New Home Theater. Is this a good setup? - AVS Forum | Home Theater Discussions And Reviews
 18Likes
  • 2 Post By Kini62
  • 1 Post By bobknavs
  • 1 Post By Russdawg1
  • 2 Post By fr8flyr
  • 1 Post By sdurani
  • 4 Post By Russdawg1
  • 2 Post By Steve Sleeve
  • 1 Post By d-rail34
  • 2 Post By Kini62
  • 2 Post By naphcon
post #1 of 22 Old 05-29-2019, 05:32 PM - Thread Starter
Liked: 2
I'm building a new home theater. Room size is 13x19
It's basically just a Klipsch Reference Premier System. I know Klipsch is pretty popular here, but does this seem like a good fit for my room size?
Sub - Klipsch 12" SPL-120
4x Bookshelf - Klipsch Ref premier
Center - Klipsch Ref Premier
Atmos - Klipsch Ref Premier height speakers. Is this a good choice or should I do in-ceiling? I can do either.
Receiver - Marantz SR5013
My other choice was basically an Elac Debut 2.0 system, which would obviously be cheaper.
This looks like it'd be paired with a JVC x790, but I'm still debating on just going for the NX7. 127" Silver ticket high contrast screen.
naphcon is offline
post #2 of 22 Old 05-29-2019, 06:12 PM
Kini62's Avatar
Quoted: 2726 Post(s)
Liked: 2538
Go with in ceiling if you can. Also might want to upgrade to a 9 channel AVR and do 4 Atmos speakers. Klipsch are good for HT but they have a love hate reputation. Up to you though, as long as you're ok with the sound then it's all good.
The sub is OK but it's not the best choice depending on how much it's costing you. If it's anywhere near $500 there's better choices for HT. Also for almost every room 2 subs can really make a difference in the overall quality and response for the bass.
naphcon and sigpig like this.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is online now
post #3 of 22 Old 05-29-2019, 06:50 PM - Thread Starter
Liked: 2
Thanks for the advice on the 9chan/4atmos. I'll definitely consider that.
The sub is actually $600, so I assume that's an even worse buy. For $100 less I could get the SVS SB-1000 or the Elac 3010 for $449. I've seen both reviewed really well. Do you feel these are better value?
I'm buying everything I can for the setup from Best Buy Magnolia because I can get about 12-13grand in gift cards there, so it technically wouldn't be any money out of my pocket. Still not sure if I'll have to get the projector elsewhere or how long I'll have to wait.
naphcon is offline
post #4 of 22 Old 05-29-2019, 07:50 PM
bobknavs's Avatar
Quoted: 2338 Post(s)
Liked: 1667
If you want 5.1.4 Atmos, and insist on Marantz, you'd prefer an SR6013 to the SR5013. The 6013 actually processes 11 channels, and be expanded to Atmos 7.2.4 by adding an external 2 channel (stereo) amp. (Not a huge improvement over 5.2.4, but...) An adequate stereo amp can be had, new, for not much over $100. The SR6013 also has Audyssey XT32, which is their best retail room equalization software. That is bundled with SubEq, which can semi-independently equalize 2 subwoofers.
If you are limiting your source to Magnolia, I don't know what to suggest for the subs. (Mine are from Hsu Research, an Internet Direct company.) Maybe SVS. Preferably two. The larger the better, if you're doing home theater, especially if you like low frequency effects.
As usual, online advice encourages you to increase your budget.
naphcon likes this.
bobknavs is online now
post #5 of 22 Old 05-29-2019, 08:10 PM
Quoted: 1744 Post(s)
Liked: 1339
Get ported subs for sure, and get in ceiling Atmos speakers.
If it’s all from Best Buy/Magnolia then definitely go with SVS subs. Multiple PB2000’s would be best.
Make sure your center channel is top notch. Lots of content going through there.
naphcon likes this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #6 of 22 Old 05-29-2019, 08:36 PM
fr8flyr's Avatar
Quoted: 33 Post(s)
Liked: 53
If you are really wanting an JVC 790 you should order one now, as I think JVC will be discontinuing this model soon. For your setup, the 790 will save you lots over the NX7 and do almost as good of a job. For speakers, I have never really been a fan of Klipsch and you can get SVS through the Magnolia stores. I would save the money from the NX7 and get a full SVS speaker and dual sub setup with 4 ceiling speakers, for a full 7.2.4 system.
naphcon and iceatola like this.
Earl
fr8flyr is offline
post #7 of 22 Old 05-30-2019, 02:21 PM - Thread Starter
Liked: 2
Thanks to everyone for the advice. Everything is still in planning but I'll be pulling the trigger in the next couple weeks. I'm not set on anything other than sourcing everything I can via Magnolia or Amazon, but I'm always weary on buying things like this from Amazon.
