Center speaker $300-$500 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By rocky1
  • 3 Post By miketofani
  • 1 Post By pase22
post #1 of 30 Old 06-04-2019, 06:02 AM - Thread Starter
cuibap's Avatar
Quoted: 120 Post(s)
Liked: 27
I'm looking for a center speaker that is around $300 to $500 and NOT made in China. This is for my small media room, 15ftx12ft. Front speakers and center are from Infinity that I got them 2nd hand. Sub is KlipschR-10SW and surround is a pair of Klipsch R-14S Surround. I plan to replace 2 front speakers and the center but thinking the center will go in first. Would you give me some suggestions? Thanks.
Sent from my SM-G975U using Tapatalk
Sony XBR-X940E; Yamaha RX-A1060; Nvidia Shield TV; OPPO BDP-93; Yamaha RX-A1070
cuibap is offline
post #2 of 30 Old 06-04-2019, 06:18 AM
rocky1's Avatar
Quoted: 447 Post(s)
Liked: 124
Is this to add to a present setup ? If so what is your setup right now. I say that since center probably should me matched to present system .. but not edged in stone for some
Transmaniacon likes this.
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is offline
post #3 of 30 Old 06-04-2019, 06:23 AM
Quoted: 70 Post(s)
Liked: 24
Originally Posted by cuibap View Post
I'm looking for a center speaker that is around $300 to $500 and NOT made in China. This is for my small media room with 65 OLED TV. Would you give me some suggestions? Thanks.
I would assume that at least 1 part of any speaker is made in China. I have a seamless bowfront 130 gallon saltwater tank that was made in China and is a work of art. I have seen made in the USA items that were complete junk. Living in a global economy, I really don't see an issue, but i understand not wanting an inferior product. Its best to match your front channels with your center so if you state what your L and R is some suggestions will come your way.
rocky1, Lp85253 and SouthernCA like this.
miketofani is offline
post #4 of 30 Old 06-04-2019, 07:26 AM
Quoted: 464 Post(s)
Liked: 246
here's one: https://www.tektondesign.com/center-channel-lp.html
hand assembled in the USA: http://www.ascendacoustics.com/pages...c/cmt340c.html
check out triad speakers, only available through dealers, lots of used on ebay. (dawngordon is a frequent poster and a dealer, I believer)
good luck
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #5 of 30 Old 06-04-2019, 07:38 AM - Thread Starter
cuibap's Avatar
Quoted: 120 Post(s)
Liked: 27
I have a pair of Klipsch R-14S Surround and Klipsch R-10SW. I don't know the name of the center and the front speakers as they came in as a 5.1 system. I will eventually replace these 3 speakers. Looking to replace the center first as it is getting worse
cuibap is offline
post #6 of 30 Old 06-04-2019, 07:43 AM
Quoted: 375 Post(s)
Liked: 318
Power Sound Audio assembled in US.
Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Located in the heartland of America, Power Sound Audio is headquartered in a small Midwest town called Mineral Ridge, OH.
https://www.powersoundaudio.com/coll...oducts/mt-110c
cocrh is offline
post #7 of 30 Old 06-04-2019, 07:52 AM - Thread Starter
cuibap's Avatar
Quoted: 120 Post(s)
Liked: 27
This is more than my budget. I was looking at the definitive technology but don't know if it is good with my system
cuibap is offline
post #8 of 30 Old 06-04-2019, 08:29 AM
pase22's Avatar
Quoted: 3098 Post(s)
Liked: 2576
Emotiva C1 would be a good choice. Klipsch RP have several center options that would work well. Ascend 340-SE center often recommended in this forum.
https://www.crutchfield.com/p_714RP6...00C-Ebony.html
https://emotiva.com/collections/loud...ts/airmotiv-c1
doni01 likes this.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #9 of 30 Old 06-04-2019, 08:48 AM
rocky1's Avatar
Quoted: 447 Post(s)
Liked: 124
My.02. If your doing front 3 by all means.wouldnt do center alone without knowing what your mains will be
rocky1 is offline
post #10 of 30 Old 06-04-2019, 09:05 AM - Thread Starter
cuibap's Avatar
Quoted: 120 Post(s)
Liked: 27
If I have to do all 3 front speakers with the center is around $300-$500, which 3 speakers do you recommend?
cuibap is offline
post #11 of 30 Old 06-04-2019, 09:06 AM
Quoted: 69 Post(s)
Liked: 32
I just replaced mine with klispch rc-42 ii, vocals are very clear.
