Dolby Atmos Home Theatre Setup Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-12-2019, 07:55 AM - Thread Starter
Liked: 0
All,
I'm looking for some advice on the best route to go down for getting a dolby atmos home theatre setup in my medium sized living room and want to get the Denon 3500H AV receiver and Klipsch speakers but unsure which speakers to select from the below 2 options;
Option 1:
* R-625FA floor-standing speakers
* R-34C centre channel speaker
* R-41M speakers
Option 2:
* RP-250F floor-standing speakers
* RP-500SA atmos speakers
* RP-400C centre channel speaker
* RP-240S surround speakers
I'm drawn more to the aesthetics of option 2 but unsure if the extra cost will be worth it?
Gav Smith is offline
post #2 of 5 Old 06-12-2019, 08:23 AM
pbz06's Avatar
Quoted: 918 Post(s)
Liked: 762
If you're not stretching the budget, and can afford it, yes the Premier is better.
Sony XBR-65Z9D / Oppo UDP-203 / Marantz SR7011 / Def Tech 9060 Series
pbz06 is online now
post #3 of 5 Old 06-12-2019, 09:06 AM - Thread Starter
Liked: 0
Would the RP-150M be better than the RP-400M for rear speakers?
post #4 of 5 Old 06-12-2019, 10:01 AM
Quoted: 787 Post(s)
Liked: 640
For Atmos, probably. They are less expensive, which will allow more money to be put towards a capable subwoofer.
sigpig is offline
post #5 of 5 Old 06-12-2019, 10:14 AM - Thread Starter
Liked: 0
I have a Klipsch r110sw sub already for my PC setup which I'm hoping to connect to the avr with a wa2 adapter if i can get my hands on one as they seem tricky to get hold of in UK
Reply Speakers