With everyone's suggestions I think I'll go with 2x SVS Sub (Sb 2000), 4x SVS bookshelves, and 4x Def. Tech in-ceiling speakers and upgrade the receiver. Is the Yamaha A2080BL a good choice?
What would be the best choice for a center channel for say under $800? It will be almost exclusively for movies.
naphcon is offline
post #8 of 22 Old 05-30-2019, 02:33 PM
sdurani's Avatar
Quoted: 7259 Post(s)
Liked: 6295
One more of the same bookshelf speakers you're planning on getting, to maximize consistency across the front soundstage.
naphcon likes this.
Sanjay
sdurani is offline
post #9 of 22 Old 05-30-2019, 02:39 PM
Liked: 1339
Go with the PB2000’s, with sealed subs you lose a lot of needed SPL.
I can not recommend either the Prime Bookshelves or the Def Techs.
Klipsch RP is your best bet, and a way better choice IMO.
d-rail34, sigpig, naphcon and 1 others like this.
post #10 of 22 Old 05-30-2019, 02:43 PM
Steve Sleeve's Avatar
Quoted: 84 Post(s)
Liked: 32
Monolith 12" subs are starting to win the battle against SVS PB's but it all comes down to price, either choice you can get a deal on is the way to go, both better choices than the slightly cheaper but capable Klipsch sub
d-rail34 and naphcon like this.
Denon AVR-X6500h Klipsch RP-8000f RP-440C (4) RP-150MS sides in parallel RB-51 rears, 4 JBL C67P pendants for atmos, 2 monolith 12" subs
Epson 5040UB, Sony Ubp-X700, AC infintiy T9, Nvidia Shield, 142" 2.35 silver ticket screen
Steve Sleeve is offline
post #11 of 22 Old 05-30-2019, 03:01 PM
d-rail34's Avatar
Quoted: 450 Post(s)
Liked: 858
Yamaha AVR's are very highly recommended, and one of the most reliable.
As for your sub choice, you really want to go with the ported models (PB-2000) for movie applications, as they will give you more output at the lower frequencies. This will give you a better overall experience. Especially with action movies (explosions, gun fire, etc.).
Lastly, as stated by the previous poster, you will get better results by matching your L/R with another bookshelf. If you're unable to fit the bookshelf in a suitable location (your speaker's tweeters should be positioned as close to ear level as possible), then get the matching center channel speaker. And I wouldn't really recommend the the SVS Prime either. The Ultra are a different story, but the price difference is pretty substantial.
As for the in-ceiling, you really don't have to break the bank there, so you could go with something like the Micca's. But, if you are indeed able to swing the extra $$, I'd recommend going with the RSL C34E's.
https://www.amazon.com/dp/B002YPS6T6...GPNSL0GE&psc=0
https://rslspeakers.com/products/c34...#go_to_reviews
naphcon likes this.
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelfs (4)/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S
d-rail34 is online now
post #12 of 22 Old 05-30-2019, 03:57 PM
Kini62's Avatar
Liked: 2538
Like others have stated, go with the PB2000s or better yet the PB3000s. Do not get a pair of small sealed subs for HT.
naphcon and d-rail34 like this.
Def Tech SC8000
Onkyo RZ820
post #13 of 22 Old 05-31-2019, 04:15 PM
Lost240's Avatar
Liked: 0
Go with the Klipsch. You won't be disappointed
Lost240 is online now
post #14 of 22 Old 05-31-2019, 04:16 PM
Lost240's Avatar
Liked: 0
You could also look at Tekton. They are very efficient as well
post #15 of 22 Old 06-06-2019, 05:24 PM
d-rail34's Avatar
Quoted: 450 Post(s)
Liked: 858
Update? Pics (or it didn't happen )?
post #16 of 22 Old 10-07-2019, 02:07 PM - Thread Starter
Liked: 2
The room is finally *mostly* done. Still a few things left to do, but it's functional. It doesn't compare to many of the rooms/builds I see here, but I'm happy with how it turned out.
Had a few bumps along the road, mainly with the local company I'd hired to do the install. They were severely dragging their feet. I assume because this was a labor only job--I purchased all the items from Best Buy Magnolia because I had $15k in gift cards so it was all essentially "free". They kept pushing the date further and further to do things and I just got the feeling they wanted to push it until they had nothing else to do. I ended up saying thanks but no thanks and did everything myself with the help of family.
I made some changes to the setup:
-4x Elac Debut 2.0 Bookshelves
-4x Bowers & Wilkens Stands
-2x SVS Pb1000 (I know people were saying get the 2000's but these are incredible as is. I can't imagine 2x 2000's. My neighbors would probably hate me)
-Elac Center
-2x Klipsch Architectural for Atmos
-Marantz 5013 Receiver
-Panasonic ub820 4k/Bluray Player
-Panamax M4300 power surge
-125" (2.35:1) White Silver Ticket Screen
-Sony 295 Projector
-Front row seats - Row of 3 Valencia Tuscany Theater Seating
-Back Row - Loveseat Seatcraft Flex HR w/ Built on 8" Risers
-Rack - Strong FS Series 21U
-6x Acoustimac 24x36 Panels - not yet hung
-Still to be added: Zephyr Beverage Center (just received today) and a custom cabinet I ordered from Etsy to house the bev center with some shelving to store supplies and such. Entry custom curtains are being made and I pick them up later this week. Also still have some cable management to do at the rear of the room.
