on LFE, as that's what I have mine set to and it works just fine. Albeit, it's only running whenever it's called upon...which is what it's supposed to do with this setting. I have a Denon AVR as well.
Also, I've actually implemented the "Cascading Crossovers" method to mine. Meaning that I have my LCR/Sub all running @80Hz. This is done by not only setting the LCR to 80Hz, but also changing the LPF on the AVR & my sub's DSP settings to 80Hz as well. This gives me more mid-bass from the sub, and better clarity through the center channel & mains. This method was was recommended by the author of the sub calibration thread. I would get the LFE thing figured out before trying something like this though.
As for my error in terminology in the previous post, I just made the mistake of saying that it was "LFE+MAIN" rather than saying "Large" that will force the mains to play full bandwith. That's definitely on me for not proofing my post, but I was a tad bit flustered with his ignorance though...which is also on me for allowing that to happen. Oops! But the principal still stands that by setting it to LFE+MAIN it will still send frequencies that can/will muddy it up and create unecessary issues. Hence it not being recommended.
Here is an explanation of how all the LFE/LFE+MAIN functions work on Denon/Marantz AVR's to help clear up any/all confusion on the subject:
Denon/Marantz Subwoofer Bass Setting sends signal to sub like this,
LFE: LFE channel + Speaker channel signal below crossover for those set to Small
LFE+Mains: LFE channel + Speaker channel signal below crossover for those set to Small + Front L and R channel signal below LPF of LFE
If a speaker is set to Small and bass setting is LFE, anything below crossover is sent to sub. LPF of LFE makes no difference.
If L and R speaker is set to Small and bass setting is LFE+Mains, L, R signal above crossover but below LPF of LFE are duplicated to sub. This configuration is not recommended since most likely there will be a peak or null in the crossover to LPF of LFE frequency band.
If a speaker is set to Large, that speaker will get full range signal. If bass setting is LFE, the sub will not get any signal associated to the speaker channel. If the setting is LFE+Mains, the speaker will continue to get full range signal and at the same time L and R channel signal below LPF of LFE will additionally play on the sub.
Hope this helps,
Darrell
post #186 of 194 Old 06-16-2019, 08:20 PM - Thread Starter
rbfastback's Avatar
Quoted: 55 Post(s)
Liked: 26
i’ll look more into this tm for sure, seems other have had this problem too.
maybe it’s a year model change?
that makes perfect sense since now u don’t have the range in between the 80hz and 120hz anymore
so basically what you are saying for me right now is that above 80Hz and below 120Hz the bass signal is being duplicated (sub and L,R)
wile not as noticeable as the worst setting of: LFE+MAIN along with LARGE and the SUB it still can be more clear and less muddy loosing a little bass between 80-120 in the main L and R towers?
d-rail34 likes this.
post #187 of 194 Old 06-16-2019, 08:58 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1228
Nope, LFE+main does exactly what you're saying should be done. It causes the subwoofer to play the bass for all the channels. Then you set all your main speakers to small and they roll off the bass to the subwoofer.
If you just google "LFE+main" for a second you'll see that it does exactly what you're describing.
You don't want to set your subwoofer to "LFE" because then you're not going to hear any bass except what's played on the LFE channel, which is stupid, because there's lots of bass content in the other channels that you also want to hear.
I don't think you're understanding what I'm trying to describe, and what you are stating will happen with LFE only in fact will not happen that way.
It is the setting of "Small" for your speakers that sends all bass frequencies below your crossover point to the subwoofer. This is also known as bass management.
LFE means only the subwoofer will be used to play those frequencies. That is how it should be.
LFE + Main has your mains playing that content as well, also known as "double bass". You do not want that for all of the reasons discussed in this thread, so no need to repeat.
If you are using subwoofers, the correct settings are to set all speakers to small, and when the choice is between LFE or LFE + Main, choose LFE.
d-rail34 and rbfastback like this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is online now
post #188 of 194 Old 06-16-2019, 09:01 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1228
What is more likely:
• Everyone using the LFE only setting is insane and missing lots of bass, or
• Your understanding of this is incorrect
post #189 of 194 Old 06-17-2019, 02:47 AM
motrek's Avatar
Quoted: 372 Post(s)
Liked: 134
I see, you're recommending different settings for HT and music.
Correct, I don't know why you would play movies and music using different settings. Movies have a ton of music in them (ever heard of soundtracks?), and music often has sound effects (and sometimes spoken-word content) just like movies. If your audio settings are good for one and not the other, then that means you're spending a lot of time listening to sub-optimal audio. Common sense says this is bad... but I guess you think it's good for some reason?
Nope, I never actually recommended plugging things into the TV over plugging them into the receiver. I just said you can do either one and it's fine. A couple people (maybe you?) told me I was wrong and that you wouldn't be able to get surround sound if you plugged your HDMI sources into the TV, but it turns out I was right and I posted links to prove that I was right. If you really want to re-hash how I was right and other people were wrong, I mean, go ahead, I guess?
Right, I already explained how, from a technical/engineering standpoint, it's better to have a stronger signal going to a device and decrease the amount of amplification necessary. What about this do you disagree with? And we all agreed that running with a subwoofer trim of around -5 is a good middle ground between signal strength, amplifier power, and ability to adjust things via the receiver. It seems like you're the only person who's still hung up about this?
