need bedroom 3.0 setup recommendations - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 1 Post By MIX_MASTER_ICE
  • 1 Post By D33vious
  • 2 Post By mariogonzalezzz
  • 1 Post By zieglj01
  • 1 Post By Lp85253
post #1 of 22 Old 06-01-2019, 07:48 PM - Thread Starter
Quoted: 160 Post(s)
denon x3300, tcl 65r615 and hsu vtf2 mk5
99% for bluray/4k movies. id like something lively, fun and slightly bright but not ear piercing. i like a bit of volume, sensitivity in the upper 80s to 90
looking at ascend 340s, raal tweeter speakers but from what i read they are a bit mellow for movies. not sure id like that
also looking at emotiva t1, t2 and the center
any other recommendations?
budget for 3.0 is approx 1K
mariogonzalezzz is online now
post #2 of 22 Old 06-01-2019, 08:06 PM
Quoted: 1883 Post(s)
Liked: 1612
emo t1 / t2 and a c1 for a bedroom , i would think...
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #3 of 22 Old 06-01-2019, 10:00 PM
Quoted: 44 Post(s)
Emotiva t1 and a c2 center would put you under 1k. The c2 is large but if you have the room for it it definitely worth it. Would say T2 since you dont plan on a subwoofer, they would put you over 1k though with a C1 or C2.
Gold87 is online now
post #4 of 22 Old 06-02-2019, 02:54 AM
pase22's Avatar
Quoted: 2987 Post(s)
Liked: 2480
Slightly bright, but not piercing I'd look at Klipsch RP, Paradigm Monitor and Kef Q series. Klipsch & Paradigm would have the edge on sensitivity.
Kef Q100 FL/FR,SL/SR, Q200C, SVS SB-2000, Denon AVR-X3400H, , Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #5 of 22 Old 06-02-2019, 09:02 AM
afrogt's Avatar
Quoted: 2016 Post(s)
Liked: 1361
T1 wouid be fine as he said he has a HSU VFT2 Mk5 in the first post.
Afro GT
afrogt is offline
post #6 of 22 Old 06-02-2019, 10:59 AM
RayGuy's Avatar
Quoted: 2515 Post(s)
Liked: 2262
If dynamics are your thing, then I would avoid the ribbon options (including the RAAL). Metal dome tweeters or horns would probably give you more of what you are looking for in a sound signature. Check out PSA.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #7 of 22 Old 06-02-2019, 05:31 PM
MIX_MASTER_ICE's Avatar
Quoted: 2539 Post(s)
Liked: 2389
Infinity has the Reference line currently on sale for 50% off or more. A pair of the R253 towers would be $400 and the matching RC263 is $200. Very well regarded speakers and well under your budget.
https://www.infinityspeakers.com/sale/
RayGuy likes this.
Subs>RBH I-12e/I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 530/520c, 270/230/235c/225c, Arena 130/125c. Jamo S807/S803. Pioneer FS52/BS22A/C22. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith AM Cinema 5 bs. Polk RTiA1/CsiA4. Infinity R152. Other Audio>Sony MDR-Z7m2, WH-XB700, XB32, XB31.RBH EP1. Logitech GPro HS. Plantronics RIG 500 Pro HS. LG FH6,RK8,PK5,PH4. UE Boom3.
MIX_MASTER_ICE is online now
post #8 of 22 Old 06-02-2019, 07:00 PM
Quoted: 231 Post(s)
Liked: 214
For the record, the Ascend 340 does not have a raal tweeter, although from what I have read it is neutral and maybe not the slightly bright that the OP has stated he is looking for.
I do agree that a raal would not be ideal. Being new to the raal recently, I do love it, but wouldn’t justify the generally higher price for almost exclusive TV/HT use
D33vious is offline
post #9 of 22 Old 06-02-2019, 08:49 PM
Liked: 1612
ascends that i know of use soft domes(lower tier speakers).. and they handle volume well imo..
post #10 of 22 Old 06-02-2019, 09:38 PM
Quoted: 231 Post(s)
Liked: 214
Yeah. I believe the Lunas and Sierra-2s are the only Ascend bookshelves with the raal.
The OP says he wants slightly bright and lively. Makes me think of our old kef q100s, although pushing the high volume levels is where they can start to sound harsh to some. Also, they probably wouldn’t be so great in 3.0. They work best with a sub.
Lp85253 likes this.
