5.1 system for 50/50 music and movies/tv - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By gajCA
  • 1 Post By gajCA
post #1 of 24 Old 06-03-2019, 10:58 AM - Thread Starter
Jamy's Avatar
Quoted: 26 Post(s)
I am looking to replace a polk setup (RTI4's etc) with a bookshelf 5.1 setup. My wife has decided she wants the tv mounted to the wall above the fireplace and the Polk towers no longer fit the bill. So far I am considering ascend acoustics with mini towers (not sure if they can be wall mounted), QAcoustics 3020i, RSL, and Infinity Reference. Any others I should consider? We use the system for 50/50 Music/Movies and TV. I'd like to stay in the $1000 to 1500 range.
Jamy is offline
post #2 of 24 Old 06-03-2019, 12:38 PM
pase22's Avatar
Quoted: 3209 Post(s)
Liked: 2668
For 50/50 usage, Ascend would give you the best of both worlds. If you like the Polk sound, the S20's may worth a look. If you're flush mounting to the wall, NHT Superone with it's seal cabinet would be suitable.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #3 of 24 Old 06-03-2019, 02:38 PM
zieglj01's Avatar
Quoted: 3005 Post(s)
Liked: 2910
Infinity Reference would be a nice option
HTD Level Three speakers can be wall mounted
https://www.htd.com/Level-THREE-Bookshelf-Speakers
https://www.htd.com/Level-THREE-Center-Channel-Speaker
Use the Level Two for surrounds
https://www.htd.com/Level-TWO-Bookshelf-Speakers
Who AM I
zieglj01 is online now
post #4 of 24 Old 06-03-2019, 03:48 PM
MIX_MASTER_ICE's Avatar
Quoted: 2634 Post(s)
Liked: 2451
The Infinity Reference line just went off sale, so that's off the table right now. Am I understanding correctly that you want to wall mount the front speakers? If that's the case the QA 3020i wouldn't be a very good option.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c, Arena 130/125c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2, MDR-V6, WH-XB700, XB32, XB31, XB22. Sennheiser HD58X, HD4.50, PC37X. SIVGA SV004. HyperX Cloud PS4. TB Stealth300. LG FH6, RK8, RK7, PK5, PH4. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
post #5 of 24 Old 06-03-2019, 05:34 PM
afrogt's Avatar
Quoted: 2096 Post(s)
Liked: 1394
you certainly dont want to wall mount towers or mini towers whatever that means.
The SuperOne is a sealed design so you don't have to worry about a rear ported speaker against the wall. And they look good with their glossy black finish, wife friendly.
Afro GT
afrogt is offline
post #6 of 24 Old 06-04-2019, 09:18 AM - Thread Starter
Jamy's Avatar
Quoted: 26 Post(s)
Doesn't have to be full wall mount, brackets would be fine too.
Mini-tower is Ascend's acoustics term, specifically the CMT-340.
Jamy is offline
post #7 of 24 Old 06-04-2019, 09:19 AM - Thread Starter
Jamy's Avatar
Quoted: 26 Post(s)
Also, what about HSU Ultra 15? What's the general consensus on those?
http://www.hsuresearch.com/products/ultra15pkg.html
Jamy is offline
post #8 of 24 Old 06-04-2019, 09:21 AM - Thread Starter
Jamy's Avatar
Quoted: 26 Post(s)
Brackets/arms would be fine too. They do not have be speaker back directly mounted to the wall.
Jamy is offline
post #9 of 24 Old 06-04-2019, 09:35 AM
Elihawk's Avatar
Quoted: 1905 Post(s)
Liked: 2035
Boy, mounting the CMT340 might be a chore...those are not light speakers (26 lbs each)! Excellent speakers, however...
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #10 of 24 Old 06-04-2019, 09:45 AM - Thread Starter
Jamy's Avatar
Quoted: 26 Post(s)
Ascend recommends these brackets at Amazon.
https://www.amazon.com/dp/B004DCAOHK
Jamy is offline
post #11 of 24 Old 06-04-2019, 09:50 AM - Thread Starter
Jamy's Avatar
Quoted: 26 Post(s)
Since this is not an, "I need to buy today," situation. I can wait and see if anything goes on sale for 4th of July.
Why aren't the Q3020i a good option? They are listed as wall mountable.
Jamy is offline
post #12 of 24 Old 06-04-2019, 03:35 PM
Liked: 2451
You can mount pretty much any speaker to a wall within a reasonable size and the right mounting bracket. The 3020i is really made as a bookshelf speaker, or more so as a stand mounted speaker. QA even has specific stands for these. They do also offer a wall bracket, so it is an option. However, these speakers area bit odd for wall mounting due to the cabinet design being rather deep and not as tall as similar speakers. Using these as wall mounted left/right speakers, the rear ported design will also be a draw-back. If they were wall mounted as surrounds it would be less significant being rear ported. They do include a port plug, but this will change the lower frequency range of the speaker.
post #13 of 24 Old 06-07-2019, 09:48 AM - Thread Starter
Jamy's Avatar
Quoted: 26 Post(s)
I demoed the Elac Debut 6.5 and Bowers and Wilkins 600 Series. The Elac's seemed to have very good balanced sound and were similar to the BW600, but the BW 600 seemed like their treble boost may get fatiguing. I also see that JBL studio 590 model is on sale, for a good price, should I consider those?