One can only hope.
post #190 of 194 Old 06-17-2019, 03:05 AM
motrek's Avatar
Quoted: 372 Post(s)
Liked: 134
Well I'll be the first to admit that I don't have a Denon receiver and that I have no experience with Denon receivers. What I've been going off of is the Denon web page about what these settings mean:
https://denon.custhelp.com/app/answe.../~/lfe---modes
So in other words, the "LFE" setting only sends the LFE content to the subwoofer. Which makes sense because it's called LFE. If you're not clear on this, LFE stands for Low Frequency Effects:
https://en.wikipedia.org/wiki/Low-frequency_effects
Basically it's the ".1" channel in "5.1" surround sound. It's generally used for exactly what it sounds like, i.e., effects, like explosions, lightning, spaceship sounds, etc. If you haven't listen to an LFE track in a movie, it's pretty interesting and I recommend it. What it generally doesn't include is the bass content from stuff like the movie soundtrack.
So if you've set up your system to only send the LFE channel to the subwoofer, and you've set your main speakers to small, then yeah, actually, you are missing out on the bass that's encoded in the other channels. As somebody pointed out earlier in this thread, a crossover is not a brick wall, and you will still hear deep bass frequencies out of your main speakers, but these frequencies will be much quieter than intended.
And it also means that if you're playing content that doesn't have an LFE channel (including a lot of TV shows and basically all music) then you will hear literally nothing out of your subwoofer. At least that's what's implied by the Denon web page that I linked to, and also by rbfastback's personal experience, since he posted about not hearing anything out of the subwoofer when it's set to LFE, which should be a fairly common occurrence.
So yeah, setting the subwoofer to LFE+main is really what you want, unless this Denon web page is grossly mistaken.
post #191 of 194 Old 06-17-2019, 05:44 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1228
I'm saying that is wrong. You do not want your mains playing LFE content, and you do not miss any bass signals with this setting. LFE + Main is not the default setting and is not used by anyone with a serious setup that has done their research.
Bass is sent to the sub channel(s) via bass management regardless of the above setting. The "main" part duplicates the signal at the mains, playing LFE content from them. If you read your link it explains that. It also states that the limitation you noted only applies if speakers are set to large. We are talking about using a subwoofer with bass management, aka "small".
I have 10 years experience with modern AVRs, including most of that time with Denons.
post #192 of 194 Old 06-17-2019, 10:22 AM
motrek's Avatar
Quoted: 372 Post(s)
Liked: 134
Well I have to admit that I basically ignored the text at the top of the link that I posted and went straight to the definitions of the settings at the bottom. I will agree that you're right about the LFE setting, i.e., when the subwoofer is set to LFE then it will also (confusingly) output the lower frequencies from the channels that are set to small. So I was wrong about that, sorry.
I do think you're mistaken about what LFE+main means though. Just to be sure I checked the actual manual for a Denon receiver:
https://www.google.com/url?sa=t&rct=...nT-xAquqklDzN7
If you go to page 91 of the manual, it explains things pretty clearly. More clearly than the web page that I linked to. LFE+main is actually the default and it means "The low range signal of all channels is added to the LFE signal output from the subwoofer." In other words, the subwoofer will play low-range content from the "large" channels in addition to the "small" channels. It does not affect the output of any of the main speakers.
So I agree, I can't think of a situation where anybody might want to use the LFE+main setting since it would cause the subwoofer to output the low frequency content that the "large" speakers are already outputting. I don't know why this setting would be the default. But the setting also literally doesn't make any difference to the OP since he said all his speakers are set to small anyway.
So that means if the OP is not hearing much from the subwoofer, maybe he accidentally set some of his mains to large instead of small? Something to check.
And going back to my original post that started all this mess, what I was trying to convey (instead of the name of a specific setting) is that the OP could try running his system with minimal audio processing on the receiver's part, as long as it was still doing bass management. I apparently don't know the names of the Denon settings and modes to accomplish this though.
post #193 of 194 Old 06-17-2019, 10:53 AM - Thread Starter
rbfastback's Avatar
Quoted: 55 Post(s)
Liked: 26
anyway so i factory reset my denon and started from scratch.
now the LFE works as everyone says it should.
again with speakers set to small and the X-over at 80Hz
trim on the sub is reading -5 now
not sure if i can tell a difference but i’m more then happy to leave it on what everyone says is the proper setting.
very excited about watching the Disney channel all day with my LFE setting right now haha
thanks for all the help everyone!
My next project is to figure out proper placement of the RS152 surround speakers (height on back wall and distance to left an right behind me)
i already ran the wire in the attic for them just gotta drill through now once i get the templates in place for the speakers
edit: also i ordered the AC Infinity AIRCOM T10 fan for the avr so that’s cool too
motrek, sigpig and d-rail34 like this.
post #194 of 194 Old 06-17-2019, 11:10 AM
motrek's Avatar
Quoted: 372 Post(s)
Liked: 134
Yeah after all this discussion it sounds like you might have had some of your speakers set to large somehow. Glad it's all sorted now.
Placement of surround speakers is probably the hardest part of any of this. If you look at the manuals, you're supposed to have those speakers almost straight out to the left and right of your listening position(s), some distance away, and with the tweeters at ear-level. I don't know a single person who has been able to achieve this recommended setup in a real-world living room. Hopefully you can get close. I wish you good luck!
EDIT: Giving this some thought after a few hours, I'd say the top priority for surround placement is to get them a significant distance away from all possible listening positions. It sucks when you go over to somebody's house and you have to sit right next to one of the surround speakers blasting in your ear the whole time. (Remember that sound gets exponentially louder the closer you sit to a speaker.) After that, my instinct is to avoid putting them close to the ceiling, which is basically the same thing as putting them in a corner. Some people put their surround speakers close to the ceiling so they're out of the way and draw less attention, but corner-loading speakers is almost always undesirable (unless you're talking about subwoofers). If you can get them even just 2 feet away from the ceiling, it should sound better.
Reply Speakers
