Looking to upgrade 5.1 speakers at about $150/speaker - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #1 of 31 Old 06-03-2019, 11:02 AM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
I am looking to upgrade my L/C/R and surround sound speakers. I was recommended the NHT SuperOnes which are too big. The NHT SuperZeros are a better size, but am hoping to find something comparable in an even slimmer design. I noticed the Polk Audio OWM5 speakers on Amazon. They're more expensive, but seem to be a slim design. How do they compare to the NHT SuperZeroes? Any others I should consider? Am open to spending up to $150/speaker.
I currently have:
Yamaha TSR-7790 AVR
Definitive Technologies ProCenter 1000
F/R/surround speakers are all JBL Satellites (5.1 setup)
Bic Venturi V1020 sub
Couch is about 9 feet away from TV/Center speaker but room extends further back for another 15 feet although it's not necessary for the speakers to fill the room beyond the couch.
Speakers are used mainly for TV and movies and some music. F/R/surround speakers need to be mounted on the wall and center speaker is sitting on TV stand at the moment, so it can't have too much height.
Thank you!
churwitz is offline
post #2 of 31 Old 06-03-2019, 11:15 AM
bobknavs's Avatar
Quoted: 2899 Post(s)
Liked: 2094
Originally Posted by churwitz View Post
(snip)
Thank you!
How tall a center can you use?
(I had to switch to a third-party TV mount to raise the screen enough to clear a 10" high center.)
bobknavs is offline
post #3 of 31 Old 06-03-2019, 11:20 AM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
5.5" is about as tall as I can go for the center.
churwitz is offline
post #4 of 31 Old 06-03-2019, 12:32 PM
pase22's Avatar
Quoted: 3862 Post(s)
Liked: 3324
I currently have:
Yamaha TSR-7790 AVR
Thank you!
Q Acoustics 3020 has a small form factor with 5" drivers. NHT SZ has 4.5" drivers. Anything smaller would put you right back into HTIB territory. The Q Acoustics are within budget, but the center is 5.9" high. You'd just need to raise the TV a little.
https://www.qacoustics.com/home-thea...l-speaker.html
https://www.qacoustics.com/3020-book...aker-pair.html
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Emotiva A-300, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #5 of 31 Old 06-03-2019, 12:59 PM
RayGuy's Avatar
Quoted: 3579 Post(s)
Liked: 3393
6" width and height, RSL CG3/23.
smithsabom likes this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #6 of 31 Old 06-03-2019, 01:48 PM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
The Q Acoustics aren't any slimmer than the SuperZeroes. The Polks are 4.1 inches deep so seem to be slimmer for wall mounting. Any thoughts on those?
churwitz is offline
post #7 of 31 Old 06-03-2019, 01:50 PM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
Those aren't any slimmer than the SuperZeroes. The Polks are 4.1 inches deep so seem to be slimmer for wall mounting. Any thoughts on those or others that might have more of a thin profile?
churwitz is offline
post #8 of 31 Old 06-03-2019, 02:05 PM
RayGuy's Avatar
Liked: 3393
Not in your price range. You have to pay for slimness! Plenty of options, but all are more expensive. KEF, Golden Ear, Def Tech, Paradigm, Martin Logan, ELAC, Revel, Dali ....
RayGuy is offline
post #9 of 31 Old 06-03-2019, 02:09 PM
djp2k7's Avatar
Quoted: 445 Post(s)
Liked: 370
You could go with the Energy RC-Micro set. You'd have to find them on eBay or Amazon. They have a 5.0 and a 5.1 package. They've been out forever and get zero discussion anymore but they are very good sound quality for their size. You do need a sub that will play up to 150hz though. I've owned them as well as original superzero's and sz 2.1's. I'd take the rc-micro's over the sz 2.1's.
KEF Q150 x 3 / Canton Surrounds / Martin Logan Sub
Sony STR-DN1080 AVR / Sony X700 Blu Ray / Xbox One X
djp2k7 is offline
post #10 of 31 Old 06-03-2019, 02:29 PM
zieglj01's Avatar
Quoted: 3422 Post(s)
Liked: 3322
Look at the KEF E301 speakers
https://www.accessories4less.com/mak...air-new/1.html
Who AM I
zieglj01 is offline
post #11 of 31 Old 06-03-2019, 05:22 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 2340
The SuperZeros are sealed speakers and are about as good as it gets at that size. You are probably not going to find smaller in any speaker that is not sealed (ported requires larger cabinets).
