Reverb............... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-18-2019, 04:39 AM - Thread Starter
Liked: 0
Question Reverb...............
Bought my condo with existing surround sound speakers in each of the 4 corners of the room.
Bought a Sony soundbar.
Had a tech guy come and hook everything up.
QUESTION-PROBLEM: When the soundbar and the surround sound speakers are running simultaneously....there is a reverb/echo/delay.
Tech guy insists the reverb is unavoidable.
Unavoidable doesn't sound right to me.
Sony soundbar - HT-ST5000
Samsung Series 6 6300 ...........(Don't buy a Samsung refrigerator!)
Denon AVR-E200 AV Surround Receiver
PureAcoustics speakers in the 4 corners of the room mounted at the top of the wall
Do everyone agree that a delay/reverb is unavoidable?
Many thanks for any thoughts.
Jeff Sickles is offline
post #2 of 6 Old 06-18-2019, 07:55 AM
Quoted: 68 Post(s)
Liked: 30
Not sure why you would want the sound bar and the wall speakers playing the same sounds.
I suspect you have the signal going from the receiver to both the speakers and the soundbar. The soundbar then does it’s own processing- which add some delay, before the sound comes out - resulting in the echo.
You effectively have two processors (soundbar and receiver) processing the signal - hence the timing mismatch. You can try adding a delay in the receiver, however I would personally, get rid of the soundbar and replace them with speakers if possible, or live with the built in speakers if aesthetics wouldn’t allow it
thebrieze01 is offline
post #3 of 6 Old 06-18-2019, 08:04 AM
Quoted: 556 Post(s)
Liked: 291
agreed. use one or the other. probably best to use the receiver, so all you will need is a center channel.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #4 of 6 Old 06-18-2019, 08:10 AM
gajCA's Avatar
Quoted: 9082 Post(s)
Liked: 6224
You chose to compromise by trying to combine a powered soundbar setup with a passive speaker setup so I completely agree with the tech guy that compromised sound is the inevitable result.
To "cure" this, return the $1500 soundbar and get passive front speakers for you receiver or disconnect the four corner speakers and don't use the Denon at all.
As your receiver is 5.1, you will just have to buy a center channel and sub and use the rear corner speakers as your surrounds and your front corner speakers as the front left and right which is another compromise as the front left and right ideally should be at ear height when seated but that would still sound a lot better than what you have now IMHO.
A "soundbar like" passive center channel speaker can be had if you want that slim profile.
There are two choices that I'm aware of.
https://www.crutchfield.com/S-lIdYCL...caAgT9EALw_wcB
https://www.jbl.com/loudspeakers/JBL...EaAiWsEALw_wcB
For a subwoofer consider one of these paying special attention to the notes at the top:
PORTED SUBWOOFERS $600 AND BELOW, DELIVERED
NOTE:
*THE LARGER PORTED SUBS DELIVER AT LEAST 40% MORE SOUND PRESSURE LEVEL
THAN THE SAME BRAND'S SEALED VERSION WITH SAME SIZE WOOFER AND AMP
*IF LOOKING AT LARGER/MORE EXPENSIVE SUBWOOFERS ADD PSA TO THE LIST OF BRANDS
*IF YOU ARE NOT AN ACTION MOVIE FAN A SUBWOOFER WITH 22-30HZ EXTENSION WOULD BE FINE
*FOR MUSIC A 30HZ SUB IS A FINE CHOICE
*BEFORE BUYING MAKE A CARDBOARD CUTOUT OF THE SIZE OF THE SUB TO MAKE SURE IT IS NOT TOO LARGE FOR YOU
Specs are from the manufacturer unless noted otherwise.
Warranty
for AMP
1 year 150watts =12w7h24d= 25 lbs 8" [23hz] $219 EARTHQUAKE LOW PROFILE CP8 (Amazon price)
3 years 120watts =13w15h16d= 29 lbs 10" [29hz] $250 MARTIN LOGAN DYNAMO 500, limited time offer
2 years 350watts =15w16h17d= 40 lbs 10" [30hz] $399 RSL SPEEDWOOFER 10S, (extension from Sound & Vision review)
2 years 250watts =15w19h17d= 42 lbs 10" [25hz] $455 HSU VTF 1 MK3 (extension from Audioholics review)
5 years 300watts =15w19h20d= 46 lbs 10" [18hz] $499 SVS PB1000, (extension from Sound & Vision Review)
5 years 500watts =15w19h20d= 72 lbs 10" [20hz] $500 MONOPRICE MONOLITH THX 10"
3 years 300watts =16w22h21d= 69 lbs* 12" [19hz] $569 RHYTHMIK LV12F
2 years 350watts =15w21h22d= 62 lbs 12" [18hz] $607 HSU VTF2 MK5, (extension from Audioholics review)
* = shipping weight
SEALED SUBWOOFERS $650 AND BELOW, DELIVERED
3 years 300watts =12w13h13d= 27 lbs 10" [24hz] $399 MARTIN LOGAN DYNAMO 700W, limited time offer Amazon.
NOTE: WIRELESS TRANSMITTER INCLUDED
5 years 300watts =13w14h16d= 27 lbs 12" [23hz] $499 SVS SB1000, (extension from Sound & Vision)
5 years 500watts =13w16h21d= 50 lbs 10" [20hz] $500 MONOPRICE MONOLITH MTS10 THX
3 years 300watts =14w14h16d= 58 lbs* 12" [18hz] $539 RHYTHMIK L12
5 years 500watts =14w15h17d= 35 lbs 12" [19hz] $649 SVS SB2000 outlet, (extension from Sound & Vision)
* = shipping weight
Geoff A. J., California
gajCA is offline
post #5 of 6 Old 06-18-2019, 08:29 AM
pase22's Avatar
Quoted: 3333 Post(s)
Liked: 2798
As everyone else already mentioned, you can't have both and expect good sound. A pair of bookshelf speakers, center and good sub will cost significantly less than the soundbar and will sound significantly better. Use the rear speakers as either height or surround. Front in-walls can be used as height channels as well.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #6 of 6 Old 06-18-2019, 10:30 AM
RayGuy's Avatar
Quoted: 2852 Post(s)
Liked: 2620
You have the perfect scenario for a three channel PASSIVE soundbar. Lots of good options out there from Golden Ear, Revel, KEF, Def Tech, PSB, Paradigm, Triad, Martin Logan, Monitor Audio ... to name just a few. Mixing two processors into the system was a mistake, so return the active soundbar and get back to echoless sound!
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
Reply Speakers