Sent from my CLT-L04 using Tapatalk
boldventure is offline
post #12 of 30 Old 06-04-2019, 09:32 AM
rocky1's Avatar
Quoted: 447 Post(s)
Liked: 124
I may have misunderstood you. Thought You mentioned you were going to replace front three? I would think if only center and not changing your mains then try to find a center that could ppssibly match the mains you have.. what exactly is going on with the center you do have ?
Looked up you speaker the r14s is a surround speaker? Whats ur mains? Or u using them as mains?
rocky1 is offline
post #13 of 30 Old 06-04-2019, 09:54 AM
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
Don’t know what you have against China but Elac Debut Center is awesome
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #14 of 30 Old 06-04-2019, 09:57 AM
Quoted: 119 Post(s)
Liked: 72
^^ Great suggestions. I personally have three Ascend 340's as my front stage and they are great. But since you have Klipsch as surrounds and if you would like to stay with Klipsch I would look at the RP line recommended by pase22
doni01 is offline
post #15 of 30 Old 06-04-2019, 09:58 AM
Quoted: 310 Post(s)
Liked: 220
New Def Techs are made in China since that seems to be a sticking point for you. If you wanted to find an older one that was made in the US I'd recommend a CLR-2000 or the big-daddy CLR-3000.
KSpan is offline
post #16 of 30 Old 06-04-2019, 10:24 AM
pase22's Avatar
Liked: 2576
Not made in China: Paradigm (Premier & up), Klipsch, PSA.
post #17 of 30 Old 06-04-2019, 10:31 AM
rocky1's Avatar
Quoted: 447 Post(s)
Liked: 124
Reread original post ref npt knkwing what mains and center are. Should be labeled on back of speaker will show model
rocky1 is offline
post #18 of 30 Old 06-04-2019, 11:20 AM - Thread Starter
cuibap's Avatar
Quoted: 120 Post(s)
Liked: 27
The main 2 front speakers along with the center are garbage. I got as a 2nd hand and have been trying to replace them. Will eventually replace all 3 but thinking the center is more important
cuibap is offline
post #19 of 30 Old 06-04-2019, 11:27 AM - Thread Starter
cuibap's Avatar
Quoted: 120 Post(s)
Liked: 27
The room is small, 15ftx12ft, so I don't want to buy anything too big. I currently have Klipsch R-14S Surround as surround speakers and Klipsch R-10SW as sub. The front speakers and the center are Infinity (small like computer speakers) I think and I will need to replace those soon. Right now i am thinking to replace the center with a budget around $300 to $500. And few months after that, replace the front speakers.
cuibap is offline
post #20 of 30 Old 06-04-2019, 11:48 AM
Quoted: 375 Post(s)
Liked: 318
PSA is top notch for HT. Actually great value for what it provides in terms of dynamics and clarity but understand they are pricey.
Polk LSiM 704c is a great 3 way center that many have had very positive results here on AVS. Add the Polk LSiM 703 bookshelf, 705 or 707 tower depending on budget.
https://www.adorama.com/pkalsim704c....ce=rflaid62905
Polk store has a super deal on buy 4 LSiM 703 bookshelf and get a free LSiM 706c center. But maybe not in your budget right now.
https://www.ebay.com/itm/Polk-Audio-...MAAOSwq5FcuNII
Emotiva C1 also 3 way and great center.
cocrh is offline
post #21 of 30 Old 06-04-2019, 12:15 PM - Thread Starter
cuibap's Avatar
Quoted: 120 Post(s)
Liked: 27
Regular price for the LSiM 704c is $750? $299 on sale is a really good deal!
