Dayton Audio MK402X - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-17-2019, 10:37 AM - Thread Starter
Pete7874's Avatar
Quoted: 150 Post(s)
Liked: 95
Dayton Audio MK402X
I noticed Dayton has released an updated version of their MK402 small bookshelf speakers, the MK402X:
https://www.parts-express.com/dayton...-pair--300-465
Reading some past reviews, one of the major gripes about the original MK402 was elevated and offending treble. It looks like Dayton accepted that criticism and redsesigned the crossover in this updated MK402X, alas, I haven't seen any reviews yet. Has anyone heard them yet?
I'm looking for some inexpensive small bookshelves as L/R mains that will fit on the TV cart next to my TV and I'm working with very limited amount of space, so these naturally drew my interest. I am currently using DefTech ProMonitors 800, but their mid bass is seriously lacking, forcing me to keep my crossover to the sub relatively high. I'm hoping these Daytons will have slightly more low end due to the ported design and overall larger cabinet, but I realize there is only so much you can expect from a 4" woofer. I'm also hoping my old Yamaha RX-V471 can handle the load. Thankfully it's not a large room and I sit fairly close to the TV, so I don't crank it up too high, and it's only a 3.1 setup.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Pete7874 is online now
post #2 of 13 Old 06-17-2019, 10:43 AM
Quoted: 1465 Post(s)
Liked: 1038
Supposedly these have quite a bit of bass for such a small form factor.
No Audiophile did a review on these and was impressed? He had the old version and once he eq’ed the treble down (which they have done with this now) he said they couldn’t be beat for the price.
These also have more bass than the old Dayton’s which used a 6.5 woofer.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #3 of 13 Old 06-17-2019, 12:01 PM
_tk
Quoted: 435 Post(s)
Liked: 174
I have the "older" version and they have a decent amount of bass for their size. You can definitely cross them over @ 80Hz and have nothing to worry about.
_tk is online now
post #4 of 13 Old 06-17-2019, 12:04 PM - Thread Starter
Pete7874's Avatar
Quoted: 150 Post(s)
Liked: 95
Great to hear. Thanks!
post #5 of 13 Old 06-17-2019, 02:42 PM
zieglj01's Avatar
Quoted: 2961 Post(s)
Liked: 2874
Yes -- they look better and I may be interested -- the crossover looks like they really put some work in them -- the sensitivity is still low, for the extra bass response
Who AM I
zieglj01 is online now
post #6 of 13 Old 06-17-2019, 02:45 PM
zieglj01's Avatar
Liked: 2874
I have owned a speaker with a 3 inch woofer that can put out way more bass than the B652 Dayton
Who AM I
post #7 of 13 Old 06-17-2019, 02:46 PM
Liked: 1038
Yeah, I think anything ported can.
When someone says anemic bass I immediately think to those!
post #8 of 13 Old 06-17-2019, 03:08 PM
Quoted: 118 Post(s)
Liked: 399
That's one heck of a crossover for the price--pretty amazing. Since they've upgraded the small guy, maybe the'll take up my suggestion to offer an upgraded BR-1 kit with my crossover. I'm still waiting to hear back.
PhilharmonicDennis is online now
post #9 of 13 Old 06-17-2019, 03:17 PM
Liked: 1038
I find it interesting how they almost doubled the crossover components but the price does not reflect that.
I’m wondering if they cut costs somewhere else in the build to keep the price the same....
At an immediate glance the foam covering for the crossover wires is missing.
post #10 of 13 Old 06-17-2019, 03:31 PM
_tk
Quoted: 435 Post(s)
Liked: 174
A long as you chop the treble a bit the older ones aren't that bad (hooray tone controls).
If anyone wants to take on a DIY project, the Overnight Sensations completely blow them out of the water for about $60 more (plus labor) and they are only a couple of inches deeper in dimensions.
_tk is online now
post #11 of 13 Old 06-18-2019, 10:14 PM - Thread Starter
Pete7874's Avatar
Quoted: 150 Post(s)
Liked: 95
I ended up buying these little Daytons. Haven't had a lot of auditioning time yet, but so far no complaints. I re-ran YPAO calibration on my receiver: it applied an 80 Hz crossover. For comparison, it was at 100 Hz with my old ProMonitors 800. I listened to some music - again, they sound nicer than the 800s, alas, that's not exactly a high benchmark to beat. They do not sound overly bright to me. Rear ports do make some noise at higher volumes if you try to run them at full range. Fit and finish isn't spectacular, but not bad for $70.
My old Yamaha does get a bit more warm powering these, but hopefully it can manage. I don't turn it up anywhere close to max.
post #12 of 13 Old 06-19-2019, 09:22 AM
zieglj01's Avatar
Liked: 2874
That is a good report for a budget friendly speaker -- some port noise is no surprise for a budget friendly speaker
Who AM I
post #13 of 13 Old 06-19-2019, 09:33 AM
_tk
Quoted: 435 Post(s)
Liked: 174
They are 4ohm speakers. I'd imagine they were designed to be used with some of the inexpensive Class D amps that PE sells (which is what I am running mine with).
_tk is online now
Reply Speakers