NHT SuperZero
9 x 5 x 5.5
A serious contender would be these:
Micca RB42
7.87 x 4.92 x 8.66 in
However they are deeper (you need cabinet space in some direction) so check to see if they would still work on the wall.
I can't recommend smaller than 4" drivers...
As was mentioned you'll need a sub that can play cleanly up to about 150Hz, maybe higher. Something like an 8-10" model.
Transmaniacon likes this.
System 1: Samsung Plasma | Denon X4500H | Hypex Ncore NC252MP | Buchardt S400 | Polk LSiM 702 F/X | Heights TBD | Subs TBD Rythmik
System 2: Laptop | NAD T758 v3 | PSB Imagine B
System 3: PC | Micca OriGen G2 | Mackie MR624
Soulburner is offline
post #12 of 31 Old 06-04-2019, 08:14 AM
pase22's Avatar
Liked: 3324
Can you get away with less depth but more height or maybe horizontally? What about something like these? Also available in white, but a little more expensive.
https://www.accessories4less.com/mak...ck-each/1.html
https://www.accessories4less.com/mak...ck-pair/1.html
pase22 is offline
post #13 of 31 Old 06-04-2019, 08:18 AM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 413
NHT SuperZero's are good speakers. I ran SuperOnes and a SuperCenter for years.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is offline
post #14 of 31 Old 06-04-2019, 10:24 AM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
I love the look of those! The center is too tall, but maybe I can work something out. Would you recommend the 417 or the 416 to use as the left and right speakers? Have you heard Canton's before? How do they sound?
churwitz is offline
post #15 of 31 Old 06-04-2019, 10:30 AM
pase22's Avatar
Liked: 3324
Bigger driver = bigger sound and better dynamics. I personally prefer the look of the 416's so I'd go 416's for FL/FR and 517 for center.
If you could increase your budget the Chrono series is a good step up in sound quality.....and look much nicer.
churwitz likes this.
pase22 is offline
post #16 of 31 Old 06-04-2019, 10:36 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 2340
Of course "big sound" is helped by more capable drivers, and size can certainly help. But big sound comes from many factors, many being related to the cabinet, front baffle, and/or waveguide design, along with driver selection and a crossover that blends the drivers directivity.
I agree, but I also noticed that the aluminum-manganese tweeter upgrade the Chrono gets did trickle down into the GLE line, so look out for that.
post #17 of 31 Old 06-04-2019, 10:47 AM
zieglj01's Avatar
Liked: 3322
I would go with the 416 -- and Canton makes some really nice sounding speakers
Who AM I
zieglj01 is offline
post #18 of 31 Old 06-05-2020, 09:55 AM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
It's been a while, but I just recently changed my tv setup and am able to fit a bigger center. I'm looking to pull the trigger on a pair of Canton Chrono 511 wall-mounted for front left and right and Canton Chrono 515 for center sitting on top of my cabinet. Wanted to see if anyone had an opinion about this setup for movies/tv. I have a sub and avr and JBL surrounds already so they will complete the system. Mainly I want to be sure the dialog from movies will be clear and they'll be enjoyable to listen to.
I wish I could test them first, but A4L doesn't have that option.
churwitz is offline
post #19 of 31 Old 06-05-2020, 10:56 AM
Quoted: 626 Post(s)
Liked: 559
The Chrono 511's have the same tweeter as the 515 center so should be a nice matched setup. The 511's don't have as large an enclosure as the bookshelf Chrono's so low end will be less of course but you have subs so I wouldn't worry about that at all. Should be an excellent sounding setup. The center is a 3 way design which is optimal.
cocrh is online now
post #20 of 31 Old 06-05-2020, 12:10 PM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
Thanks! The 515 is rear ported and will be placed about 5-inches from the wall on top of a cabinet. Any concerns with a rear-ported center? I'm assuming there wouldn't be much bass coming from the center anyway since I have a sub but I also wouldn't want it to push too much noise to the room behind the wall the tv is on.
churwitz is offline
post #21 of 31 Old 06-05-2020, 12:19 PM
Quoted: 626 Post(s)
Liked: 559
5 inches is plenty since you will probably be crossing it over at 60 or 80Hz
cocrh is online now
post #22 of 31 Old 06-05-2020, 12:20 PM
pase22's Avatar
Liked: 3324
If you can't do the Chrono 502's and have to go on wall, the 511 are designed for that purpose. The frequency range will be shorter, but I'm sure your sub can handle a 100-120hz crossover. As mentioned the center has the same drivers so should be no issue. Keep in mind that these speakers aren't very efficient so something to keep in mind if you like cranking it up to 11.