Jamy is offline
post #14 of 24 Old 06-07-2019, 10:13 AM
Quoted: 401 Post(s)
Liked: 346
If you can fit them in as they are big then yes they would be good to consider. If you want bookshelf speakers here is a great deal on Polk LSiM 703's. Buy 4 get the awesome LSiM 706c center for free.
https://www.ebay.com/itm/Polk-Audio-....c100903.m5276
Polk Audio LSi M703 MT VERNON CHERRY Bookshelf Speaker NEW EACH
FREE LSiM706 With 4 qty LSiM NEW Speakers F l/r & R l/r
cocrh is online now
post #15 of 24 Old 06-07-2019, 10:43 AM - Thread Starter
Jamy's Avatar
Quoted: 26 Post(s)
I have Polk RTI Towers right now and the Elac bookshelfs put them to shame, so I am a bit hesitant on going polk again.
Jamy is offline
post #16 of 24 Old 06-07-2019, 11:45 AM
Quoted: 401 Post(s)
Liked: 346
Perhaps post your concern in the Polk thread and see what others have to say to compare your RTi's to the LSiM. LSiM is their top of the line and are very nice for music or HT.
https://www.avsforum.com/forum/89-sp...l#post58150240
cocrh is online now
post #17 of 24 Old 06-07-2019, 01:28 PM
pase22's Avatar
Liked: 2668
If you liked the Elac 2.0 over your current Polks, you should definitely consider them, though it maybe a good idea to go listen to other brands as well.
pase22 is offline
post #18 of 24 Old 06-07-2019, 07:48 PM
dswierenga's Avatar
Quoted: 133 Post(s)
Liked: 167
All these from Amazon for under $1,000
NHT C-3 front left and right $330 each
NHT SuperOne surrounds $100 each
NHT SuperCenter $145
Here is a review of the C-3. I have an earlier version of these and they are terrific.
https://hometheaterhifi.com/reviews/speaker/bookshelf/nht-c3-bookshelf-speaker-review/
Add a sub for $500 (many good ones at this price) and you will have a system that will last for years of pleasure.
Panasonic TCP65VT60, Denon AVR-x6200w
Oppo UDP-203, Dish VIP722
NHT C4 front speakers, NHT C LCR center spkr
NHT Classic 3 surrounds
Velodyne Optimum 12 & DLS-5000R subs
dswierenga is offline
post #19 of 24 Old 06-15-2019, 11:53 AM
gajCA's Avatar
Quoted: 8777 Post(s)
Liked: 5964
If you liked the Elacs keep your powder dry as they have gone on severe discount the last 6 months twice.
Many happy Elac owners and as you've heard them a safe bet.
Would allow for a better subwoofer purchase as even at full msrp they are quite a bargain.
pase22 likes this.
Geoff A. J., California
gajCA is offline
post #20 of 24 Old 07-16-2019, 07:25 AM - Thread Starter
Jamy's Avatar
Quoted: 26 Post(s)
Any recommendations of bookshelf or wall mountable that sound good at lower volumes? My wife wants something that will sound good at low and high volumes. I have a Yamaha TSR-7810 to power them. Wife wants the towers gone, and is willing to spend up to $1000 on just the 5 speakers (i'll buy the sub separately). The Ascend CMT340 peaks my interest, but I'm not sure they would do well a t lower volumes.
Jamy is offline
post #21 of 24 Old 07-16-2019, 07:39 AM
Quoted: 485 Post(s)
Liked: 256
Ascend is amazing at any volume. While my experience with the 340 is limited - just a short session in their listening room - it left me impressed.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #22 of 24 Old 07-16-2019, 10:19 AM
gajCA's Avatar
Liked: 5964
How about 5.1 for $1199?
Free returns if not happy.
https://rslspeakers.com/products/cg2...heater-system/
Or 5.0 for $900.
https://rslspeakers.com/products/cg2...enter-channel/
RayGuy likes this.
gajCA is offline
post #23 of 24 Old 07-16-2019, 11:10 AM
zieglj01's Avatar
Liked: 2910
HTD Level Three and Level Two can be wall mounted and sound good at different volumes
Fronts
Center
Surrounds
Who AM I
post #24 of 24 Old 07-16-2019, 06:41 PM
jwskud's Avatar
Quoted: 76 Post(s)
Liked: 214
I need to read through your entire thread, but I'll direct you here for now. Chane A2.4s would fit the bill nicely, and they are affordable.
7.2 system: Chane A2.4 center, Chane A5.4s L/R, Chane A1.5s surround, Kenwood KS-505HTs rear
Subs: Klipsch R-120SW and Kenwood SW-35HT (8"); HiVi Swan X3 monitors (laptop)
Onkyo TX-RZ620, Samsung 4k 43NU7100, PS3, Nintendo Switch, Sennheiser HDR130 headphones
Protection: Tripp Lite Isobar 8 Ultra; VCE SP250-2P
And don't forget - JVC HR-S3900U Super VHS - the last working VCR in America??
jwskud is offline
Reply Speakers