cuibap is offline
post #22 of 30 Old 06-04-2019, 12:25 PM
rocky1's Avatar
Quoted: 447 Post(s)
Liked: 124
Looks like those polk deals posted are a deal to be made. Better jump
rocky1 is offline
post #23 of 30 Old 06-04-2019, 12:55 PM
RayGuy's Avatar
Quoted: 2611 Post(s)
Liked: 2363
Replace all three with RSL CG3/CG23 ... UNDER budget. These should be plenty in your small room. Clear and detailed sound.
https://rslspeakers.com/cg3-overview/
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #24 of 30 Old 06-04-2019, 01:23 PM
jdlynch's Avatar
Quoted: 337 Post(s)
Liked: 131
I say go for the best center for the money, then slowly add matching L/R speakers as funds allow. That being said, I recommend pre-owned and that you look for an Aerial Acoustics CC3 center. One of the best center speakers ever. Aerials new models would be even better, but well beyond their budget. It’s too bad more aren’t familiar with Aerial Acoustics, they have lost a lot of appeal in the forums since they are not the latest fad.
Current Equipment: Datasat LS10 w/ Atmos and DIRAC. ATI 6005, AT527NC, Aerial Acoustics LR5's (LCR), SR3's sides, LR3's (rears), Seaton Submersive HP, Marantz VP15s1, 123" diag 16:9 Stewart Cima Neve screen, Oppo BDP-103, Palliser Flicks Theater Seating AC Power: Eaton whole-house surge protector at main panel, three dedicated 20 amp circuits, Surgex XR315 surge protector at equipment rack, Cyberpower 1400VA/900 watt, true sine wave UPS.
jdlynch is offline
post #25 of 30 Old 06-04-2019, 01:28 PM
ratbuddy's Avatar
Quoted: 661 Post(s)
Liked: 913
Klipsch has some products "designed and assembled in America" but their mainstream stuff seems to be made in China as far as I can tell. Is that not correct?
ratbuddy is offline
post #26 of 30 Old 06-04-2019, 02:37 PM
Quoted: 874 Post(s)
Liked: 264
Drivers made in China?
SouthernCA is online now
post #27 of 30 Old 06-05-2019, 04:57 AM
Dawn Gordon's Avatar
Quoted: 374 Post(s)
Liked: 236
As others have mentioned, Triad is an American manufacturer that hand builds their home theater speakers in Portland, Oregon. They use very high-quality parts and feature super-stiff internal bracing. The company will even color paint match (or veneer match) the speakers to match their surroundings.
For your size room I would recommend the Bronze Series:
https://www.triadspeakers.com/produc...ir-bronze-lcr/
https://www.triadspeakers.com/produc...bronze-center/
________________________________________
[email protected]
Dawn Gordon is offline
post #28 of 30 Old 06-05-2019, 05:06 AM - Thread Starter
cuibap's Avatar
Quoted: 120 Post(s)
Liked: 27
Thanks. I'm looking to see where they sell it and how much.
cuibap is offline
post #29 of 30 Old 06-06-2019, 05:47 AM
Quoted: 374 Post(s)
Liked: 236
Triad sells though local custom installers. Bronze LCRs have an MSRP of $650 each. It's up to the individual dealer whether they will discount or not.
[email protected]
post #30 of 30 Old 06-06-2019, 10:09 PM
Mudslide's Avatar
Quoted: 141 Post(s)
Liked: 204
Absolutely give a look to Aperion Audio. Their speakers are built right here in Oregon (!), have incredible quality for the price, free shipping (BOTH Ways if you don't like them), and are in your price range. Here you go ... https://www.aperionaudio.com/collections/speakers
You can't do better in your price range. You're welcome.
EDIT: Aperion speakers are designed in Oregon, but are (hand) built elsewhere. Don't know where. I suggest the Aperion Intimus speaker line for your needs.
Good luck with your search.
MARGARITAS,
they're not just for breakfast anymore.
Mudslide is online now
Reply Speakers
