Should I change my JBL 590 for JBL 520c - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By smithsabom
post #1 of 21 Old 06-03-2019, 05:07 AM - Thread Starter
genaccmiller's Avatar
Quoted: 366 Post(s)
Liked: 42
Folks - I purchased the three JBL590s when they were on sale less than a month back. I wanted to use them for an AT Screen flanking left, right and center. Since then I have run into some construction difficulties and the placement of an AT screen is still under discussion. I see that the 520c is on sale for Father's day for $149. Should I return one of my 590s and replace with this so that I have flexibility on placement of center channel regardless of whether I do an AT screen or not? Your immediate attention is appreciated as the return window is closing.
@danhitchman
Sent from my Moto G (5) Plus using Tapatalk
genaccmiller is online now
post #2 of 21 Old 06-03-2019, 11:05 AM
m0j0's Avatar
Quoted: 463 Post(s)
Liked: 380
Yes, if you are not going with an AT screen, that would probably be the prudent thing to do. What kind of problems did you run into?
m0j0 is offline
post #3 of 21 Old 06-03-2019, 11:27 AM
ack_bk's Avatar
Quoted: 1334 Post(s)
Liked: 1467
@danhitchman
If you can put in an AT screen you will definitely want the third 590. I would return the 590 get the 520 but if you can go the AT route and make the third 590 work, do that (meaning you may have to order another 590).
ack_bk is offline
post #4 of 21 Old 06-03-2019, 11:33 AM - Thread Starter
Quoted: 366 Post(s)
Liked: 42
Hello - I already have three 590s. Why would I need to order another?
post #5 of 21 Old 06-03-2019, 11:43 AM
ack_bk's Avatar
Liked: 1467
I am saying if you return the 590 for 520 and then later determine you can have a third 590 as a center I would do that (get another 590 for a center). It will be far superior to the 520. I have 3 590's now as well as a pair of 530's and a 520. A 590 and 520 are not in the same league but obviously the 590 is much bigger.
ack_bk is offline
post #6 of 21 Old 06-03-2019, 11:45 AM - Thread Starter
Quoted: 366 Post(s)
Liked: 42
Wouldn't I then be left with an unused 520?
post #7 of 21 Old 06-03-2019, 11:52 AM
Quoted: 457 Post(s)
Liked: 242
I would not recommend 4" woofer for a center channel...while not a compression driver, this would be a better center: https://www.infinityspeakers.com/cen...urrent#start=1
on sale now..don't know how long it will be on sale.
cocrh likes this.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #8 of 21 Old 06-03-2019, 11:55 AM
ack_bk's Avatar
Liked: 1467
When will you know if you can fit a 590 as a center channel? Would you be in the return window for the 520? Worse case you have to sell it yourself and are out some money.
ack_bk is offline
post #9 of 21 Old 06-03-2019, 11:56 AM - Thread Starter
Quoted: 366 Post(s)
Liked: 42
Or I could just stick with the 590s if you say they are good to use as a center channel.
post #10 of 21 Old 06-03-2019, 12:08 PM
ack_bk's Avatar
Liked: 1467
It is an excellent center channel. Very good dispersion and overall bass.
ack_bk is offline
post #11 of 21 Old 06-04-2019, 02:46 AM
Skylinestar's Avatar
Quoted: 1308 Post(s)
Liked: 268
I hope you discuss this in detail. The biggest mistake I've done in HT is not having AT screen in the beginning. I end up wasting so much to re-buy speaker and screen (and the whole setup placement).
Skylinestar is offline
post #12 of 21 Old 06-15-2019, 10:53 AM
gajCA's Avatar
Quoted: 8558 Post(s)
Liked: 5759
@danhitchman
Very small investment; order and see for yourself.
It just might surprise you despite its small size.
Geoff A. J., California
gajCA is offline
post #13 of 21 Old 06-15-2019, 11:31 AM
gajCA's Avatar
Liked: 5759
@danhitchman
Question about the capability of the 520c is answered here.
It actually sounds like three 520cs placed horizontally would make a great budget front three.
https://www.avsforum.com/forum/89-sp...io-580s-3.html
gajCA is offline
post #14 of 21 Old 06-15-2019, 11:32 AM - Thread Starter
Quoted: 366 Post(s)
Liked: 42
How about three 590s in the front and two 580s for surrounds?
post #15 of 21 Old 06-15-2019, 11:36 AM
gajCA's Avatar
Liked: 5759
Assuming they are all placed vertically I'm sure that would be a great combination...assuming you like the sound of the 590s.
gajCA is offline
post #16 of 21 Old 06-15-2019, 11:39 AM - Thread Starter
Quoted: 366 Post(s)
Liked: 42
I started using the 590s yesterday and they are great. I plan to have an AT screen with three 590s in the back. Room size with be about 12x13 and wondering if the two 580s in the back would be too much for the room size.
post #17 of 21 Old 06-15-2019, 11:46 AM
gajCA's Avatar
Liked: 5759
For me it would be too much as I'd essentially be sitting right next to the 580s...and for people on either end of the couch they'd get a huge dose of either the left or right surround depending on where they sit.
In such a small room I'd likely use two 520s placed horizontally as rears...likely placed three feet or so above the end table of the couch as it sounds like the couch must be against the rear wall as mine is.
gajCA is offline
post #18 of 21 Old 06-15-2019, 11:48 AM - Thread Starter
Quoted: 366 Post(s)
Liked: 42
What do a decent pair of surrounds cost that can work with the 590s? Don't have to be JBL.
post #19 of 21 Old 06-15-2019, 11:58 AM
gajCA's Avatar
Liked: 5759
I'd use the 520cs mounted horizontally.
But my rears don't match my fronts so likely a pair of Klipsch RP400ms or RP500ms would be a good match for a bit less money.
Free returns at Best Buy assuming they have them in stock.
gajCA is offline
post #20 of 21 Old 06-15-2019, 12:00 PM - Thread Starter
Quoted: 366 Post(s)
Liked: 42
I have the 590s. What would be a matching surround for that and what kind of cost?
post #21 of 21 Old 06-15-2019, 12:07 PM
gajCA's Avatar
Liked: 5759
Asked and answered.
Pair of 520s are $500, RP400s $350, RP500s are $420.
gajCA is offline
Reply Speakers
