KEF LS50 passive vs wireless - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-18-2019, 07:44 AM - Thread Starter
Alkaizer's Avatar
Quoted: 27 Post(s)
Im looking to upgrade my 2008 HT setup consist of paradigm monitors speakrs (titans for mains) and SVS subwoofer and ONKYO AVR with 130w per ch.
i listened to LS50 active speaker few days ago and really liked them. afterward, i made extensive research about these speakers and on how the best way to make some upgrades i would like your advice on this.
i heard LS50 passive is very hard to drive without a good amp. the point is i dont want to install an amp in my setup.
that would leave me with a high end AVR (Cambridge CXR200, arcam 850/550 and nad t777v3) that capable of driving the LS50.....but these are really expensive.
and the lower end of these brands dont have high watt power compare with mainstream ones.(Denon/Yamaha/Onkyo).
so there would probably be two options:
1- get LS50 wireless. buy a new cheap receiver to drive the remaining paradigm speakers (which i will eventually upgrade)
2- buy LS50 passive and use the remaining amount in a mid range Yamaha/onkyo with 140w 2ch.
is there other option? would option 2 be able to drive the LS50 passive??
my use is 70% gaming and 30% movies/tv shows. (gaming type is mostly music)
Alkaizer is offline
post #2 of 4 Old 06-18-2019, 08:05 AM
Elihawk's Avatar
Quoted: 1892 Post(s)
Liked: 2012
The LS50 aren't very high sensitivity...85dB, however, you might be suprised how loud they can be driven with a good, but not high end AV rec/Amp. I had a Marantz slimeline, advertised at 50 watts/channel, and my EmPtek speaker (87dB sensitive) got as loud as I care to play them without pushing them too far.
However, if you like it loud, you might want to go for a higher sensitive speaker and perhaps buy an AV rec with preouts to future-proof for adding more amplification down the road. (Emotiva T1 on sale for 500/pr, gets you into 88 dB range. the Chane 2.4 would put you at 90 dB, although I am not sure they are available right now).
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is online now
post #3 of 4 Old 06-18-2019, 10:48 AM
Quoted: 830 Post(s)
Liked: 260
I had also heard that ls50s need an high end amplifier to bring the best out of them.
I have a Yamaha class D AVR (100wpc) and a Parasound High current class AB amp (75 wpc).
To my ears, I can not make out much of a difference.
Maybe none of my choices are high (enough) end or maybe it does not make that much of a difference as long as amps are performing within their operational limits and not clipping. I tend to believe the latter.
Just my two cents. YMMV
SouthernCA is online now
post #4 of 4 Old 06-18-2019, 02:07 PM - Thread Starter
Alkaizer's Avatar
Quoted: 27 Post(s)
thanks for the replies.
in term of costs, option 1 will have the new LS50 active speaker for 1800 USD and cheap AVR for 1000 USD, total 2800.
option 2 with new LS50 passive speaker is only 700 USD (offered by agency) and mid end AVR 1500-2000 USD, total 2700.
from my experience and the review of many youtubers and users, the active speaker is one of the best. i heard its also good to invest in a good main speakers.
Alkaizer is offline
Reply Speakers
