Comparing Speakers - Klipsch KHO-7 vs. Yamaha NS-AW390 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-12-2019, 12:54 PM - Thread Starter
charlesmtf's Avatar
I am trying to set up a pair of outdoor speakers on the deck. I am looking at two specific models. Any advise on which would sound better?
Klipsch KHO-7
8 Ohms
75W Continuous / 150W Max
vs.
Yamaha NS-AW390
6 Ohms
40W Nominal / 130W Max
I am using the Sonos Connect:Amp to power the speakers:
At 8 Ohms, it outputs 55W/channel.
At 6 Ohms, it outputs 82.5W/channel.
I'm aware that wattage is not a direct indicator of audio quality. So, any input from someone who might actually have these speakers is greatly appreciated.
charlesmtf is offline
post #2 of 3 Old 06-12-2019, 10:18 PM
RayGuy's Avatar
Quoted: 2516 Post(s)
Liked: 2264
If you are willing to go $199/pair, then go for these instead:
https://rslspeakers.com/products/rsl-outsider-ii/
Offset tweeter allows them to be placed either horizontally or vertically with equal efficacy.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #3 of 3 Old 06-13-2019, 01:45 AM - Thread Starter
charlesmtf's Avatar
Thanks for the recommendation. Those look like a nice pair. $199 is not too much... that's what the Klipsch were going for. I wish I could get them local somewhere here in New York, though. I have a party here at the house this Saturday, so everything needs to be in place before then. Which basically somewhat limits me to Best Buy or Amazon.
Reply Speakers
