My Speaker is connected With Gaming PC And It's Crackling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-11-2019, 03:52 AM - Thread Starter
Liked: 0
Hello Friends,
My Speaker is connected with my gaming Pc and it's making crackling noise on high bass sounds. What can be done about it to resolve the issue?
Lincoln90 is offline
post #2 of 10 Old 06-11-2019, 04:57 AM
Jawaburger's Avatar
Quoted: 182 Post(s)
Liked: 173
You either have a bad speaker, or bad speaker connection (on either the speaker itself, the computer, or the cable in between). You will want to test these by plugging the speaker into a different source, turn up the volume, if you still get crackels, then the speaker and/or the cord are the issue. If you can't swap the cord, then you will need a new speaker.
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | Phase Tech PC 9.1 (FL/FR) | Phase Tech PC 3.1 (C/SL/SR) | 3 Phase Tech Octave Power-15 Subs | 1 REL R-528 Sub
Jawaburger is online now
post #3 of 10 Old 06-11-2019, 11:11 AM
pase22's Avatar
Quoted: 2989 Post(s)
Liked: 2484
Originally Posted by Lincoln90 View Post
Hello Friends,
What speaker is it and how loud doyou play it?
Kef Q100 FL/FR,SL/SR, Q200C, SVS SB-2000, Denon AVR-X3400H, , Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #4 of 10 Old 06-11-2019, 09:35 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1125
Try connecting with optical if possible and see if that solves it.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is online now
post #5 of 10 Old 06-14-2019, 03:11 AM - Thread Starter
Liked: 0
I have a Bose SoundTouch 10. I have connected it wirelessly.
post #6 of 10 Old 06-14-2019, 03:12 AM - Thread Starter
Liked: 0
I generally play it on Medium volume. And only sometimes on high.
post #7 of 10 Old 06-14-2019, 03:14 AM - Thread Starter
Liked: 0
When I use it on PC or while gaming on it, the sound crackles. But if I connect it on mobile, no such issues occur.
post #8 of 10 Old 06-14-2019, 03:15 AM - Thread Starter
Liked: 0
Would it be a good idea to visit the service center?
post #9 of 10 Old 06-14-2019, 04:57 AM
Jawaburger's Avatar
Quoted: 182 Post(s)
Liked: 173
It is probably the speaker out connector on your computer. Is this a desktop computer? Many desktop computers have a speaker/headphone out on the front and the back, so if possible try the other port. You may also want to try connecting some headphones to the computer if you have them. If the headphones crackle this will help solidify that the connection on the computer is bad.
post #10 of 10 Old Today, 02:48 AM - Thread Starter
Liked: 0
Okay. I will try to test that out. Also found this could it be any helpful?
Reply Speakers
bass , speaker
