In wall speakers recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-25-2019, 11:22 PM - Thread Starter
Liked: 0
Hi,
I am looking to buy the wharfedale MI 602 in wall speakers for a HT set up can any body how good are they ? I am using MI 601 for the surround and wcm 80 for the atmos and sw12 woofer. The reciever I am using is denon x4500.
Please can anyone advice on this setup.
Priyesh.089 is offline
post #2 of 6 Old 05-26-2019, 02:31 AM
pase22's Avatar
Quoted: 3012 Post(s)
Liked: 2502
Originally Posted by Priyesh.089 View Post
Hi,
Wharfedale are great speakers, but are very mellow and laid back making better suited for music. I'm not saying the won't do well for HT, just that they won't be as dynamic as Klipsch or Kef.
Are you in the US?
Kef Q100 FL/FR,SL/SR, Q200C, SVS SB-2000, Denon AVR-X3400H, , Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #3 of 6 Old 05-26-2019, 07:39 AM - Thread Starter
Liked: 0
Hi,
No I am from India. I was only able to hear 3 brands deftech, paradigm and wharfdale but in all 3 different demo rooms so an exact comparison was not possible.
Between this 3 which would you suggest as the best for a HT setup. I prefer something which does not create a fatigue in a small room. The room size is 10 x 11 foot. I like a little high bass.
Also when I heard the wharfedale speakers I found them more clear and crisp and the bass was good.
post #4 of 6 Old 05-26-2019, 08:48 PM
RayGuy's Avatar
Quoted: 2530 Post(s)
Liked: 2279
Choose what you like. Since you have heard them, no reason not to pursue them.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #5 of 6 Old 05-27-2019, 08:52 AM
ack_bk's Avatar
Quoted: 1334 Post(s)
Liked: 1461
Hi,
Those 602's look good. Only concern you may want to consider is they are rated 4ohm and might put a lot of load on your receiver. They are not 90db so fairly efficient. You just may want to consider a dedicated amp to power your three main speakers if you find them causing too much heat, distortion, etc with that receiver.
ack_bk is offline
post #6 of 6 Old 05-30-2019, 05:53 PM
Jonas2's Avatar
Quoted: 2766 Post(s)
Liked: 1729
I'll second what RayGuy said - if you like the Wharfedales, and you do, I think the choice is clear....
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
Reply Speakers