No idea how to embed images, so please excuse the links. Definitely not the best walk thru with pics, but I did take some shots along the way.
Here's the room before we got started. It is a 19x14 room with 9.5' ceiling at the height. It's a 3rd floor finished room.
https://ibb.co/xJB53JK
Painting - Sherwin Williams (flat). Urban Bronze side walls. Tricorn black ceiling + front & Back wall.
https://ibb.co/g36dZQJ
https://ibb.co/QdVjmYm
https://ibb.co/dtGHMvK
After paint and new carpet. Mohawk smart strand silk. Extremely soft. Very pleased with it.
https://ibb.co/rvXYbnZ
Window blacked out, Screen hung, and first chairs put in
https://ibb.co/d7XbxMY
Projector hung and rest of seating
https://ibb.co/5v9zDc3
Random pics of riser chairs, rack etc
https://ibb.co/VgkSBsQ
https://ibb.co/3Mq374X
https://ibb.co/HN86zBg
https://ibb.co/mS8xFTp
d-rail34 and tdogroeder like this.
naphcon is offline
post #17 of 22 Old 10-07-2019, 02:36 PM
capo4u's Avatar
Quoted: 153 Post(s)
Liked: 108
-Elac Center
-Sony 295 Projector
None of those links are working for me.
Receiver: Pioneer VSX-1022-K
Sub: SVS SB12-NSD
Fronts: Pioneer SP-BS22-LR
Center: Chane A2.4
Surrounds: Polk R15
capo4u is online now
post #18 of 22 Old 10-07-2019, 03:11 PM - Thread Starter
Liked: 2
Edited to attach them in case they weren't working for everyone.
naphcon is offline
post #19 of 22 Old 10-08-2019, 08:51 PM
iceatola's Avatar
Quoted: 262 Post(s)
Liked: 234
-Elac Center
-Sony 295 Projector
Attachment 2625000
Attachment 2625002
Attachment 2625004
Attachment 2625006
Attachment 2625010
Attachment 2625012
Attachment 2625014
Attachment 2625016
Attachment 2625020
Attachment 2625022
Attachment 2625024
Attachment 2625026
Attachment 2625028
Attachment 2625058
Job well done
Video: BenQ HT3550 4K Projector - Elite Screens Manual Grande Series - 128inch
Pre Amp: Marantz 7705/ Power Amplifiers: Emotiva XPA-3, UPA-700
JBL - Stage A190 Towers L/R , Stage A135 Center , Stage A190 surrounds , Atmos Klipsch rp-500sa
Subwoofer PSA 2xV1801 / Xbox One X, Nvidia Shield, Darbee Darblet 5000
iceatola is offline
post #20 of 22 Old 10-08-2019, 09:06 PM
capo4u's Avatar
Quoted: 153 Post(s)
Liked: 108
Originally Posted by iceatola View Post
Job well done
Yes. It looks great.
How does it sound?
Sub: SVS SB12-NSD
Center: Chane A2.4
Surrounds: Polk R15
post #21 of 22 Old 10-12-2019, 06:44 AM
d-rail34's Avatar
Quoted: 450 Post(s)
Liked: 858
Spoiler!
Congrats on finally getting things set up, and sorry for the late reply. Looks like you got some great stuff to work with.
post #22 of 22 Old 10-16-2019, 06:40 PM - Thread Starter
Liked: 2
How does it sound?
I'm far from an audiophile, but it sounds great!
Re: d-rail34 (I can't send PM since I'm a new user)
The Sony 295 wasn't on my list of choices initially. It was either the x790 or the nx5. I let the installer (who I ended up dropping and doing it myself) talk me into getting the 295. He didn't have much skin in the game since I was buying it from Magnolia, so I went with that. I wish I would've just gotten the NX5, but I'm still happy with the Sony 295. It's been great, but I do kind of wish I had that lens memory.
It definitely would've been a good idea to go with a 9 channel instead so I could upgrade later. I got the marantz 5013 again based on the installer recommendations and it was already on my list of 3 to get anyway. To top it off, Magnolia had it $300 off at the time. But just last week I was already saying to myself that I should've just gotten the 9 for room to upgrade later.
The subs though, I don't know if I would've ever had the need to upgrade lol. They are monsters and shake the whole room/chairs and aren't even turned up all the way as it is.
naphcon is offline
Reply Speakers