pase22 is offline
post #23 of 31 Old 06-05-2020, 12:26 PM
Zorba922's Avatar
Quoted: 9591 Post(s)
Liked: 7418
Here are 5 compact speakers to compare:
  • NHT SuperZero, 9 x 5 x 5.5 (sealed, 4" woofer) - 85Hz*
  • NHT SuperOne, 11.6 x 7.3 x 8.5" (sealed, 6.5" woofer) - 56Hz*
  • NHT C1, 9.7 x 7.5 x 5.8" (sealed, 5" woofer) - 70Hz*
  • RSL CG3, 9.5 x 5.2 x 6.4" (front ported, 4" woofer) - 100Hz
  • Ascend HTM-200SE, 11 x 6.5 x 6.4" (sealed, DUAL 4" woofers) - 68Hz
* = NHT's bass extension numbers are often questioned by users, who report them to be an average of 20Hz higher than claimed; the SuperZero for example usually requires a 100Hz or higher crossover.
The 200SE would be my pick out of those 5. Second would be the NHT C1.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #24 of 31 Old 06-05-2020, 01:13 PM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
Thanks, that should be ok. I don't need things too loud generally, but it needs to be clear enough so we can hear dialogue. The only exception is when we have a Super Bowl Party and I have to crank the volume then. I figure in the future, if we get more space and I can get the 502s, I can then move the 511s to surround speakers for 5.1 or even 7.1.
churwitz is offline
post #25 of 31 Old 06-05-2020, 01:20 PM
pase22's Avatar
Liked: 3324
They can get pretty loud with a modest AVR, but won't achieve movie theater levels. Some room correction programs will sometimes put the center level a little low so make manual adjustments if necessary. The detail, clarity and accuracy will be quite good on the Chrono's.
pase22 is offline
post #26 of 31 Old 06-05-2020, 02:03 PM
Zorba922's Avatar
Liked: 7418
Noticed that Canton lists the 511 as
Frequency response 40...40.000 Hz
https://www.canton.de/en/hifi/chrono-series/chrono-511
For a sealed cabinet only 3.5" deep, that must be at least a 60db roll-off, lol! Didn't know that Canton is a specs-embellisher.
@churwitz
I'd expect the 3db roll off to be closer to 90-100Hz for the 511.
Where did you find that the 515 is rear-ported? I couldn't find any mention of it on the Canton website, nor any photos of the back of the speaker, although the 12" depth of the speaker does suggest a rear ported design.
https://www.canton.de/en/hifi/chrono...r?number=03594
Zorba922 is offline
post #27 of 31 Old 06-05-2020, 02:18 PM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
@churwitz
Yeah, I found it strange that Canton said the 511's could handle 40Hz too. Thanks for that info.
I saw someone mentioned it in a thread on one of the AV boards - sorry I can't find the link. Anyway, I emailed A4L to find out just in case and they confirmed it was rear-ported.
churwitz is offline
post #28 of 31 Old 06-05-2020, 02:28 PM
Zorba922's Avatar
Liked: 7418
The 515 should make for a good center speaker then, but if you value your music listening, that's where either the Ascend 200SE or NHT C1 would be a much wiser choice at least for the L/R...and no, it's not at all essential to "timbre match" the center to the mains.
If you're curious, start with post #19 of this thread:
https://www.avsforum.com/forum/89-sp...-c2-stock.html
There are many more threads like that. I should have thought to save them as they came up, and will start to do so herewith.
Zorba922 is offline
post #29 of 31 Old 06-06-2020, 03:34 PM - Thread Starter
churwitz's Avatar
Quoted: 17 Post(s)
Interesting - I'm curious, why would you recommend the 515 as a center speaker for those when you could use an Ascend as a center for Ascend LR or the NHT C Center as a Center for the C1? What's better about the 515 for those LR speakers? (Just trying to learn as much as I can)
churwitz is offline
post #30 of 31 Old 06-06-2020, 04:41 PM
Zorba922's Avatar
Liked: 7418
Oh I forgot that Amazon does carry the C-LCR center for $278, so you don't have to pay $500 from NHT direct. In that case you could use it with the C1 on L/R, yes. I thought you would've been stuck with the SuperCenter of the Media Series centers, both of which are 2 way designs.
The 200SE would probably be ok as a center too, but if given a choice between a 3 way with 6.5" woofers and a 2 way with dual 4" it's an easy choice.
Zorba922 is offline
Reply Speakers
