Suggestions LCR under $4k - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By crg28
  • 1 Post By Sekosche
  • 1 Post By bear123
  • 1 Post By pase22
  • 1 Post By chucky7
post #1 of 12 Old 06-15-2019, 02:34 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 4
I was set on Ascend Sierra Towers w Raals after listening to them at a friend's Home Theater. But the truth is I have not really been able to try any other models.
I was hoping to get some suggestions from the pros here on 3 LCRs for $4k or under for a dedicated Home Theater.
This will be 90% movies (including watching a lot of music concerts) and 10% Music/Live Sports/etc...
One row of 4 seats in a 16 x 24 room. Amp is an Emotiva XPA-11 Gen 3.
Deejay Freddy likes this.
crg28 is offline
post #2 of 12 Old 06-15-2019, 02:39 PM
Quoted: 1464 Post(s)
Liked: 1037
The Ascend Towers with Raal’s May be good for music, but I’m not sure if they are the best choice for a theater scenario.
You might want to look to something with a bit more force like Klipsch RF7iii’s.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #3 of 12 Old 06-15-2019, 02:39 PM
pase22's Avatar
Quoted: 3084 Post(s)
Liked: 2559
Try Cruthfields speaker compare app. Lots of different brands and models from different price points.
https://www.crutchfield.com/speakercompare/
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, , Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #4 of 12 Old 06-15-2019, 02:54 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 4
The RF7 III are above my budget ….when you add a center, this goes well above $4k.....
Also, what is the deal with 10" woofers on LCRs when most of time I will be crossing over to subs at 80HZ? A little overkill? I'm not an expert by any means....but just wondering why go so big on LCR woofers?
crg28 is offline
post #5 of 12 Old 06-15-2019, 03:02 PM
Sekosche's Avatar
Quoted: 1375 Post(s)
Liked: 3373
For 90% movies under $4K, you’d be hard pressed to beat PSA for a L/C/R combo; three MTM-210T are $3,225.
https://www.powersoundaudio.com/prod...ant=6802836868
bear123 likes this.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is offline
post #6 of 12 Old 06-15-2019, 03:03 PM
Liked: 1037
I’ve seen plenty of people get that combo for $4000 or less. It’s only like a 30% discount needed.
Well to begin, an 80hz crossover isn’t a brick wall, in fact it extends down to well below 80hz before it becomes negligible. So smoother crossover.
Increased power handling.
Improved efficiency. So you can hit THX Reference at your listening position without stressing every component in your system.
More mid bass I guess.
Have a listen and hear for yourself.
Not to mention 80hz crossover isn’t permanent. You can do a 60hz, 40hz, even 20hz crossover, whatever you feel sounds the best, and going lower does remove any possible subwoofer localization.
post #7 of 12 Old 06-15-2019, 07:02 PM
ack_bk's Avatar
Quoted: 1334 Post(s)
Liked: 1467
I like these along with the Klipsch RP series. You are also in the ballpark for Revel Speakers, Kef, and PSB.
What sub do you have OP?
ack_bk is offline
post #8 of 12 Old 06-15-2019, 08:09 PM
bear123's Avatar
Quoted: 2490 Post(s)
Liked: 3883
Under 4k budget, nothing comes close to the PSA option. 8 ohm, 98 dB efficient speaker means they require ten times less power than typical low efficiency speakers. Clean, accurate, low distortion, amazing dynamics. Dual 10" woofers allow ultra low distortion that little 6" woofers just can't approach.
jamiebosco likes this.
bear123 is online now
post #9 of 12 Old 06-16-2019, 12:07 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 4
Didn't realize they were 16" Deep and 11" wide....those are monster speakers....
While those would be nice, I need a little slimmer towers if possible.
crg28 is offline
post #10 of 12 Old 06-16-2019, 12:08 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 4
I dont have the subs yet....posted similar question in the Sub section....Have a $2500 budget allocated for 2 subs.
crg28 is offline
post #11 of 12 Old 06-16-2019, 02:41 AM
pase22's Avatar
Liked: 2559
For great value/performance, Dual HSU VTF-15H MK2's.
http://www.hsuresearch.com/products/vtf-15hmk2Dual.html
Or
Dual PSA V1510's
https://www.powersoundaudio.com/products/V1510
bear123 likes this.
pase22 is offline
post #12 of 12 Old 06-16-2019, 03:22 AM
chucky7's Avatar
Quoted: 3402 Post(s)
Liked: 4156
Too bad you couldn't fit the JTR Noesis 228HTs...
You can also look at the JTR Single 8HTs.
Get 3 JTR Single 8HTs and 2 other JTR 8HT variants for just a little over $4000 after discounts for multiples...
Or get 3 JTR Single 8HTs and put the leftover towards better subs...
Speakers: L/C/R: JTR Neosis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is offline
Reply Speakers