D33vious is offline
post #11 of 22 Old 06-02-2019, 09:45 PM
Liked: 1612
i thought about the q100's too , then i thought about the limited spl handling.. ascend would be better.. i have the cbm 170's , they handle volume well..chane might have something that would work as well..
post #12 of 22 Old 06-03-2019, 07:07 AM
Transmaniacon's Avatar
Quoted: 1742 Post(s)
Liked: 1551
I’d take a look at the Monitor Audio Bronze speakers, they are a touch bright and should suit your taste well.
The Bronze 2 Bookshelves and center will set you back $800.
5.1: Samsung PN60F5300 | Sony BDP-S1700 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
2.0: Apple Airport Express | Topping D50 | Parasound HCA-1500a | Chane A1.4
Transmaniacon is offline
post #13 of 22 Old 06-03-2019, 11:48 AM - Thread Starter
Quoted: 160 Post(s)
what jbl studio 530 and 520 center?
would these be as good as above mentioned?
Lp85253 and cocrh like this.
post #14 of 22 Old 06-03-2019, 02:40 PM
zieglj01's Avatar
Quoted: 2935 Post(s)
Liked: 2837
A serious good option and not easy to beat them
Lp85253 likes this.
Who AM I
zieglj01 is offline
post #15 of 22 Old 06-04-2019, 10:34 AM
Stephen Hopkins's Avatar
Quoted: 396 Post(s)
Liked: 176
530 was going to be my recommendation... not as efficient as I remember them being, but should still be plenty for a bedroom. They've been harder to find lately, but JBL has them back for $300/pair right now. The 520 center doesn't look to currently be available from JBL direct, but it's much easier to find in general than the 530s these days and will likely come back in stock at JBL sooner rather than later.
Do you have a single main listening position that's fairly well centered between the L/R speakers? If so, a center channel may really be superfluous.
BenQ TK800 | Silver Ticket 106" 16:9 1.0 Grey | Marantz SR6011 | B&W P6 | B&W CDMC SE | Sonance .5 THX SUR | MCM In-Ceiling Atmos | Ascendant Avalanche 12" in 6 ft^3 @ 18Hz w/ BASH 500w Plate Amp | Sony X800 | NVidia Shield TV Pro | XBox One 500gb | Nintendo Switch | Harmony Smart Control | SmartThings Hub | Google Home | AT&T Fiber 300 | YouTube TV | Netflix | HBO Now | Spotify
Stephen Hopkins is offline
post #16 of 22 Old 06-04-2019, 05:01 PM - Thread Starter
Quoted: 160 Post(s)
i ordered 2 pair 530s and 520center all on sale. even ordered the 550p ill probably use in the garage/man cave
very excited because ive read so many good things about those 530s
i also have jbl 230s and 235center and like those but im assuming the 530/520 setup are a notch above those in sq
post #17 of 22 Old 06-04-2019, 05:10 PM
zieglj01's Avatar
Liked: 2837
You should easily notice a clear difference
Lp85253 likes this.
Who AM I
zieglj01 is offline
post #18 of 22 Old 06-04-2019, 06:41 PM - Thread Starter
Quoted: 160 Post(s)
havent received any speakers yet of course but now im thinking of returning the center, order another pair of 530s and use one as a center. i can make it work by angling it toward ear level off the ground at mlp but id have an extra 530
would this be a better idea than using the 520
post #19 of 22 Old 06-04-2019, 07:06 PM
Liked: 1612
if you have the room to use the 530 vertically , it would be better , imo
Transmaniacon likes this.
post #20 of 22 Old 06-04-2019, 07:48 PM - Thread Starter
Quoted: 160 Post(s)
ordered another 530 pair. i will feel bad about returning the 520 but it will be in box unopened. i will need to sell an extra 530 here but im sure others here want to use one as a center.
post #21 of 22 Old 06-04-2019, 07:53 PM
Liked: 1612
i would think you could get a taker pretty easy if you can find somebody close enough to keep shipping cost down... i think you made a good call , i have vertical books as centers in both my set ups, i have no issues at all..
post #22 of 22 Old 06-05-2019, 10:34 AM
kyzer soze's Avatar
Quoted: 508 Post(s)
Liked: 352
I thought you owned those new Monoprice thx speakers.
Ascend Sierra 2's (LCR & side surrounds) + Pioneer atmos modules. 5.1.4 setup
Marantz AV7703
Rythmik FV15HP
JVC DLA-X590R (RS 440) projector
Stewart StudioTek 130 screen
kyzer soze is offline
Reply Speakers
