speaker with micro usb - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-16-2019, 05:58 PM - Thread Starter
951Michael's Avatar
I thought this would be a simple solution but it is turning out difficult. I have speakers that charge through a micro usb. I would like to extend this speaker 15 feet. I thought this was easy but I cannot seem to find a micro usb cable that has a heavy enough gauge to power the speakers adequately. Unknowingly I purchase a 15 foot micro usb cable off of amazon only to be shown that because of the length it won't charge. I did a search for a heavy gauge micro usb cable but I cannot find anything. Got to be kidding me. Does no cable exist? I suppose you are going to ask me to use an extension cord but I don't want an extension cord with the plug in to be in the middle of the room. Usb cords are cleaner than extension cords.
-Mike
951Michael is offline
post #2 of 2 Old 06-16-2019, 06:52 PM
acras13's Avatar
Quoted: 316 Post(s)
Liked: 292
http://www.yourcablestore.com/USB-Ca...m_ep_42-1.html
If you are trying to go over 16 foot total you need an active solution from what I've seen . I've stretched that a little with low power devices (mice) with some success but I would imaging speakers are going to require more power . If you are going to stay under that , they make USB 2.0 F to micro M adapters that you can use to get a M to M USB cable to work for your speakers .
Turn that $*!# UP!! --Beethoven
acras13 is offline
Reply Speakers
